[petsc-users] what kind of stuffs I forget to free?
Fande Kong fd.kong at siat.ac.cn
Thu Mar 20 12:29:14 CDT 2014
Thanks, Jed,
I tried valgrind, but it could not catch any noises. I used these
options:   mpirun -n 8 valgrind --tool=memcheck -q --num-callers=20
--log-file=valgrind.log.%p   ./nonlinearElasticity3d  -malloc off .
I think I forget freeing something or petsc does.
On Wed, Mar 19, 2014 at 4:58 PM, Jed Brown <jed at jedbrown.org> wrote:
> Fande Kong <fd.kong at siat.ac.cn> writes:
> > I run my code with options: -malloc_debug -malloc_dump, then the
> following
> > messages are produced, but nothing happened in my code. I want to know
> what
> > kind of objects I forgot freeing. Any suggestions?
> Huh, those should show more stack.  Before trying to think hard, can you
> run with valgrind?
> > [0]Total space allocated 6864 bytes
> > [ 0]256 bytes PetscSplitReductionCreate() line 91 in
> > /home/fdkong/math/petsc-3.4.1/src/vec/vec/utils/comb.c
> > [ 0]256 bytes PetscSplitReductionCreate() line 88 in
> > [ 0]512 bytes PetscSplitReductionCreate() line 87 in
> > [ 0]512 bytes PetscSplitReductionCreate() line 86 in
> > [ 0]80 bytes PetscSplitReductionCreate() line 81 in
> > [ 0]16 bytes PetscThreadCommReductionCreate() line 448 in
> /home/fdkong/math/petsc-3.4.1/src/sys/threadcomm/interface/threadcommred.c
> > [ 0]512 bytes PetscThreadCommReductionCreate() line 440 in
> > [ 0]256 bytes PetscThreadCommReductionCreate() line 436 in
> > [ 0]1280 bytes PetscThreadCommReductionCreate() line 435 in
> > [ 0]32 bytes PetscThreadCommReductionCreate() line 432 in
> > [ 0]128 bytes PetscThreadCommWorldInitialize() line 1242 in
> > /home/fdkong/math/petsc-3.4.1/src/sys/threadcomm/interface/threadcomm.c
> > [ 0]2560 bytes PetscThreadCommWorldInitialize() line 1241 in
> > [ 0]32 bytes PetscThreadCommWorldInitialize() line 1233 in
> > [ 0]16 bytes PetscThreadCommSetAffinities() line 424 in
> > [ 0]48 bytes PetscThreadCommCreate() line 150 in
> > [ 0]336 bytes PetscThreadCommCreate() line 146 in
> > [ 0]32 bytes PetscCommDuplicate() line 151 in
> > /home/fdkong/math/petsc-3.4.1/src/sys/objects/tagm.c
> > Fande,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140320/73b8b4f0/attachment.html>
