[petsc-users] undefined reference to `PetscMalloc1'
Barry Smith
bsmith at mcs.anl.gov
Thu Mar 20 08:17:01 CDT 2014
On Mar 20, 2014, at 8:04 AM, Raeth . Peter <PRaeth at drc.com> wrote:
> Am trying to build the code in a PETsc tutorial:
> http://www.mcs.anl.gov/petsc/petsc-dev/src/ksp/ksp/examples/tutorials/ex7.c.html
The examples in this directory, denoted by petsc-dev, work with the development version of PETSc. Sometimes they will be different than the examples in the release of PETSc http://www.mcs.anl.gov/petsc/petsc-current/src/ksp/ksp/examples/tutorials/ex7.c.html denoted by petsc-currant.
They shouldn’t be mixed together. So either use the PETSc release and the examples in it or the development version of PETSc and the examples in it.
Barry
> Got past the compile error regarding KSPSetOperators by adding the fourth parameter:
> ierr = KSPSetOperators(ksp,A,A,SAME_PRECONDITIONER);CHKERRQ(ierr);
> Added the include file the man page said was needed:
> #include <petscsys.h>
> Using the following build command:
> gcc gmres_ex7.c -o gmres_ex7 -I $PET_HOME/pkgs/valgrind-3.6.1/include -I $PET_HOME/.unsupported/petsc-3.4.4/Installed/include -I $PET_HOME/.unsupported/mpich-3.0.3/Installed/include -L $PET_HOME/.unsupported/petsc-3.4.4/Installed/lib -l petsc
> Getting the following link error:
> Many thanks for any insights the group has to offer.
> Best,
> Peter.
> ________________________________
> This electronic message transmission and any attachments that accompany it contain information from DRC® (Dynamics Research Corporation) or its subsidiaries, or the intended recipient, which is privileged, proprietary, business confidential, or otherwise protected from disclosure and is the exclusive property of DRC and/or the intended recipient. The information in this email is solely intended for the use of the individual or entity that is the intended recipient. If you are not the intended recipient, any use, dissemination, distribution, retention, or copying of this communication, attachments, or substance is prohibited. If you have received this electronic transmission in error, please immediately reply to the author via email that you received the message by mistake and also promptly and permanently delete this message and all copies of this email and any attachments. We thank you for your assistance and apologize for any inconvenience.
