[petsc-users] Fwd: Convergence problems
Oliver Browne oliver.browne at upm.es
Wed Mar 19 12:22:59 CDT 2014
The problem at the moment is building the Hessenberg matrix. Once I have
that I find the eigenvalues with LAPACK.
So I am solving
x = (J^I)b with PETSc (ILU and GMRES) for the first column of the
Hessenberg matrix and for the big problem (Dof = 64000) I can't get it
to converge.
Oliver Browne
Ph.D. Student
School of Aeronautics (E.T.S.I.A.)
Universidad Politécnica de Madrid
Tel No: (0034) 913 366 326 ext: 201
http://matap.dmae.upm.es/numat/index.php/people/mod-fellow-in?persona=oliver
http://www.anade-itn.eu/index.php/people/fellow-information
On 19-03-2014 18:17, Jose E. Roman wrote:
> El 19/03/2014, a las 18:03, Oliver Browne escribió:
>> To Whom It May Concern,
>> I am using petsc to solve an eigenvalue problem
>> Jq = oq
>> I am obtaining the Jacobian matrix, J, from solving
>> F(x) = 0
>> and by numerically perturbing the solution to give
>> J = dF(x)/dx = F(x + delta) + F(x) / delta             (1)
>> I use the PETSc to solve Ax=b in the Arnoldi iteration to build the
>> Hessenberg matrix.
>> For small problems (1000 DoF) I obtain accurate results in a timely
>> fashion by using ILU(2) and GMRES.
>> However, when I move to bigger problems (60000 Dof) I can't get the
>> GMRES to converge. 5 GMRES steps take an HOUR (it is incredible!!!). I
>> have tried modifying the levels for ILU but with no success and a few
>> different preconditioners. I have also tried some of the
>> MatGetOrdering to improve the stability. I believe that it is down to
>> the structure of my matrix, because I have tried similar size matrices
>> obtained from a different code which creates the analytical Jacobian
>> (has a different topology), of which I can get a convergence to GMRES
>> in about 3 mins. I have attached a figure showing the structure of the
>> matrix for a smaller problem but obtained with equation (1) above.
>> I would be very grateful if you could give me some advice in choosing
>> a different preconditioner/solver etc or anything else which could
>> help.
>> Thanks in advance
>> Olls<MatrixStructure.png>
> Are you using SLEPc for the eigenvalue problem? Which eigenvalues do
> you want? Are you using GMRES for the shift-and-invert solve?
> Jose
