[petsc-users] Fwd: Convergence problems
Oliver Browne
oliver.browne at upm.es
Wed Mar 19 12:03:59 CDT 2014
To Whom It May Concern,
I am using petsc to solve an eigenvalue problem
Jq = oq
I am obtaining the Jacobian matrix, J, from solving
F(x) = 0
and by numerically perturbing the solution to give
J = dF(x)/dx = F(x + delta) + F(x) / delta (1)
I use the PETSc to solve Ax=b in the Arnoldi iteration to build the
Hessenberg matrix.
For small problems (1000 DoF) I obtain accurate results in a timely
fashion by using ILU(2) and GMRES.
However, when I move to bigger problems (60000 Dof) I can't get the
GMRES to converge. 5 GMRES steps take an HOUR (it is incredible!!!). I
have tried modifying the levels for ILU but with no success and a few
different preconditioners. I have also tried some of the MatGetOrdering
to improve the stability. I believe that it is down to the structure of
my matrix, because I have tried similar size matrices obtained from a
different code which creates the analytical Jacobian (has a different
topology), of which I can get a convergence to GMRES in about 3 mins. I
have attached a figure showing the structure of the matrix for a smaller
problem but obtained with equation (1) above.
I would be very grateful if you could give me some advice in choosing a
different preconditioner/solver etc or anything else which could help.
Thanks in advance
Olls
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140319/f2f19cd4/attachment-0001.png>
