[petsc-users] Spatial distribution of the residual after an implicit TS timestep
Mani Chandra
mc0710 at gmail.com
Tue Mar 18 22:56:38 CDT 2014
I can't find SNESSetMonitor in petsc-dev. I get the following error even
after including petscsnes.h
error: ‘SNESSetMonitor’ was not declared in this scope
Moreover, there is no manpage for it on the petsc-dev SNES website:
http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/SNES/index.html
Has it been removed?
On Tue, Mar 18, 2014 at 9:11 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Mar 18, 2014, at 7:54 PM, Mani Chandra <mc0710 at gmail.com> wrote:
> > The residual of the system of equation that I feed into TS with
> TSSetIFunction. I have a system of equations and I want to probe where most
> of the residual is coming from. The reason is that after certain time of
> evolution, the initial residual at the beginning of each time step
> increases by orders of magnitude than what it used to be at the beginning
> of the time step at early times. For ex, say at t=200, the SNES norm at the
> beginning of a TS timestep with the theta method would be something like
> 1.0812 and at t = 300, it would be 2e5 at the beginning. SNES then has to
> work much harder to reach the abs norm levels and so I want to investigate
> what is happening.
> So this is the initial residual in the nonlinear solve.
> -snes_monitor_residual works for plotting if it is 2d otherwise write your
> own custom SNES monitor routine and call TSGetSNES, SNESSetMonitor().
> Barry
> > On Tue, Mar 18, 2014 at 7:48 PM, Jed Brown <jed at jedbrown.org> wrote:
> > Mani Chandra <mc0710 at gmail.com> writes:
> > > Is there anyway I can get the residual at the beginning of the time
> step? I
> > > tried TSSetPreStage and TSSetPreStep but they didn't work. Setting
> > > TSSetPreStage would crash the program even if there is nothing in the
> > > routine that I set and TSSetPreStep would give me the residual at the
> end
> > > of the previous time step. I want to take a look at the residual at the
> > > beginning of the new time step before the nonlinear solver starts.
> > Residual of what? What are you going to do with it?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140318/1c298ce3/attachment.html>
