[petsc-users] Custom vector owenrship ranges
Tue Mar 18 18:16:28 CDT 2014
On Tue, Mar 18, 2014 at 11:00 AM, Mohammad Bahaa
<m.bahaa.eldein at gmail.com>wrote:
> I used
> call VecCreateMPIWithArray(PETSC_COMM_WORLD,1,nc,ncall,myx,xall,ierr)
> however, when I use process 0 to write a file containing the combined
> values (the xall vector), the values seem not to be updated by some
> processes, eventhough I use PetscBarrier, in other words, values locally
> owned by processes 0 and 2 are ok, but those owned by process 1 & 3 aren't !
For collective writes, use VecView() or -vec_view
   Matt
> On Tue, Mar 18, 2014 at 3:43 PM, Mohammad Bahaa <m.bahaa.eldein at gmail.com>wrote:
>> the second approach of the MPI vector did it for me, thanks
>> On Tue, Mar 18, 2014 at 3:20 PM, Mohammad Bahaa <m.bahaa.eldein at gmail.com
>> > wrote:
>>> Forgive me as my expression "sum up" was misguiding or misplaced, I
>>> didn't mean to literally sum the values in the vectors, I meant I want to
>>> put all values from each local vector into one global vector that can be
>>> accessed by all processes, "COMM_WORLD" communicator for instance
>>> On Tue, Mar 18, 2014 at 3:09 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>> On Tue, Mar 18, 2014 at 7:53 AM, Mohammad Bahaa <
>>>> m.bahaa.eldein at gmail.com> wrote:
>>>>> I'm using "PETSC_COMM_SELF" communicator for running n serial
>>>>> independent processes, I need to sum up a certain vector from the n
>>>>> processes in one vector, however, vectors involved in each process vary in
>>>>> size, and I couldn't find any function to define custom ownership ranges,
>>>>> so assuming I have a 4 processes run with each computing an "x" vector as
>>>>> follows:
>>>>> 1. process (1) with x of length 51
>>>>> 2. process (2) with x of length 49
>>>>> 3. process (3) with x of length 52
>>>>> 4. process (4) with x of length 48
>>>> Let your local length be n, so that on proc 3 n== 52. Then
>>>>   VecCreate(comm, &v);
>>>>   VecSetSizes(v, n, PETSC_DETERMINE);
>>>>   VecSetFromOptions(v);
>>>>   <fill up v>
>>>>   VecSum(v, &sum);
>>>> You could also make a parallel Vec from your Seq vecs:
>>>>   VecGetArray(lv, &array);
>>>>   VecCreateMPIWithArray(comm, 1, n, PETSC_DETERMINE, array, &v);
>>>>   Thanks,
>>>>      Matt
>>>>> The processes sum up to 100 elements, when I define a vector "x_all"
>>>>> of size "100" with "PETSC_COMM_WORLD" communicator, the ownership
>>>>> ranges are equal, which isn't the case, how to customize them ?
>>>>> Mohamamd Bahaa ElDin
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140318/188a335b/attachment.html>
