[petsc-users] Using PETSC for a CFD solver
Mohammad Bahaa m.bahaa.eldein at gmail.com
Tue Mar 18 07:44:05 CDT 2014
The "PETSC_COMM_SELF" worked like a charm for me, thanks alot
On Mon, Mar 10, 2014 at 4:50 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Mar 10, 2014 at 9:36 AM, Mohammad Bahaa <m.bahaa.eldein at gmail.com>wrote:
>> Hi,
>> I'm pretty new to PETSC, so pardon me if the question is primitive
>> somehow, I used *METIS *to partition my grid (represented by a system of
>> linear equations Ax=b) to a number of sub-grids, say 4 sub-grids, with 4
>> different systems of linear Equations (A1x1=b1, A2x2=b2, ...), can anyone
>> post an example showing how to solve these "n" sub-systems simultaneously,
>> I've tried the following program, but it's not working correctly, as when I
>> use *MatGetOwnershipRange *in each process I find that A1 ownership
>> range is 1/4 the matrix size for the first process, while it should be all
>> of it.
> I will answer this two ways. First, here is the "PETSc strategy" for doing
> the same thing.
>   1) Write a code that assembles and solves the entire thing
>   2) Use -pc_type bjacobi -ksp_type preonly -sub_ksp_type <whatever you
> want> -mat
>   3) You can use ParMetis inside PETSc with the MatPartitioning
> This will solve the individual systems with no coupling (this is what it
> sounds like you want above).
> If you want to manage everything yourself, and you want to form individual
> systems on every process,
> just create the solvers using a smaller communicator. PETSC_COMM_SELF
> means that every system
> is serial. You can make smaller comms with MPI_Comm_split() if you want
> smaller comms, but some
> parallelism for each system.
>   Thanks,
>      Matt
>> subroutine test_drive_2
>>       implicit none
>> !                    Include files
>> !  This program uses CPP for preprocessing, as indicated by the use of
>> !  PETSc include files in the directory petsc/include/finclude.  This
>> !  convention enables use of the CPP preprocessor, which allows the use
>> !  of the #include statements that define PETSc objects and variables.
>> !  Use of the conventional Fortran include statements is also supported
>> !  In this case, the PETsc include files are located in the directory
>> !  petsc/include/foldinclude.
>> !  Since one must be very careful to include each file no more than once
>> !  in a Fortran routine, application programmers must exlicitly list
>> !  each file needed for the various PETSc components within their
>> !  program (unlike the C/C++ interface).
>> !  See the Fortran section of the PETSc users manual for details.
>> !  The following include statements are required for KSP Fortran programs:
>> !     petscsys.h    - base PETSc routines
>> !     petscvec.h    - vectors
>> !     petscmat.h    - matrices
>> !     petscksp.h    - Krylov subspace methods
>> !     petscpc.h     - preconditioners
>> !  Other include statements may be needed if using additional PETSc
>> !  routines in a Fortran program, e.g.,
>> !     petscviewer.h - viewers
>> !     petscis.h     - index sets
>> ! main includes
>> #include <finclude/petscsys.h>
>> #include <finclude/petscvec.h>
>> #include <finclude/petscmat.h>
>> #include <finclude/petscksp.h>
>> #include <finclude/petscpc.h>
>> ! includes for F90 specific functions
>> #include <finclude/petscvec.h90>
>> #include <finclude/petscmat.h90>
>> #include <finclude/petscksp.h90>
>> #include <finclude/petscpc.h90>
>> !                   Variable declarations
>> !  Variables:
>> !     ksp      - linear solver context
>> !     ksp      - Krylov subspace method context
>> !     pc       - preconditioner context
>> !     x, b, u  - approx solution, right-hand-side, exact solution vectors
>> !     A        - matrix that defines linear system
>> !     its      - iterations for convergence
>> !     norm     - norm of error in solution
>>       Vec              x,b,u
>>       Mat              A
>>       KSP              ksp
>>       PC               pc
>>       PetscReal        norm,tol
>>       PetscErrorCode   ierr
>>       PetscInt         i,n,col(3),its,i1,i2,i3
>>       PetscBool        flg
>>       PetscMPIInt      size,rank
>>       PetscScalar      none,one,value(3), testa
>>       PetscScalar, pointer :: xx_v(:)
>>       PetscScalar, allocatable, dimension(:) :: myx
>>       PetscOffset i_x
>>       !real(4) :: myx(10), myu(10), myb(10)
>>       !real(8), allocatable, dimension(:) :: myx
>>       integer :: ic, nc, ncmax, nz, ncols, j
>>       integer :: fileunit, ione
>>       integer, allocatable, dimension(:,:) :: neighb, cols
>>       integer, allocatable, dimension(:)   :: nnz, vcols
>>       real(8), allocatable, dimension(:,:) :: acoef, vals
>>       real(8), allocatable, dimension(:)   :: ap, su, vvals
>>       character (len=100)                  :: rankstring, filename, folder
>>       real(8) :: atol, rtol, dtol
>>       integer :: mxit, istart, iend
>>       real(8) :: rvar, minvalx
>>       call PetscInitialize(PETSC_NULL_CHARACTER,ierr)
>>       call MPI_Comm_size(PETSC_COMM_WORLD,size,ierr)
>>       call MPI_Comm_rank(PETSC_COMM_WORLD,rank,ierr)
>> !                 Load the linear system
>>       !mbs read data file for experimentation
>>       !if(rank.EQ.0) read(*,'(A)'), folder
>>       folder = '60'
>>       write(rankstring,'(I)'), rank
>>       filename = trim(adjustl(folder)) // '/linearsys_' //
>> trim(adjustl(rankstring)) // '.txt'
>>       fileunit = 9000 + rank
>>       open(unit=fileunit, file=trim(filename))
>>       read(fileunit,*), ncmax
>>       read(fileunit,*),
>>       allocate( neighb(6,ncmax), acoef(6,ncmax), ap(ncmax), su(ncmax) )
>>       allocate( nnz(0:ncmax-1), cols(6,0:ncmax-1), vals(6,0:ncmax-1) )
>>       allocate( vcols(0:ncmax-1), vvals(0:ncmax-1) )
>>       !allocate( xx_v(ncmax), myx(ncmax) )
>>       !allocate( xx_v(0:ncmax), myx(0:ncmax) )
>>       allocate( myx(ncmax) )
>>       do i=1,nc
>>           read(fileunit,'(I)'), ic
>>           read(fileunit,'(6I)'), ( neighb(j,ic), j=1,6 )
>>           read(fileunit,'(6F)'), ( acoef(j,ic), j=1,6 )
>>           read(fileunit,'(2F)'), ap(ic), su(ic)
>>           read(fileunit,*),
>>       enddo
>>       close(fileunit)
>>       nz = 7
>>       nnz = 0
>>       do ic=0,nc-1
>>           ! values for coefficient matrix (diagonal)
>>           nnz(ic) = nnz(ic) + 1
>>           cols(nnz(ic),ic) = ic
>>           vals(nnz(ic),ic) = ap(ic+1)
>>           ! values for coefficient matrix (off diagonal)
>>           do j=1,6
>>               if(neighb(j,ic+1).GT.0)then
>>                   cols(nnz(ic),ic) = neighb(j,ic+1) - 1
>>                   vals(nnz(ic),ic) = acoef(j,ic+1)
>>               endif
>>           enddo
>>           ! values for RHS
>>           vcols(ic) = ic
>>           vvals(ic) = su(ic+1)
>>       enddo
>>       ! add dummy values for remaining rows (if any)
>>       if(ncmax.GT.nc)then
>>           do ic=nc,ncmax-1
>>               ! coeff matrix
>>               nnz(ic) = 1
>>               vals(nnz(ic),ic) = 1.0
>>               ! RHS
>>               vcols(ic) = ic
>>               vvals(ic) = 0.0
>>           enddo
>>       endif
>>       print*, 'rank', rank, 'says nc is', nc
>> !                 Beginning of program
>>       !if (size .ne. 1) then
>>       !   call MPI_Comm_rank(PETSC_COMM_WORLD,rank,ierr)
>>       !   if (rank .eq. 0) then
>>       !      write(6,*) 'This is a uniprocessor example only!'
>>       !   endif
>>       !   SETERRQ(PETSC_COMM_WORLD,1,' ',ierr)
>>       !endif
>>       ione = 1
>>       none = -1.0
>>       one  = 1.0
>>       n    = ncmax
>>       i1 = 1
>>       i2 = 2
>>       i3 = 3
>>       call PetscOptionsGetInt(PETSC_NULL_CHARACTER,'-n',n,flg,ierr)
>> !         Compute the matrix and right-hand-side vector that define
>> !         the linear system, Ax = b.
>> !  Create matrix.  When using MatCreate(), the matrix format can
>> !  be specified at runtime.
>>       call MatCreate(PETSC_COMM_WORLD,A,ierr)
>>       !call MatCreateSeqAij(PETSC_COMM_SELF,A,ierr)
>>       call MatSetSizes(A,PETSC_DECIDE,PETSC_DECIDE,n,n,ierr)
>>       call MatSetFromOptions(A,ierr)
>>       call MatSetUp(A,ierr)
>>       call MatGetOwnershipRange(A,istart,iend,ierr)
>>       print*, rank, istart, iend
>> !  Assemble matrix.
>> !   - Note that MatSetValues() uses 0-based row and column numbers
>> !     in Fortran as well as in C (as set here in the array "col").
>>   !    value(1) = -1.0
>>   !    value(2) = 2.0
>>   !    value(3) = -1.0
>>   !    do 50 i=1,n-2
>>   !       col(1) = i-1
>>   !       col(2) = i
>>   !       col(3) = i+1
>>   !       call MatSetValues(A,i1,i,i3,col,value,INSERT_VALUES,ierr)
>>   !50  continue
>>   !    i = n - 1
>>   !    col(1) = n - 2
>>   !    col(2) = n - 1
>>   !    call MatSetValues(A,i1,i,i2,col,value,INSERT_VALUES,ierr)
>>   !    i = 0
>>   !    col(1) = 0
>>   !    col(2) = 1
>>   !    value(1) = 2.0
>>   !    value(2) = -1.0
>>   !    call MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY,ierr)
>>   !    call MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY,ierr)
>>        do ic=0,ncmax-1
>>            call
>> MatSetValues(A,ione,ic,nnz(ic),cols(1:nnz(ic),ic),vals(1:nnz(ic),ic),INSERT_VALUES,ierr)
>>        enddo
>> !  Create vectors.  Note that we form 1 vector from scratch and
>> !  then duplicate as needed.
>>       call VecCreate(PETSC_COMM_WORLD,x,ierr)
>>       !call VecCreateSeq(PETSC_COMM_SELF,x,ierr)
>>       call VecSetSizes(x,PETSC_DECIDE,n,ierr)
>>       call VecSetFromOptions(x,ierr)
>>       call VecDuplicate(x,b,ierr)
>>       call VecDuplicate(x,u,ierr)
>> !  Set exact solution; then compute right-hand-side vector.
>>       call VecSet(u,one,ierr)
>>       call VecSet(x,one*10,ierr)
>>       !call MatMult(A,u,b,ierr)
>>       ! set source terms vector
>>       call VecSetValues(b,ncmax,vcols,vvals,INSERT_VALUES,ierr)
>>       call VecAssemblyBegin(b,ierr)
>>       call VecAssemblyEnd(b,ierr)
>> !          Create the linear solver and set various options
>> !  Create linear solver context
>>       call KSPCreate(PETSC_COMM_WORLD,ksp,ierr)
>> !  Set operators. Here the matrix that defines the linear system
>> !  also serves as the preconditioning matrix.
>>       call KSPSetOperators(ksp,A,A,DIFFERENT_NONZERO_PATTERN,ierr)
>> !  Set linear solver defaults for this problem (optional).
>> !   - By extracting the KSP and PC contexts from the KSP context,
>> !     we can then directly directly call any KSP and PC routines
>> !     to set various options.
>> !   - The following four statements are optional; all of these
>> !     parameters could alternatively be specified at runtime via
>> !     KSPSetFromOptions();
>>       call KSPGetPC(ksp,pc,ierr)
>>       call PCSetType(pc,PCJACOBI,ierr)
>>       atol = 1.d-12
>>       rtol = 1.d-12
>>       dtol = 1.d10
>>       mxit = 100
>> !      call KSPSetTolerances(ksp,tol,PETSC_DEFAULT_DOUBLE_PRECISION,     &
>> !     &     PETSC_DEFAULT_DOUBLE_PRECISION,PETSC_DEFAULT_INTEGER,ierr)
>>        call KSPSetTolerances(ksp,atol,rtol,dtol,mxit,ierr)
>> !  Set runtime options, e.g.,
>> !      -ksp_type <type> -pc_type <type> -ksp_monitor -ksp_rtol <rtol>
>> !  These options will override those specified above as long as
>> !  KSPSetFromOptions() is called _after_ any other customization
>> !  routines.
>>       call KSPSetFromOptions(ksp,ierr)
>> !                      Solve the linear system
>>       call KSPSetType(ksp,KSPBCGS,ierr)
>>       call KSPSolve(ksp,b,x,ierr)
>> !  View solver info; we could instead use the option -ksp_view
>>       !call KSPView(ksp,PETSC_VIEWER_STDOUT_WORLD,ierr)
>> !                      Check solution and clean up
>>       call VecGetArrayF90(x,xx_v,ierr)
>>       !xx_v = 5.1d0
>>       !do ic=1,ncmax
>>       !    myx(ic) = xx_v(ic)
>>       !enddo
>>       myx = xx_v
>>       !call VecGetArray(x,myx,i_x,ierr)
>>       !value = x_array(i_x + 1)
>>       !call VecRestoreArray(x,myx,i_x,ierr)
>>       !rvar = xx_v(3)
>>       call VecRestoreArrayF90(x,xx_v,ierr)
>>       !call VecGetArrayF90(b,xx_v,ierr)
>>       !myb = xx_v
>>       !call VecRestoreArrayF90(x,xx_v,ierr)
>>       !call VecView(x,PETSC_VIEWER_STDOUT_SELF)
>>       !call MatView(a,PETSC_VIEWER_STDOUT_SELF)
>>       !print*, 'rank', rank, 'says max x is', maxval(myx)
>>      ! print*, xx_v
>> !  Check the error
>>       call MatMult(A,x,u,ierr)
>>       call VecAXPY(u,none,b,ierr)
>>       call VecNorm(u,NORM_2,norm,ierr)
>>       call KSPGetIterationNumber(ksp,its,ierr)
>>       if (norm .gt. 1.e-12) then
>>         write(6,100) norm,its
>>       else
>>         write(6,200) its
>>       endif
>>  100  format('Norm of error = ',e11.4,',  Iterations = ',i5)
>>  200  format('Norm of error < 1.e-12,Iterations = ',i5)
>>       !call KSPGetSolution(ksp,myx)
>>       minvalx = 1.0e15
>>       do ic=1,ncmax
>>           if(myx(ic).LT.minvalx) minvalx = myx(ic)
>>       enddo
>>       !write(*,300), rank, maxval(myx(1:nc)), minvalx
>>       if(rank.EQ.0) print*, myx
>> 300 format('Rank ', I1, ' says max/min x are: ', F12.4, ' / ', F12.4)
>> !  Free work space.  All PETSc objects should be destroyed when they
>> !  are no longer needed.
>>       call VecDestroy(x,ierr)
>>       call VecDestroy(u,ierr)
>>       call VecDestroy(b,ierr)
>>       call MatDestroy(A,ierr)
>>       call KSPDestroy(ksp,ierr)
>>       call PetscFinalize(ierr)
>>       continue
>> end
>> Mohamamd Bahaa ElDin
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140318/15b1a028/attachment-0001.html>
