[petsc-users] How to use command line option for separate matrix
TAY wee-beng
zonexo at gmail.com
Mon Mar 17 09:39:30 CDT 2014
I use
call KSPSetOptionsPrefix(ksp_semi_xyz,"momentum_",ierr)
and
call KSPSetOptionsPrefix(ksp,"poisson_",ierr)
so that I can choose separate ksp/pc options for my momentum and poisson
equations through command line e.g.
-poisson_ksp_type gmres -poisson_pc_type hypre -poisson_pc_type_hypre
boomeramg
In general, I need to use boomeramg as the preconditioner and gmres as
the solver for my poisson eqn, separate from my momentum eqn, which has
its own default pc and ksp. Is the above the correct way?
Thanks!
Yours sincerely,
TAY wee-beng
