[petsc-users] KSPSolve doesn't seem to scale. (Must be doing something wrong...)
Matthew Knepley
knepley at gmail.com
Sat Mar 15 09:15:01 CDT 2014
On Sat, Mar 15, 2014 at 9:08 AM, William Coirier <
William.Coirier at kratosdefense.com> wrote:
> Thanks Karl. We'll check this out on different architectures. I appreciate
> your help!
> Related to all of this, is there an example code in the distribution that
> might be recommended to use for testing machines for scalabiilty? Perhaps
> an example from the KSP?
SNES ex5 is a very simple code and easy to see what is happening on the
architecture. I use it to start. You
can increase the grid size using -da_grid_x M -da_grid_y N.
Matt
> Thanks again...
> Bill C.
> From: Karl Rupp [rupp at iue.tuwien.ac.at]
> Sent: Saturday, March 15, 2014 4:01 AM
> To: William Coirier
> Cc: petsc-users at mcs.anl.gov
> Subject: Re: [petsc-users] KSPSolve doesn't seem to scale. (Must be doing
> something wrong...)
> Hi William,
> I couldn't find something really suspicious in the logs, so the lack of
> scalability may be due to hardware limitations. Did you run all MPI
> processes on the same machine? How many CPU sockets? If it is a
> single-socket machine, chances are good that you saturate the memory
> channels pretty well with one process already. With higher process
> counts the cache per process is reduced, thus reducing cache reuse. This
> is the only reasonable explanation why the execution time for VecMDot
> goes up from e.g. 7 seconds for one and two processes to about 24 for
> four and eight processes.
> I suggest you try to run the same code across multiple machines if
> possible, you should see better scalability there. Also, for
> benchmarking purposes try to replace the ILU preconditioner with e.g.
> Jacobi, this should give you better scalability (provided that the
> solver still converges, of course...)
> Best regards,
> Karli
> On 03/14/2014 10:45 PM, William Coirier wrote:
> > I've written a parallel, finite-volume, transient thermal conduction
> solver using PETSc primitives, and so far things have been going great.
> Comparisons to theory for a simple problem (transient conduction in a
> semi-infinite slab) looks good, but I'm not getting very good parallel
> scaling behavior with the KSP solver. Whether I use the default KSP/PC or
> other sensible combinations, the time spent in KSPSolve seems to not scale
> well at all.
> > I seem to have loaded up the problem well enough. The PETSc
> logging/profiling has been really useful for reworking various code
> segments, and right now, the bottleneck is KSPSolve, and I can't seem to
> figure out how to get it to scale properly.
> > I'm attaching output produced with -log_summary, -info, -ksp_view and
> -pc_view all specified on the command line for 1, 2, 4 and 8 processes.
> > If you guys have any suggestions, I'd definitely like to hear them! And
> I apologize in advance if I've done something stupid. All the documentation
> has been really helpful.
> > Thanks in advance...
> > Bill Coirier
> > ***NOTICE*** This e-mail and/or the attached documents may contain
> technical data within the definition of the International Traffic in Arms
> Regulations and/or Export Administration Regulations, and are subject to
> the export control laws of the U.S. Government. Transfer of this data by
> any means to a foreign person, whether in the United States or abroad,
> without an export license or other approval from the U.S. Department of
> State or Commerce, as applicable, is prohibited. No portion of this e-mail
> or its attachment(s) may be reproduced without written consent of Kratos
> Defense & Security Solutions, Inc. Any views expressed in this message are
> those of the individual sender, except where the message states otherwise
> and the sender is authorized to state them to be the views of any such
> entity. The information contained in this message and or attachments is
> intended only for the person or entity to which it is addressed and may
> contain confidential and/or privileged material. If you
> are not the intended recipient or believe that you may have received this
> document in error, please notify the sender and delete this e-mail and any
> attachments immediately.
> contain confidential and/or privileged material. If you are not the
> intended recipient or believe that you may have received this document in
> error, please notify the sender and delete this e-mail and any attachments
> immediately.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140315/3b33e6a7/attachment.html>
