[petsc-users] Extra Variable in DMCircuit
Florian Meier
florian.meier at koalo.de
Fri Mar 14 07:00:27 CDT 2014
Seen from that perspective it is reasonable to add a further vertex,
thank you!
I have implemented that and it works very good.
Regarding the scalability: My previous approach was to do binary search
and running the calculation multiple times with a different constant
parameter, so this is much faster anyway :-)
Greetings,
Florian
On 03/14/2014 11:44 AM, Matthew Knepley wrote:
> On Fri, Mar 14, 2014 at 4:13 AM, Florian Meier <florian.meier at koalo.de
> <mailto:florian.meier at koalo.de>> wrote:
> Hi,
> I got quite far with my project, although I still have not managed (or
> better "have not tried...") to get the parallelization running (Shri:
> Any news about that?).
> Now I would like to add a single global variable (and a single equation)
> to the equation system. Is there an elegant way to do this with
> DMCircuit?
> A hackish solution might be to add an additional imaginary vertex that
> is excluded from all other calculations, but that does not seem to be
> the right way to do it.
> The graph expresses the influence of variables on each other, so if you have
> a globally coupled variable, then a node linked to all other nodes is the
> appropriate structure.
> The problem is that this is not scalable since it will result in a
> dense row. I
> would do this for now. And when your problem is large enough for this to
> be a drag on scalability (thousands of processes), switch to specialized
> code.
> Matt
> Greetings,
> Florian
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
