[petsc-users] Rescaling quantites to remove positivity constraints
Mani Chandra mc0710 at gmail.com
Thu Mar 13 21:08:32 CDT 2014
On Thu, Mar 13, 2014 at 8:51 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Mar 13, 2014 at 6:12 PM, Mani Chandra <mc0710 at gmail.com> wrote:
>> Hi,
>> I'm trying to solve for fluid flows with large density and pressure
>> variations using the theta method in the TS module. This inevitably leads
>> to negative densities and pressures during the course of the evolution. In
>> order to deal with this, I am trying to now solve for log(rho) and log(P)
>> instead of rho and P. In order to do this, I changed my initial conditions
>> for rho and P to log(rho) and log(P) and inside the residual evaluation
>> function I keep the original code unchanged expect that I add the following
>> lines above the original code:
>> rho = exp(logrho)
>> P = exp(logP)
> You must d your scaling such that the output of your residual is log() of
> your variables. If that is the case, it
> will work.
Could you elaborate a bit? I didn't understand that. I thought that as long
as the residuals are the same, one can solve for any forms of the
variables.
> since I expect the solution vector x[j][i] to now have logrho and logP
>> instead of rho and  P. I now run the simulation with a modified newton
>> krylov method and lag the jacobian for every 100 linear solves. The
>> jacobian assembly is using colored finite differences. This goes smoothly
>> from the point I start the simulation to the first 100 linear solves after
>> which it needs to assemble the jacobian again. At this point the nonlinear
>> solver crashes and I think something is wrong with the jacobian assembly. I
>> checked that the simulation runs till it has to assemble the jacobian the
>> second time by varying the lagging by say 10, 20, 30, ... It fails
>> everytime it has to assemble the second time.
>>  When I view the solution using VecView inside TSMonitor during the time
>> elasped when the simulation ran, the initial conditions are log(rho) and
>> log(P) but the output of the vector actually has rho and P and not log(rho)
>> and log(P) which I expect the solver to be solving for. However when I look
>> at the .vts files generated by -ts_monitor_solution_vtk, the output is
>> log(rho) and log(P).
>> Should I be doing something else in order to rescale the quantities that
>> TS/SNES should solve for instead of what I did above?
>> The method suggesting that one rescales is described in this paper:
>> "A newton-krylov solver for implicit solution of hydrodynamics in
>> core-collapse supernova"
>> http://iopscience.iop.org/1742-6596/125/1/012085/pdf/1742-6596_125_1_012085.pdf
> I personally think this is a bad idea. They must have guesses that are
> very close to the solutions, and
> it messes with the accuracy of the discretization.
> I tried other things like setting floors, but they fail. Any suggestions?
>   Thanks,
>      Matt
> P.S I also tried the variational inequality SNES solver a while back but
>> it didn't really work in enforcing the constraints.
>> Thanks,
>> Mani
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140313/868f97f5/attachment.html>
