[petsc-users] petsc configuer time
Dharmendar Reddy
dharmareddy84 at gmail.com
Thu Mar 13 18:12:17 CDT 2014
I was suspecting python may be the cause,
I am using: Enthought Canopy Python 2.7.3 | 64-bit | (default, Aug 8
2013, 05:43:23)
I will try other approaches.
Thanks
Reddy
On Thu, Mar 13, 2014 at 6:04 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> Hm - configure should first print the 'executing' message - and then
> run the command.
> If its hanging at 'pusing language' message - I'm not sure what the
> cause is.
> Perhaps the python stdout-buffer-flush is off-sync. [and its icc/ifort
> thats hanging]. Or there is a problem with python on this machine?
> 2 things you can try to confirm.
> 1. run configure with gcc/gfortran and see if thats quicker.
> If so - then intel compilers are the cause for slowdown.
> 2. Try configure with the option --useThreads=0 and see if this makes a difference.
> [or tray a different python]
> Satish
> On Thu, 13 Mar 2014, Dharmendar Reddy wrote:
>> I see that at every pushing language, the screen statys there for a
>> while and the compile execute commands quickly appear and go....
>> On Thu, Mar 13, 2014 at 4:23 PM, Balay, Satish <balay at mcs.anl.gov> wrote:
>> > You can try " tail -f configure.log" to see where its hanging during the
>> > run
>> > Intel compilers can hang waiting for response from license server.
>> > Satish
>> > ________________________________
>> > From: Dharmendar Reddy
>> > Sent: 3/13/2014 2:03 PM
>> > To: Smith, Barry F.
>> > Cc: PETSc users list
>> > Subject: Re: [petsc-users] petsc configuer time
>> > Yes, my home directory is mounted on nfs. And i have configured and
>> > installed petsc many times on my laptop and TACC stampede (which also
>> > has my home directory mounted on network file system). But the
>> > particular computer that i am working on now has been extremely slow
>> > when it comes to petsc configure. Any suggestions on how i can fix
>> > this ? I do not have a choice of not having my home on nfs.
>> > Otherwise, i do not see big disk i/o impact even when i visualize
>> > large ( > 100 MB ) files for visualization.
>> > On Thu, Mar 13, 2014 at 3:55 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> >> The long time is pretty much always due to a slow file system (it takes
>> >> about 3 minutes with my laptop using the local disk) but on a desktop
>> >> machine using a network file system it can take up to 20 minutes. We
>> >> generally always build on a local disk; since disk space is so cheap now
>> >> pretty much any machine has gigabytes free of disk space that you can use to
>> >> build on.
>> >> I think two hours is totally unacceptably long. What type of system are
>> >> you building on and where is the file system? My guess is /home/reddy is off
>> >> on some slow filesystem away from the machine you are compiling on.
>> >> Barry
>> >> On Mar 13, 2014, at 3:29 PM, Dharmendar Reddy <dharmareddy84 at gmail.com>
>> >> wrote:
>> >>> Hello,
>> >>> How long does it take to configure petsc ? I understand that
>> >>> it depends on the options, but i am find the particular version i have
>> >>> is taking very long time (nearly 2 hours) before it begins configuring
>> >>> packages.
>> >>> I am using intel MPI and intel compilers.
>> >>> I am using the following config opts:
>> >>> PETSC_VERSION = petsc-3.4.3
>> >>> MPICC=mpiicc
>> >>> MPIF90=mpiifort
>> >>> MPICXX=mpiicpc
>> >>> COMPILERS = --with-cc="$(MPICC)" --with-fc="$(MPIF90)"
>> >>> --with-cxx="$(MPICXX)" COPTFLAGS="$(O_LEVEL)" CXXOPTFLAGS="$(O_LEVEL)"
>> >>> FOPTFLAGS="$(O_LEVEL)"
>> >>> # COMPILERS = --with-mpi-dir=$(MPI_HOME)
>> >>> BLAS_LAPACK = $(PETSC_BLAS_LAPACK_DIR)
>> >>> PETSCExtPackagePath = /home/reddy/libs/petsc
>> >>> METISPATH=$(PETSCExtPackagePath)/metis-5.0.2-p3.tar.gz
>> >>> MUMPSPATH=$(PETSCExtPackagePath)/MUMPS_4.10.0-p3.tar.gz
>> >>> PARMETISPATH=$(PETSCExtPackagePath)/parmetis-4.0.2-p5.tar.gz
>> >>> SUPERLUPATH=$(PETSCExtPackagePath)/superlu_dist_3.3.tar.gz
>> >>> SCALPACKINC=$(MKLHOME)/include
>> >>> SCALPACKLIB="$(MKLROOT)/lib/intel64/libmkl_scalapack_lp64.a
>> >>> -Wl,--start-group $(MKLROOT)/lib/intel64/libmkl_intel_lp64.a
>> >>> $(MKLROOT)/lib/intel64/libmkl_core.a
>> >>> $(MKLROOT)/lib/intel64/libmkl_sequential.a -Wl,--end-group
>> >>> $(MKLROOT)/lib/intel64/libmkl_blacs_intelmpi_lp64.a -lpthread -lm"
>> >>> #BLACSINC=$(MKLHOME)/include
>> >>> #BLACSLIB=$(MKLHOME)/lib/intel64/libmkl_blacs_intelmpi_lp64.a
>> >>> confOptsCommon = --with-x=0 --with-make-np=12 --with-hdf5
>> >>> --with-hdf5-dir=$(HDF5_DIR) --with-single-library=0 --with-pic=1
>> >>> --with-shared-libraries=0 --with-blas-lapack-dir=$(BLAS_LAPACK)
>> >>> --with-clanguage=C++ --with-fortran --with-debugging=1 $(COMPILERS)
>> >>> --download-metis=$(METISPATH) --download-parmetis=$(PARMETISPATH)
>> >>> --download-superlu_dist=$(SUPERLUPATH) --download-mumps=$(MUMPSPATH)
>> >>> --with-scalapack-include=$(SCALPACKINC)
>> >>> --with-scalapack-lib=$(SCALPACKLIB)
>> >>> #--with-blacs-include=$(BLACSINC) --with-blacs-lib=$(BLACSLIB)
>> >>> ### configure command
>> >>> ./configure --with-scalar-type=real $(confOptsCommon)
