[petsc-users] Null spaces with fieldsplit preconditioning
Wed Mar 12 07:10:08 CDT 2014
On Wed, Mar 12, 2014 at 6:44 AM, Lawrence Mitchell <
lawrence.mitchell at imperial.ac.uk> wrote:
> Hello,
> I have a mixed FEM system, for which the null space is constant
> functions in one of the sub spaces.  That is, I have W = V * Q and the
> null space is a constant function in Q (and zero in V).  If I assemble
> the operator, I get a block structure:
> X = [A B,
>      C D]
> When I solve this monolithically, I project the null space out by
> attaching it to X.  However, if I use Schur complement preconditioning,
> then S = D - C Ainv B has a null space of the constant functions as
> well.  Do I therefore need to attach null spaces to both X and S in this
> case, or will attaching it to X be enough?  If I do need to hang
> something on S, is there an easy way to do it?
Here are two ways to do this, depending on how you manage your fields. At
the
lowest level, an IS defines the field in PCFIELDSPLIT. So you can attach
your
MatNullSpace that way
  PetscObjectCompose(isD, "nullspace", nullspace)
of if you use a DM, you can say
  DMGetField(dm, 1, &obj);
  PetscObjectCompose(obj, "nullspace", nullspace)
This is also how we pass in "nearsullspace" for AMG, and "pmat" for a
separate
preconditioning operator.
     Matt
Cheers,
> Lawrence
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140312/fb43fff6/attachment.html>
