[petsc-users] snes + matrix free + coloring
Jed Brown
jed at jedbrown.org
Fri Mar 7 17:56:18 CST 2014
"Zou (Non-US), Ling" <ling.zou at inl.gov> writes:
> Hi Jed,
> I was searching a topic on preconditioning in the mail list and found this
> email.
> On Wed, Oct 10, 2012 at 2:55 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> Then you aren't using a matrix-free method at all.
> In case of using SNESDefaultComputeJacobianColor to compute Jacobian matrix
> and mf_operator command, is this exactly what you are describing ('aren't
> using a matrix-free method at all')?
> The SNESDefaultComputeJacobianColor I found in lines 149-155 from
> http://www.mcs.anl.gov/petsc/petsc-2.3.3/src/snes/examples/tutorials/ex5.c.html
1. Please upgrade PETSc. I don't think we have any links to these
antique man pages, so I assume you specifically changed the version
number back rather than landing there accidentally.
2. It is NOT a matrix-free method because coloring is used to assemble
the matrix. It usually doesn't make sense to assemble a matrix using
coloring, but then not use it to apply the matrix (-snes_mf_operator
only uses the assembled matrix for preconditioning).
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140307/0070fafc/attachment.pgp>
