[petsc-users] Is it possible to use -snes_ksp_ew in the framework of KSP?
Matthew Knepley
knepley at gmail.com
Fri Mar 7 13:39:52 CST 2014
On Fri, Mar 7, 2014 at 1:21 PM, Song Gao <song.gao2 at mail.mcgill.ca> wrote:
> Hello,
> We are working on a legacy codes which solves the NS equations. The codes
> take control of newton iterations itself and use KSP to solve the linear
> system.
> We modified the codes, used SNES to control the newton iteration and
> changed the code to matrix free fashion. But the legacy codes did a lot of
> other things between two newton iterations (such as output solution, update
> variables....). I know we could use linesearchpostcheck but it is
> difficulty to do that correctly. Therefore, we decide to go back to the KSP
> framework but still use matrix free.
What makes it difficult?
Matt
> When using SNES, we always use the runtime option -snes_ksp_ew, we observe
> that for some test cases, the residual stalls without -snes_ksp_ew, but
> converges with-snes_ksp_ew. So I'm thinking if it is possible to
> use -snes_ksp_ew in KSP? Thanks in advance.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140307/bec63073/attachment.html>
