[petsc-users] having issues with nullspace
Thu Mar 6 17:57:30 CST 2014
On Thu, Mar 6, 2014 at 5:49 PM, Mohammad Mirzadeh <mirzadeh at gmail.com>wrote:
> Matt,
1) Use -ksp_monitor_true_residual
2) Quit using Hypre. It can easily get rank deficient stuff on its coarse
grid, which throws off this analysis.
    Use SOR if it converges, otherwise use -pc_type svd
   Matt
here's the output:
>   0 KSP Residual norm 3.033840960250e+02
>   1 KSP Residual norm 1.018974811826e+01
>   2 KSP Residual norm 5.450493684941e-02
>   3 KSP Residual norm 3.944064039516e-02
>   4 KSP Residual norm 6.286181172600e-05
>   5 KSP Residual norm 4.349133658643e-06
>   6 KSP Residual norm 9.279429568232e-08
>   7 KSP Residual norm 3.032522248740e-09
>   8 KSP Residual norm 6.533747246875e-09
>   9 KSP Residual norm 6.083185162500e-12
> Linear solve converged due to CONVERGED_RTOL iterations 9
> KSP Object: 1 MPI processes
>   type: bcgs
>   maximum iterations=10000, initial guess is zero
>   tolerances:  relative=1e-12, absolute=1e-50, divergence=10000
>   left preconditioning
>   has attached null space
>   using PRECONDITIONED norm type for convergence test
> PC Object: 1 MPI processes
>   type: hypre
>     HYPRE BoomerAMG preconditioning
>     HYPRE BoomerAMG: Cycle type V
>     HYPRE BoomerAMG: Maximum number of levels 25
>     HYPRE BoomerAMG: Maximum number of iterations PER hypre call 1
>     HYPRE BoomerAMG: Convergence tolerance PER hypre call 0
>     HYPRE BoomerAMG: Threshold for strong coupling 0.5
>     HYPRE BoomerAMG: Interpolation truncation factor 0
>     HYPRE BoomerAMG: Interpolation: max elements per row 0
>     HYPRE BoomerAMG: Number of levels of aggressive coarsening 0
>     HYPRE BoomerAMG: Number of paths for aggressive coarsening 1
>     HYPRE BoomerAMG: Maximum row sums 0.9
>     HYPRE BoomerAMG: Sweeps down         1
>     HYPRE BoomerAMG: Sweeps up           1
>     HYPRE BoomerAMG: Sweeps on coarse    1
>     HYPRE BoomerAMG: Relax down          symmetric-SOR/Jacobi
>     HYPRE BoomerAMG: Relax up            symmetric-SOR/Jacobi
>     HYPRE BoomerAMG: Relax on coarse     symmetric-SOR/Jacobi
>     HYPRE BoomerAMG: Relax weight  (all)      1
>     HYPRE BoomerAMG: Outer relax weight (all) 1
>     HYPRE BoomerAMG: Using CF-relaxation
>     HYPRE BoomerAMG: Measure type        local
>     HYPRE BoomerAMG: Coarsen type        Falgout
>     HYPRE BoomerAMG: Interpolation type  classical
>   linear system matrix = precond matrix:
>   Mat Object:   1 MPI processes
>     type: seqaij
>     rows=263169, cols=263169
>     total: nonzeros=1236141, allocated nonzeros=1244417
>     total number of mallocs used during MatSetValues calls =0
>       not using I-node routines
> On Thu, Mar 6, 2014 at 3:43 PM, Jed Brown <jed at jedbrown.org> wrote:
>> Mohammad Mirzadeh <mirzadeh at gmail.com> writes:
>> > Yes. To be precise this is the set of functions I call:
>> > ierr = MatNullSpaceCreate(mpicomm, PETSC_FALSE, 1, &null_space,
>> > &A_null_space); CHKERRXX(ierr);
>> > ierr = MatSetNullSpace(A, A_null_space); CHKERRXX(ierr);
>> > ierr = KSPSetNullSpace(ksp, A_null_space); CHKERRXX(ierr);
>> > ierr = MatNullSpaceRemove(A_null_space, rhs_, NULL); CHKERRXX(ierr);
>> Is the matrix symmetric?  If not, the right and left null spaces could
>> be different, in which case this system might be inconsistent.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140306/6826c894/attachment-0001.html>
