[petsc-users] having issues with nullspace
Mohammad Mirzadeh
mirzadeh at gmail.com
Thu Mar 6 17:50:55 CST 2014
Jed,
No the matrix is actually non-symmetric due to grid adaptivity (hanging
nodes of QuadTree). Anyway, what do you exactly mean by the system being
inconsistent?
On Thu, Mar 6, 2014 at 3:49 PM, Mohammad Mirzadeh <mirzadeh at gmail.com>wrote:
> Matt,
> here's the output:
> 0 KSP Residual norm 3.033840960250e+02
> 1 KSP Residual norm 1.018974811826e+01
> 2 KSP Residual norm 5.450493684941e-02
> 3 KSP Residual norm 3.944064039516e-02
> 4 KSP Residual norm 6.286181172600e-05
> 5 KSP Residual norm 4.349133658643e-06
> 6 KSP Residual norm 9.279429568232e-08
> 7 KSP Residual norm 3.032522248740e-09
> 8 KSP Residual norm 6.533747246875e-09
> 9 KSP Residual norm 6.083185162500e-12
> Linear solve converged due to CONVERGED_RTOL iterations 9
> KSP Object: 1 MPI processes
> type: bcgs
> maximum iterations=10000, initial guess is zero
> tolerances: relative=1e-12, absolute=1e-50, divergence=10000
> left preconditioning
> has attached null space
> using PRECONDITIONED norm type for convergence test
> PC Object: 1 MPI processes
> type: hypre
> HYPRE BoomerAMG preconditioning
> HYPRE BoomerAMG: Cycle type V
> HYPRE BoomerAMG: Maximum number of levels 25
> HYPRE BoomerAMG: Maximum number of iterations PER hypre call 1
> HYPRE BoomerAMG: Convergence tolerance PER hypre call 0
> HYPRE BoomerAMG: Threshold for strong coupling 0.5
> HYPRE BoomerAMG: Interpolation truncation factor 0
> HYPRE BoomerAMG: Interpolation: max elements per row 0
> HYPRE BoomerAMG: Number of levels of aggressive coarsening 0
> HYPRE BoomerAMG: Number of paths for aggressive coarsening 1
> HYPRE BoomerAMG: Maximum row sums 0.9
> HYPRE BoomerAMG: Sweeps down 1
> HYPRE BoomerAMG: Sweeps up 1
> HYPRE BoomerAMG: Sweeps on coarse 1
> HYPRE BoomerAMG: Relax down symmetric-SOR/Jacobi
> HYPRE BoomerAMG: Relax up symmetric-SOR/Jacobi
> HYPRE BoomerAMG: Relax on coarse symmetric-SOR/Jacobi
> HYPRE BoomerAMG: Relax weight (all) 1
> HYPRE BoomerAMG: Outer relax weight (all) 1
> HYPRE BoomerAMG: Using CF-relaxation
> HYPRE BoomerAMG: Measure type local
> HYPRE BoomerAMG: Coarsen type Falgout
> HYPRE BoomerAMG: Interpolation type classical
> linear system matrix = precond matrix:
> Mat Object: 1 MPI processes
> type: seqaij
> rows=263169, cols=263169
> total: nonzeros=1236141, allocated nonzeros=1244417
> total number of mallocs used during MatSetValues calls =0
> not using I-node routines
> On Thu, Mar 6, 2014 at 3:43 PM, Jed Brown <jed at jedbrown.org> wrote:
>> Mohammad Mirzadeh <mirzadeh at gmail.com> writes:
>> > Yes. To be precise this is the set of functions I call:
>> > ierr = MatNullSpaceCreate(mpicomm, PETSC_FALSE, 1, &null_space,
>> > &A_null_space); CHKERRXX(ierr);
>> > ierr = MatSetNullSpace(A, A_null_space); CHKERRXX(ierr);
>> > ierr = KSPSetNullSpace(ksp, A_null_space); CHKERRXX(ierr);
>> > ierr = MatNullSpaceRemove(A_null_space, rhs_, NULL); CHKERRXX(ierr);
>> Is the matrix symmetric? If not, the right and left null spaces could
>> be different, in which case this system might be inconsistent.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140306/3269a8bf/attachment.html>
