[petsc-users] DMDA Global vs Local indexing
Jed Brown
jed at jedbrown.org
Thu Mar 6 10:01:29 CST 2014
Mark Lohry <mlohry at gmail.com> writes:
> As a PETSc developer, of course, I would recommend keeping your
> local/temporary data also in Vecs and using the
> DMDAVecGetArray() for access to those also and having all code
> written in the “local patch style” with loops i=gxs; i<gxs+gxm
> I think the code is clearer and easier to reason about than
> having each process from 0 to vxm etc.
> Yeah, I definitely see the attraction and I may ultimately go that
> route. As a non-PETSc developer however, it seems preferable to
> absolutely minimize the reliance on PETSc data management for code
> re-use in a non-PETSc application going forward. I'd be eager to hear
> from other devs on how they approach this.
Note that using a DMDA for this auxiliary data means you can restrict
and interpolate it through a hierarchy, as well as visualize it.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140306/f9e0a3be/attachment.pgp>
