[petsc-users] DMDA questions
Xiangdong epscodes at gmail.com
Wed Mar 5 13:16:33 CST 2014
Yes, I am using DMDA. I looked at the DM index page with keywords *coarsen*,
but did not realize that *interpolation* is the key word to search. Thanks
pointing out.
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DM/index.html
Xiangdong
On Wed, Mar 5, 2014 at 1:57 PM, Jed Brown <jed at jedbrown.org> wrote:
> Xiangdong <epscodes at gmail.com> writes:
> > If I first define a DM, and obtain the solution vector on this DM
> (through
> > non multigrid method).  However, given that this DM is so fine, I may
> only
> > need to save/view the solution on a coarsen grid. Is there some functions
> > available in petsc for this instead of writing my own vec scatter?
> Where did you try searching and what terms did you try before asking?
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DM/DMCoarsen.html
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DM/DMCreateInterpolation.html
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DM/DMCreateInjection.html
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140305/d3fcb2e5/attachment.html>
