[petsc-users] Problems running ex12.c
Tue Mar 4 12:01:28 CST 2014
On Tue, Mar 4, 2014 at 11:51 AM, Miguel Angel Salazar de Troya <
salazardetroya at gmail.com> wrote:
> I can run it now, thanks. Although if I run it with valgrind 3.5.0 (should
> I update to the last version?) I get some memory leaks related with the
> function DMPlexCreateBoxMesh.
I will check it out.
     Matt
> [salaza11 at maya tutorials]$ valgrind --leak-check=full ./ex12 -run_type
> test -refinement_limit 0.0    -bc_type dirichlet -interpolate 0
> -petscspace_order 1 -show_initial -dm_plex_print_fem 1
> ==9625== Memcheck, a memory error detector
> ==9625== Copyright (C) 2002-2009, and GNU GPL'd, by Julian Seward et al.
> ==9625== Using Valgrind-3.5.0 and LibVEX; rerun with -h for copyright info
> ==9625== Command: ./ex12 -run_type test -refinement_limit 0.0 -bc_type
> dirichlet -interpolate 0 -petscspace_order 1 -show_initial
> ==9625==
> Local function:
> Vec Object: 1 MPI processes
>   type: seq
> 0
> 0.25
> 1
> 0.25
> 0.5
> 1.25
> 1
> 1.25
> 2
> Initial guess
>   type: seq
> 0.5
> L_2 Error: 0.111111
> Residual:
>   type: seq
> 0
> 0
> 0
> 0
> 0
> 0
> 0
> 0
> 0
> Initial Residual
>   type: seq
> 0
> L_2 Residual: 0
> Jacobian:
> Mat Object: 1 MPI processes
>   type: seqaij
> row 0: (0, 4)
> Residual:
>   type: seq
> 0
> 0
> 0
> 0
> -2
> 0
> 0
> 0
> 0
> Au - b = Au + F(0)
>   type: seq
> 0
> Linear L_2 Residual: 0
> ==9625==
> ==9625== HEAP SUMMARY:
> ==9625==     in use at exit: 288 bytes in 3 blocks
> ==9625==   total heap usage: 2,484 allocs, 2,481 frees, 1,009,287 bytes
> allocated
> ==9625==
> ==9625== 48 bytes in 1 blocks are definitely lost in loss record 1 of 3
> ==9625==    at 0x4A05E46: malloc (vg_replace_malloc.c:195)
> ==9625==    by 0x5D8D4E1: writepoly (triangle.c:12012)
> ==9625==    by 0x5D8FAAC: triangulate (triangle.c:13167)
> ==9625==    by 0x56B0884: DMPlexGenerate_Triangle (plex.c:3749)
> ==9625==    by 0x56B5EE4: DMPlexGenerate (plex.c:4503)
> ==9625==    by 0x567F414: DMPlexCreateBoxMesh (plexcreate.c:668)
> ==9625==    by 0x4051FA: CreateMesh (ex12.c:341)
> ==9625==    by 0x408D3D: main (ex12.c:651)
> ==9625==
> ==9625== 96 bytes in 1 blocks are definitely lost in loss record 2 of 3
> ==9625==    by 0x5D8D485: writepoly (triangle.c:12004)
> ==9625==
> ==9625== 144 bytes in 1 blocks are definitely lost in loss record 3 of 3
> ==9625==    by 0x5D8CD20: writenodes (triangle.c:11718)
> ==9625==    by 0x5D8F9DE: triangulate (triangle.c:13132)
> ==9625==
> ==9625== LEAK SUMMARY:
> ==9625==    definitely lost: 288 bytes in 3 blocks
> ==9625==    indirectly lost: 0 bytes in 0 blocks
> ==9625==      possibly lost: 0 bytes in 0 blocks
> ==9625==    still reachable: 0 bytes in 0 blocks
> ==9625==         suppressed: 0 bytes in 0 blocks
> ==9625==
> ==9625== For counts of detected and suppressed errors, rerun with: -v
> ==9625== ERROR SUMMARY: 3 errors from 3 contexts (suppressed: 6 from 6)
> On Mon, Mar 3, 2014 at 7:05 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Mon, Mar 3, 2014 at 4:59 PM, Miguel Angel Salazar de Troya <
>>> You are welcome, thanks for your help.
>> Okay, I have rebuilt completely clean, and ex12 runs for me. Can you try
>> again after pulling?
>>   Thanks,
>>      Matt
>>> On Mon, Mar 3, 2014 at 4:13 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>> On Mon, Mar 3, 2014 at 1:44 PM, Miguel Angel Salazar de Troya <
>>>>> Thanks. This is what I get.
>>>> Okay, this was broken by a new push to master/next in the last few
>>>> days. I have pushed a fix,
>>>> however next is currently broken due to a failure to check in a file.
>>>> This should be fixed shortly,
>>>> and then ex12 will work. I will mail you when its ready.
>>>>   Thanks for finding this,
>>>>       Matt
>>>>> (gdb) cont
>>>>> Continuing.
>>>>> Program received signal SIGSEGV, Segmentation fault.
>>>>> 0x00007fd6811bea7b in DMPlexComputeJacobianFEM (dm=0x159a180,
>>>>> X=0x168b5b0,
>>>>>     Jac=0x7fffae6e8a88, JacP=0x7fffae6e8a88, str=0x7fffae6e7970,
>>>>>     user=0x7fd6811be509)
>>>>>     at /home/salaza11/petsc/src/dm/impls/plex/plexfem.c:882
>>>>> 882         ierr = PetscFEGetDimension(fe[f], &Nb);CHKERRQ(ierr);
>>>>> (gdb) where
>>>>> #0  0x00007fd6811bea7b in DMPlexComputeJacobianFEM (dm=0x159a180,
>>>>> X=0x168b5b0,
>>>>> #1  0x00007fd6814a5bf6 in SNESComputeJacobian_DMLocal (snes=0x14e9450,
>>>>>     X=0x1622ad0, A=0x7fffae6e8a88, B=0x7fffae6e8a88, ctx=0x1652300)
>>>>>     at /home/salaza11/petsc/src/snes/utils/dmlocalsnes.c:102
>>>>> #2  0x00007fd6814cc609 in SNESComputeJacobian (snes=0x14e9450,
>>>>> X=0x1622ad0,
>>>>>     A=0x7fffae6e8a88, B=0x7fffae6e8a88)
>>>>>     at /home/salaza11/petsc/src/snes/interface/snes.c:2245
>>>>> #3  0x000000000040af72 in main (argc=15, argv=0x7fffae6e8bc8)
>>>>>     at /home/salaza11/petsc/src/snes/examples/tutorials/ex12.c:784
>>>>> On Mon, Mar 3, 2014 at 1:40 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>> On Mon, Mar 3, 2014 at 1:39 PM, Miguel Angel Salazar de Troya <
>>>>>>> This is what I get at gdb when I type 'where'.
>>>>>> You have to type 'cont', and then when it fails you type 'where'.
>>>>>>    Matt
>>>>>>> #0  0x000000310e0aa860 in __nanosleep_nocancel () from
>>>>>>> /lib64/libc.so.6
>>>>>>> #1  0x000000310e0aa70f in sleep () from /lib64/libc.so.6
>>>>>>> #2  0x00007fd83a00a8be in PetscSleep (s=10)
>>>>>>>     at /home/salaza11/petsc/src/sys/utils/psleep.c:52
>>>>>>> #3  0x00007fd83a06f331 in PetscAttachDebugger ()
>>>>>>>     at /home/salaza11/petsc/src/sys/error/adebug.c:397
>>>>>>> #4  0x00007fd83a0af1d2 in PetscOptionsCheckInitial_Private ()
>>>>>>>     at /home/salaza11/petsc/src/sys/objects/init.c:444
>>>>>>> #5  0x00007fd83a0b6448 in PetscInitialize (argc=0x7fff5cd8df2c,
>>>>>>>     args=0x7fff5cd8df20, file=0x0,
>>>>>>>     help=0x60ce40 "Poisson Problem in 2d and 3d with simplicial
>>>>>>> finite elements.\nWe solve the Poisson problem in a rectangular\ndomain,
>>>>>>> using a parallel unstructured mesh (DMPLEX) to discretize it.\n\n\n")
>>>>>>>     at /home/salaza11/petsc/src/sys/objects/pinit.c:876
>>>>>>> #6  0x0000000000408f2c in main (argc=15, argv=0x7fff5cd8f1f8)
>>>>>>>     at /home/salaza11/petsc/src/snes/examples/tutorials/ex12.c:663
>>>>>>> The rest of the gdb output is attached. I am a bit ignorant with
>>>>>>> gdb, I apologize for that.
>>>>>>> On Mon, Mar 3, 2014 at 12:48 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>>>> On Mon, Mar 3, 2014 at 12:39 PM, Miguel Angel Salazar de Troya <
>>>>>>>>> Thanks for your response. Sorry I did not have the "next" version,
>>>>>>>>> but the "master" version. I still have an error though. I followed the
>>>>>>>>> steps given here (https://bitbucket.org/petsc/petsc/wiki/Home) to
>>>>>>>>> obtain the next version, I configured petsc as above and ran ex12 as above
>>>>>>>>> as well, getting this error:
>>>>>>>>> [salaza11 at maya tutorials]$ ./ex12 -run_type test
>>>>>>>>> Local function:
>>>>>>>>>   type: seq
>>>>>>>>> 0
>>>>>>>>> 0.25
>>>>>>>>> 1
>>>>>>>>> 0.25
>>>>>>>>> 0.5
>>>>>>>>> 1.25
>>>>>>>>> 1
>>>>>>>>> 1.25
>>>>>>>>> 2
>>>>>>>>> Initial guess
>>>>>>>>>   type: seq
>>>>>>>>> 0.5
>>>>>>>>> L_2 Error: 0.111111
>>>>>>>>> Residual:
>>>>>>>>>   type: seq
>>>>>>>>> 0
>>>>>>>>> 0
>>>>>>>>> 0
>>>>>>>>> 0
>>>>>>>>> 0
>>>>>>>>> 0
>>>>>>>>> 0
>>>>>>>>> 0
>>>>>>>>> 0
>>>>>>>>> Initial Residual
>>>>>>>>>   type: seq
>>>>>>>>> 0
>>>>>>>>> L_2 Residual: 0
>>>>>>>> Okay, now run with -start_in_debugger, and give me a stack trace
>>>>>>>> using 'where'.
>>>>>>>>   Thanks,
>>>>>>>>      Matt
>>>>>>>>>  [0]PETSC ERROR:
>>>>>>>>> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation
>>>>>>>>> Violation, probably memory access out of range
>>>>>>>>> [0]PETSC ERROR: Try option -start_in_debugger or
>>>>>>>>> -on_error_attach_debugger
>>>>>>>>> [0]PETSC ERROR: or see
>>>>>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[0]PETSCERROR: or try
>>>>>>>>> http://valgrind.org on GNU/linux and Apple Mac OS X to find
>>>>>>>>> memory corruption errors
>>>>>>>>> [0]PETSC ERROR: likely location of problem given in stack below
>>>>>>>>> [0]PETSC ERROR: ---------------------  Stack Frames
>>>>>>>>> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>>>>>>>>> available,
>>>>>>>>> [0]PETSC ERROR:       INSTEAD the line number of the start of the
>>>>>>>>> function
>>>>>>>>> [0]PETSC ERROR:       is given.
>>>>>>>>> [0]PETSC ERROR: [0] DMPlexComputeJacobianFEM line 871
>>>>>>>>>  [0]PETSC ERROR: [0] SNESComputeJacobian_DMLocal line 94
>>>>>>>>> [0]PETSC ERROR: [0] SNES user Jacobian function line 2244
>>>>>>>>> [0]PETSC ERROR: [0] SNESComputeJacobian line 2203
>>>>>>>>> [0]PETSC ERROR: --------------------- Error Message
>>>>>>>>> [0]PETSC ERROR: Signal received
>>>>>>>>> [0]PETSC ERROR: See http://
>>>>>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
>>>>>>>>> shooting.
>>>>>>>>>  [0]PETSC ERROR: Petsc Development GIT revision:
>>>>>>>>> v3.4.3-4705-gfb6b3bc  GIT Date: 2014-03-03 08:23:43 -0600
>>>>>>>>> [0]PETSC ERROR: ./ex12 on a linux-gnu-c-debug named maya by
>>>>>>>>> salaza11 Mon Mar  3 11:49:15 2014
>>>>>>>>> [0]PETSC ERROR: Configure options --download-mpich
>>>>>>>>> --download-scientificpython --download-triangle --download-ctetgen
>>>>>>>>> --download-chaco --with-c2html=0
>>>>>>>>> [0]PETSC ERROR: #1 User provided function() line 0 in  unknown file
>>>>>>>>> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
>>>>>>>>> [unset]: aborting job:
>>>>>>>>> On Sun, Mar 2, 2014 at 7:11 PM, Matthew Knepley <knepley at gmail.com
>>>>>>>>> > wrote:
>>>>>>>>>> On Sun, Mar 2, 2014 at 6:54 PM, Miguel Angel Salazar de Troya <
>>>>>>>>>>> Hi everybody
>>>>>>>>>>> I am trying to run example ex12.c without much success. I
>>>>>>>>>>> specifically run it with the command options:
>>>>>>>>>> We need to start narrowing down differences, because it runs for
>>>>>>>>>> me and our nightly tests. So, first can
>>>>>>>>>> you confirm that you are using the latest 'next' branch?
>>>>>>>>>>   Thanks,
>>>>>>>>>>       Matt
>>>>>>>>>>> And I get this output
>>>>>>>>>>> Local function:
>>>>>>>>>>>   type: seq
>>>>>>>>>>> 0
>>>>>>>>>>> 1
>>>>>>>>>>> 1
>>>>>>>>>>> 2
>>>>>>>>>>> 1
>>>>>>>>>>> 2
>>>>>>>>>>> 2
>>>>>>>>>>> 3
>>>>>>>>>>> Initial guess
>>>>>>>>>>>   type: seq
>>>>>>>>>>> L_2 Error: 0.625
>>>>>>>>>>> Residual:
>>>>>>>>>>>   type: seq
>>>>>>>>>>> 0
>>>>>>>>>>> 0
>>>>>>>>>>> 0
>>>>>>>>>>> 0
>>>>>>>>>>> 0
>>>>>>>>>>> 0
>>>>>>>>>>> 0
>>>>>>>>>>> 0
>>>>>>>>>>> Initial Residual
>>>>>>>>>>>   type: seq
>>>>>>>>>>> L_2 Residual: 0
>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>> not available,
>>>>>>>>>>> the function
>>>>>>>>>>> [0]PETSC ERROR: [0] DMPlexComputeJacobianFEM line 867
>>>>>>>>>>> [0]PETSC ERROR: Signal received!
>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>> v3.4.3-3453-g0a94005  GIT Date: 2014-03-02 13:12:04 -0600
>>>>>>>>>>> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>>>>>>>>>>> [0]PETSC ERROR: See docs/faq.html for hints about trouble
>>>>>>>>>>> shooting.
>>>>>>>>>>> [0]PETSC ERROR: See docs/index.html for manual pages.
>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>> salaza11 Sun Mar  2 17:00:09 2014
>>>>>>>>>>> [0]PETSC ERROR: Libraries linked from
>>>>>>>>>>> /home/salaza11/petsc/linux-gnu-c-debug/lib
>>>>>>>>>>> [0]PETSC ERROR: Configure run at Sun Mar  2 16:46:51 2014
>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>> [0]PETSC ERROR: User provided function() line 0 in  unknown file
>>>>>>>>>>> Probably my problems could be on my configuration. I attach the
>>>>>>>>>>> configure.log. I ran ./configure like this
>>>>>>>>>>> ./configure --download-mpich --download-scientificpython
>>>>>>>>>>> --download-triangle --download-ctetgen --download-chaco --with-c2html=0
>>>>>>>>>>> Thanks a lot in advance.
>>>>>>>>>>> On Tue, Jan 28, 2014 at 10:37 AM, Matthew Knepley <
>>>>>>>>>>>> On Tue, Jan 28, 2014 at 10:31 AM, Yaakoub El Khamra <
>>>>>>>>>>>> yelkhamra at gmail.com> wrote:
>>>>>>>>>>>>> If
>>>>>>>>>>>>>  ./ex12 -run_type test -dim 3 -refinement_limit 0.0125
>>>>>>>>>>>>> -variable_coefficient field    -interpolate 1 -petscspace_order 2
>>>>>>>>>>>>> is for serial, any chance we can get the options to run in
>>>>>>>>>>>>> parallel?
>>>>>>>>>>>> Just use mpiexec -n <procs>
>>>>>>>>>>>>    Matt
>>>>>>>>>>>>> Regards
>>>>>>>>>>>>> Yaakoub El Khamra
>>>>>>>>>>>>> On Fri, Jan 17, 2014 at 11:29 AM, Matthew Knepley <
>>>>>>>>>>>>>> On Fri, Jan 17, 2014 at 11:06 AM, Jones,Martin Alexander <
>>>>>>>>>>>>>> MAJones2 at mdanderson.org> wrote:
>>>>>>>>>>>>>>> *From:* Matthew Knepley [knepley at gmail.com]
>>>>>>>>>>>>>>> *Sent:* Friday, January 17, 2014 11:04 AM
>>>>>>>>>>>>>>> *To:* Jones,Martin Alexander
>>>>>>>>>>>>>>> *Cc:* petsc-users at mcs.anl.gov
>>>>>>>>>>>>>>> *Subject:* Re: [petsc-users] Problems running ex12.c
>>>>>>>>>>>>>>>    On Fri, Jan 17, 2014 at 11:00 AM, Jones,Martin Alexander
>>>>>>>>>>>>>>> <MAJones2 at mdanderson.org> wrote:
>>>>>>>>>>>>>>>>  These examples all seem to run excepting the following
>>>>>>>>>>>>>>>> command,
>>>>>>>>>>>>>>>> I get the following ouput:
>>>>>>>>>>>>>>>> Local function:
>>>>>>>>>>>>>>>> ./ex12: symbol lookup error:
>>>>>>>>>>>>>>>> /opt/apps/EPD/epd-7.3-1-rh5-x86_64/lib/libmkl_intel_thread.so: undefined
>>>>>>>>>>>>>>>> symbol: omp_get_num_procs
>>>>>>>>>>>>>>>  This is a build problem, but it should affect all the
>>>>>>>>>>>>>>> runs. Is this reproducible? Can you send configure.log? MKL is the worst.
>>>>>>>>>>>>>>> If this
>>>>>>>>>>>>>>> persists, I would just switch to --download-f-blas-lapack.
>>>>>>>>>>>>>> Thanks. I have some advice on options
>>>>>>>>>>>>>>   --with-precision=single # I would not use this unless you
>>>>>>>>>>>>>> are doing something special, like CUDA
>>>>>>>>>>>>>>   --with-clanguage=C++  # I would recommend switching to C,
>>>>>>>>>>>>>> the build is much faster
>>>>>>>>>>>>>>   --with-mpi-dir=/usr --with-mpi4py=0
>>>>>>>>>>>>>>   --with-shared-libraries --CFLAGS=-O0 --CXXFLAGS=-O0
>>>>>>>>>>>>>> --with-fc=0
>>>>>>>>>>>>>>   --with-etags=1                # This is unnecessary
>>>>>>>>>>>>>> --with-blas-lapack-lib="[/opt/apps/EPD/epd-7.3-1-rh5-x86_64/lib/libmkl_rt.so,/opt/apps/EPD/epd-7.3-1-rh5-x86_64/lib/libmkl_intel_thread.so,/opt/apps/EPD/epd-7.3-1-rh5-x86_64/lib/libmkl_core.so,/opt/apps/EPD/epd-7.3-1-rh5-x86_64/lib/libiomp5.so]"
>>>>>>>>>>>>>> # Here is the problem, see below
>>>>>>>>>>>>>>   --download-metis
>>>>>>>>>>>>>>   --download-fiat=yes --download-generator
>>>>>>>>>>>>>> --download-scientificpython # Get rid of these, they are obsolete
>>>>>>>>>>>>>> Your MKL needs another library for the OpenMP symbols. I
>>>>>>>>>>>>>> would recommend switching to --download-f2cblaslapack,
>>>>>>>>>>>>>> or you can try and find that library.
>>>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>>>       Matt
>>>>>>>>>>>>>>>    Thanks,
>>>>>>>>>>>>>>>       Matt
>>>>>>>>>>>>>>>> *Sent:* Thursday, January 16, 2014 6:35 PM
>>>>>>>>>>>>>>>>    On Thu, Jan 16, 2014 at 5:43 PM, Jones,Martin Alexander
>>>>>>>>>>>>>>>>>  Hi, This is the next error message after configuring and
>>>>>>>>>>>>>>>>> building with the triangle package when trying to run ex12
>>>>>>>>>>>>>>>>  This is my fault for bad defaults. I will fix. Try running
>>>>>>>>>>>>>>>>  for a representative run. Then you could try 3D
>>>>>>>>>>>>>>>>  or a full run
>>>>>>>>>>>>>>>>    ex12 -refinement_limit 0.01 -bc_type dirichlet
>>>>>>>>>>>>>>>> -interpolate -petscspace_order 1
>>>>>>>>>>>>>>>> -interpolate -petscspace_order 2
>>>>>>>>>>>>>>>>  Let me know if those work.
>>>>>>>>>>>>>>>>    Thanks,
>>>>>>>>>>>>>>>>       Matt
>>>>>>>>>>>>>>>>>   ./ex12
>>>>>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>>>>>> [0]PETSC ERROR: Caught signal number 8 FPE: Floating Point
>>>>>>>>>>>>>>>>> Exception,probably divide by zero
>>>>>>>>>>>>>>>>> find memory corruption errors
>>>>>>>>>>>>>>>>> below
>>>>>>>>>>>>>>>>> are not available,
>>>>>>>>>>>>>>>>> of the function
>>>>>>>>>>>>>>>>> [0]PETSC ERROR: [0] DMPlexComputeResidualFEM line 531
>>>>>>>>>>>>>>>>> /home/mjonesa/PETSc/petsc/src/dm/impls/plex/plexfem.c
>>>>>>>>>>>>>>>>> [0]PETSC ERROR: [0] SNESComputeFunction_DMLocal line 63
>>>>>>>>>>>>>>>>> /home/mjonesa/PETSc/petsc/src/snes/utils/dmlocalsnes.c
>>>>>>>>>>>>>>>>> [0]PETSC ERROR: [0] SNES user function line 2088
>>>>>>>>>>>>>>>>> /home/mjonesa/PETSc/petsc/src/snes/interface/snes.c
>>>>>>>>>>>>>>>>> [0]PETSC ERROR: [0] SNESComputeFunction line 2076
>>>>>>>>>>>>>>>>> [0]PETSC ERROR: [0] SNESSolve_NEWTONLS line 144
>>>>>>>>>>>>>>>>> /home/mjonesa/PETSc/petsc/src/snes/impls/ls/ls.c
>>>>>>>>>>>>>>>>> [0]PETSC ERROR: [0] SNESSolve line 3765
>>>>>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>>>>>> v3.4.3-2317-gcd0e7f7  GIT Date: 2014-01-15 20:33:42 -0600
>>>>>>>>>>>>>>>>> updates.
>>>>>>>>>>>>>>>>> shooting.
>>>>>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>>>>>> [0]PETSC ERROR: ./ex12 on a arch-linux2-cxx-debug named
>>>>>>>>>>>>>>>>> maeda by mjonesa Thu Jan 16 17:41:23 2014
>>>>>>>>>>>>>>>>> /home/mjonesa/local/lib
>>>>>>>>>>>>>>>>> [0]PETSC ERROR: Configure run at Thu Jan 16 17:38:33 2014
>>>>>>>>>>>>>>>>> --prefix=/home/mjonesa/local
>>>>>>>>>>>>>>>>> --with-c2html=0 --with-clanguage=c++ PETSC_ARCH=arch-linux2-cxx-debug
>>>>>>>>>>>>>>>>> --download-triangle
>>>>>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>>>>>>  unknown file
>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>> *Sent:* Thursday, January 16, 2014 4:37 PM
>>>>>>>>>>>>>>>>>    On Thu, Jan 16, 2014 at 4:33 PM, Jones,Martin
>>>>>>>>>>>>>>>>> Alexander <MAJones2 at mdanderson.org> wrote:
>>>>>>>>>>>>>>>>>>  Hi, I have downloaded and built the dev version you
>>>>>>>>>>>>>>>>>> suggested. I think I need the triangle package to run this particular case.
>>>>>>>>>>>>>>>>>> Is there any thing else that appears wrong in what I have done from the
>>>>>>>>>>>>>>>>>> error messages below:
>>>>>>>>>>>>>>>>>  Great! Its running. You can reconfigure like this:
>>>>>>>>>>>>>>>>>    $PETSC_DIR/$PETSC_ARCH/conf/reconfigure-$PETSC_ARCH.py
>>>>>>>>>>>>>>>>> --download-triangle
>>>>>>>>>>>>>>>>>  and then rebuild
>>>>>>>>>>>>>>>>>     make
>>>>>>>>>>>>>>>>>  and then rerun. You can load meshes, but its much easier
>>>>>>>>>>>>>>>>> to have triangle create them.
>>>>>>>>>>>>>>>>>    Thanks for being patient,
>>>>>>>>>>>>>>>>>       Matt
>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: No support for this operation for this
>>>>>>>>>>>>>>>>>> object type!
>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: Mesh generation needs external package
>>>>>>>>>>>>>>>>>> support.
>>>>>>>>>>>>>>>>>> Please reconfigure with --download-triangle.!
>>>>>>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>>>>>>> updates.
>>>>>>>>>>>>>>>>>> shooting.
>>>>>>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>>>>>>> maeda by mjonesa Thu Jan 16 16:28:20 2014
>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: Configure run at Thu Jan 16 16:25:53 2014
>>>>>>>>>>>>>>>>>> --prefix=/home/mjonesa/local --with-clanguage=c++ --with-c2html=0
>>>>>>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: DMPlexGenerate() line 4332 in
>>>>>>>>>>>>>>>>>> /home/mjonesa/PETSc/petsc/src/dm/impls/plex/plex.c
>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: DMPlexCreateBoxMesh() line 600 in
>>>>>>>>>>>>>>>>>> /home/mjonesa/PETSc/petsc/src/dm/impls/plex/plexcreate.c
>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: CreateMesh() line 295 in
>>>>>>>>>>>>>>>>>> /home/mjonesa/PETSc/petsc/src/snes/examples/tutorials/ex12.c
>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: main() line 659 in
>>>>>>>>>>>>>>>>>> application called MPI_Abort(MPI_COMM_WORLD, 56) -
>>>>>>>>>>>>>>>>>> process 0
>>>>>>>>>>>>>>>>>> *Sent:* Thursday, January 16, 2014 4:06 PM
>>>>>>>>>>>>>>>>>>    On Thu, Jan 16, 2014 at 4:05 PM, Jones,Martin
>>>>>>>>>>>>>>>>>>>  Hi. I changed the ENV variable to the correct entry.
>>>>>>>>>>>>>>>>>>> when I type make ex12 I get this:
>>>>>>>>>>>>>>>>>>> mjonesa at maeda:~/PETSc/petsc-3.4.3/src/snes/examples/tutorials$
>>>>>>>>>>>>>>>>>>> make ex12
>>>>>>>>>>>>>>>>>>> g++ -o ex12.o -c -Wall -Wwrite-strings
>>>>>>>>>>>>>>>>>>> -Wno-strict-aliasing -Wno-unknown-pragmas -g   -fPIC
>>>>>>>>>>>>>>>>>>> -I/home/mjonesa/PETSc/petsc-3.4.3/include
>>>>>>>>>>>>>>>>>>> -I/home/mjonesa/PETSc/petsc-3.4.3/arch-linux2-cxx-debug/include
>>>>>>>>>>>>>>>>>>> -I/home/mjonesa/PETSc/petsc-3.4.3/include/mpiuni
>>>>>>>>>>>>>>>>>>> -D__INSDIR__=src/snes/examples/tutorials/ ex12.c
>>>>>>>>>>>>>>>>>>> ex12.c:14:18: fatal error: ex12.h: No such file or
>>>>>>>>>>>>>>>>>>> directory
>>>>>>>>>>>>>>>>>>> compilation terminated.
>>>>>>>>>>>>>>>>>>> make: *** [ex12.o] Error 1
>>>>>>>>>>>>>>>>>>> Any help of yours is very much appreciated.
>>>>>>>>>>>>>>>>>>  Yes, this relates to my 3). This is not going to work
>>>>>>>>>>>>>>>>>> for you with the release. Please see the link I sent.
>>>>>>>>>>>>>>>>>>     Matt
>>>>>>>>>>>>>>>>>>> *Sent:* Thursday, January 16, 2014 3:58 PM
>>>>>>>>>>>>>>>>>>>    On Thu, Jan 16, 2014 at 3:55 PM, Jones,Martin
>>>>>>>>>>>>>>>>>>>>  Thanks!
>>>>>>>>>>>>>>>>>>>  You built with PETSC_ARCH=arch-linux2-cxx-debug
>>>>>>>>>>>>>>>>>>>     Matt
>>>>>>>>>>>>>>>>>>>> *Sent:* Thursday, January 16, 2014 3:31 PM
>>>>>>>>>>>>>>>>>>>>    On Thu, Jan 16, 2014 at 3:11 PM, Jones,Martin
>>>>>>>>>>>>>>>>>>>>>  Now I went to the directory where ex12.c sits and
>>>>>>>>>>>>>>>>>>>>> just did a 'make ex12.c' with the following error if this helps?  :
>>>>>>>>>>>>>>>>>>>>> make ex12.c
>>>>>>>>>>>>>>>>>>>>> /home/mjonesa/PETSc/petsc-3.4.3/conf/variables:108:
>>>>>>>>>>>>>>>>>>>>> /home/mjonesa/PETSc/petsc-3.4.3/linux-gnu-cxx-debug/conf/petscvariables: No
>>>>>>>>>>>>>>>>>>>>> such file or directory
>>>>>>>>>>>>>>>>>>>>> /home/mjonesa/PETSc/petsc-3.4.3/conf/rules:962:
>>>>>>>>>>>>>>>>>>>>> /home/mjonesa/PETSc/petsc-3.4.3/linux-gnu-cxx-debug/conf/petscrules: No
>>>>>>>>>>>>>>>>>>>>> make: *** No rule to make target
>>>>>>>>>>>>>>>>>>>>> `/home/mjonesa/PETSc/petsc-3.4.3/linux-gnu-cxx-debug/conf/petscrules'.
>>>>>>>>>>>>>>>>>>>>> Stop.
>>>>>>>>>>>>>>>>>>>>  1) You would type 'make ex12'
>>>>>>>>>>>>>>>>>>>>  2) Either you PETSC_DIR (/home/mjonesa/PETSc/petsc-3.
>>>>>>>>>>>>>>>>>>>> 4.3) or PETSC_ARCH (linux-gnu-cxx-debug) environment
>>>>>>>>>>>>>>>>>>>> variables
>>>>>>>>>>>>>>>>>>>>     do not match what you built. Please send
>>>>>>>>>>>>>>>>>>>> configure.log and make.log
>>>>>>>>>>>>>>>>>>>>  3) Since it was only recently added, if you want to
>>>>>>>>>>>>>>>>>>>> use the FEM functionality, you must use the development version:
>>>>>>>>>>>>>>>>>>>>     http://www.mcs.anl.gov/petsc/developers/index.html
>>>>>>>>>>>>>>>>>>>>    Thanks,
>>>>>>>>>>>>>>>>>>>>        Matt
>>>>>>>>>>>>>>>>>>>>> *From:* Matthew Knepley [mailto:knepley at gmail.com]
>>>>>>>>>>>>>>>>>>>>> *Sent:* Thursday, January 16, 2014 2:48 PM
>>>>>>>>>>>>>>>>>>>>> On Thu, Jan 16, 2014 at 2:35 PM, Jones,Martin
>>>>>>>>>>>>>>>>>>>>> Hello To Whom it Concerns,
>>>>>>>>>>>>>>>>>>>>> I am trying to run the tutorial ex12.c by running 'bin/pythonscripts/PetscGenerateFEMQuadrature.py
>>>>>>>>>>>>>>>>>>>>> dim order dim 1 laplacian dim order dim 1 boundary
>>>>>>>>>>>>>>>>>>>>> src/snes/examples/tutorials/ex12.h'
>>>>>>>>>>>>>>>>>>>>> but getting the following error:
>>>>>>>>>>>>>>>>>>>>> $ bin/pythonscripts/PetscGenerateFEMQuadrature.py dim
>>>>>>>>>>>>>>>>>>>>> Traceback (most recent call last):
>>>>>>>>>>>>>>>>>>>>>   File
>>>>>>>>>>>>>>>>>>>>> "bin/pythonscripts/PetscGenerateFEMQuadrature.py", line 15, in <module>
>>>>>>>>>>>>>>>>>>>>>     from FIAT.reference_element import default_simplex
>>>>>>>>>>>>>>>>>>>>> ImportError: No module named FIAT.reference_element
>>>>>>>>>>>>>>>>>>>>> I have removed the requirement of generating the
>>>>>>>>>>>>>>>>>>>>> header file (its now all handled in C). I thought
>>>>>>>>>>>>>>>>>>>>> I changed the documentation everywhere (including the
>>>>>>>>>>>>>>>>>>>>> latest tutorial slides). Can you try running
>>>>>>>>>>>>>>>>>>>>> with 'master' (or 'next'), and point me toward the old
>>>>>>>>>>>>>>>>>>>>> docs?
>>>>>>>>>>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>>>>>>>>>>     Matt
>>>>>>>>>>>>>>>>>>>>> What most experimenters take for granted before they
>>>>>>>>>>>>>>>>>>>>> begin their experiments is infinitely more interesting than any results to
>>>>>>>>>>>>>>>>>>>>> which their experiments lead.
>>>>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>> *Miguel Angel Salazar de Troya*
>>>>>>>>>>> Graduate Research Assistant
>>>>>>>>>>> Department of Mechanical Science and Engineering
>>>>>>>>>>> University of Illinois at Urbana-Champaign
>>>>>>>>>>> (217) 550-2360
>>>>>>>>>>> salaza11 at illinois.edu
>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>> experiments lead.
>>>>>>>>>> -- Norbert Wiener
>>>>>>>>> (217) 550-2360
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>>> (217) 550-2360
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>> (217) 550-2360
>>>> experiments lead.
>>>> -- Norbert Wiener
>>> (217) 550-2360
>> experiments lead.
>> -- Norbert Wiener
> (217) 550-2360
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140304/d43c8f81/attachment-0001.html>
