[petsc-users] Problems running ex12.c
Mon Mar 3 12:48:56 CST 2014
On Mon, Mar 3, 2014 at 12:39 PM, Miguel Angel Salazar de Troya <
salazardetroya at gmail.com> wrote:
> Thanks for your response. Sorry I did not have the "next" version, but the
> "master" version. I still have an error though. I followed the steps given
> here (https://bitbucket.org/petsc/petsc/wiki/Home) to obtain the next
> version, I configured petsc as above and ran ex12 as above as well, getting
> this error:
> [salaza11 at maya tutorials]$ ./ex12 -run_type test -refinement_limit 0.0
>  -bc_type dirichlet -interpolate 0 -petscspace_order 1 -show_initial
> -dm_plex_print_fem 1
> Local function:
> Vec Object: 1 MPI processes
>   type: seq
> 0
> 0.25
> 1
> 0.25
> 0.5
> 1.25
> 1
> 1.25
> 2
> Initial guess
>   type: seq
> 0.5
> L_2 Error: 0.111111
> Residual:
>   type: seq
> 0
> 0
> 0
> 0
> 0
> 0
> 0
> 0
> 0
> Initial Residual
>   type: seq
> 0
> L_2 Residual: 0
Okay, now run with -start_in_debugger, and give me a stack trace using
'where'.
     Matt
> [0]PETSC ERROR:
> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> probably memory access out of range
> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [0]PETSC ERROR: or see
> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[0]PETSCERROR: or try
> http://valgrind.org on GNU/linux and Apple Mac OS X to find memory
> corruption errors
> [0]PETSC ERROR: likely location of problem given in stack below
> [0]PETSC ERROR: ---------------------  Stack Frames
> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> [0]PETSC ERROR:       INSTEAD the line number of the start of the function
> [0]PETSC ERROR:       is given.
> [0]PETSC ERROR: [0] DMPlexComputeJacobianFEM line 871
> /home/salaza11/petsc/src/dm/impls/plex/plexfem.c
> [0]PETSC ERROR: [0] SNESComputeJacobian_DMLocal line 94
> /home/salaza11/petsc/src/snes/utils/dmlocalsnes.c
> [0]PETSC ERROR: [0] SNES user Jacobian function line 2244
> /home/salaza11/petsc/src/snes/interface/snes.c
> [0]PETSC ERROR: [0] SNESComputeJacobian line 2203
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Signal received
> [0]PETSC ERROR: See http://
> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> [0]PETSC ERROR: Petsc Development GIT revision: v3.4.3-4705-gfb6b3bc  GIT
> Date: 2014-03-03 08:23:43 -0600
> [0]PETSC ERROR: ./ex12 on a linux-gnu-c-debug named maya by salaza11 Mon
> Mar  3 11:49:15 2014
> [0]PETSC ERROR: Configure options --download-mpich
> --download-scientificpython --download-triangle --download-ctetgen
> --download-chaco --with-c2html=0
> [0]PETSC ERROR: #1 User provided function() line 0 in  unknown file
> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
> [unset]: aborting job:
> On Sun, Mar 2, 2014 at 7:11 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Sun, Mar 2, 2014 at 6:54 PM, Miguel Angel Salazar de Troya <
>>> Hi everybody
>>> I am trying to run example ex12.c without much success. I specifically
>>> run it with the command options:
>> We need to start narrowing down differences, because it runs for me and
>> our nightly tests. So, first can
>> you confirm that you are using the latest 'next' branch?
>>   Thanks,
>>       Matt
>>> ./ex12 -run_type test -refinement_limit 0.0    -bc_type dirichlet
>>> -interpolate 0 -petscspace_order 1 -show_initial -dm_plex_print_fem 1
>>> And I get this output
>>> Local function:
>>>   type: seq
>>> 0
>>> 1
>>> 1
>>> 2
>>> 1
>>> 2
>>> 2
>>> 3
>>> Initial guess
>>>   type: seq
>>> L_2 Error: 0.625
>>> Residual:
>>>   type: seq
>>> 0
>>> 0
>>> 0
>>> 0
>>> 0
>>> 0
>>> 0
>>> 0
>>> Initial Residual
>>>   type: seq
>>> L_2 Residual: 0
>>> [0]PETSC ERROR:
>>> corruption errors
>>> available,
>>> function
>>> [0]PETSC ERROR: [0] DMPlexComputeJacobianFEM line 867
>>> [0]PETSC ERROR: Signal received!
>>> [0]PETSC ERROR:
>>> [0]PETSC ERROR: Petsc Development GIT revision: v3.4.3-3453-g0a94005
>>>  GIT Date: 2014-03-02 13:12:04 -0600
>>> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>>> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>>> [0]PETSC ERROR: See docs/index.html for manual pages.
>>> [0]PETSC ERROR:
>>> [0]PETSC ERROR: ./ex12 on a linux-gnu-c-debug named maya by salaza11 Sun
>>> Mar  2 17:00:09 2014
>>> [0]PETSC ERROR: Libraries linked from
>>> /home/salaza11/petsc/linux-gnu-c-debug/lib
>>> [0]PETSC ERROR: Configure run at Sun Mar  2 16:46:51 2014
>>> [0]PETSC ERROR:
>>> [0]PETSC ERROR: User provided function() line 0 in  unknown file
>>> Probably my problems could be on my configuration. I attach the
>>> configure.log. I ran ./configure like this
>>> ./configure --download-mpich --download-scientificpython
>>> --download-triangle --download-ctetgen --download-chaco --with-c2html=0
>>> Thanks a lot in advance.
>>> On Tue, Jan 28, 2014 at 10:37 AM, Matthew Knepley <knepley at gmail.com>wrote:
>>>> On Tue, Jan 28, 2014 at 10:31 AM, Yaakoub El Khamra <
>>>> yelkhamra at gmail.com> wrote:
>>>>> If
>>>>>  ./ex12 -run_type test -dim 3 -refinement_limit 0.0125
>>>>> -variable_coefficient field    -interpolate 1 -petscspace_order 2
>>>>> is for serial, any chance we can get the options to run in parallel?
>>>> Just use mpiexec -n <procs>
>>>>    Matt
>>>>> Regards
>>>>> Yaakoub El Khamra
>>>>> On Fri, Jan 17, 2014 at 11:29 AM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>> On Fri, Jan 17, 2014 at 11:06 AM, Jones,Martin Alexander <
>>>>>> MAJones2 at mdanderson.org> wrote:
>>>>>>> *From:* Matthew Knepley [knepley at gmail.com]
>>>>>>> *Sent:* Friday, January 17, 2014 11:04 AM
>>>>>>> *To:* Jones,Martin Alexander
>>>>>>> *Cc:* petsc-users at mcs.anl.gov
>>>>>>> *Subject:* Re: [petsc-users] Problems running ex12.c
>>>>>>>    On Fri, Jan 17, 2014 at 11:00 AM, Jones,Martin Alexander <
>>>>>>>>  These examples all seem to run excepting the following command,
>>>>>>>> I get the following ouput:
>>>>>>>> Local function:
>>>>>>>> ./ex12: symbol lookup error:
>>>>>>>> /opt/apps/EPD/epd-7.3-1-rh5-x86_64/lib/libmkl_intel_thread.so: undefined
>>>>>>>> symbol: omp_get_num_procs
>>>>>>>  This is a build problem, but it should affect all the runs. Is
>>>>>>> this reproducible? Can you send configure.log? MKL is the worst. If this
>>>>>>> persists, I would just switch to --download-f-blas-lapack.
>>>>>> Thanks. I have some advice on options
>>>>>>   --with-precision=single # I would not use this unless you are doing
>>>>>> something special, like CUDA
>>>>>>   --with-clanguage=C++  # I would recommend switching to C, the build
>>>>>> is much faster
>>>>>>   --with-mpi-dir=/usr --with-mpi4py=0
>>>>>>   --with-shared-libraries --CFLAGS=-O0 --CXXFLAGS=-O0 --with-fc=0
>>>>>>   --with-etags=1                # This is unnecessary
>>>>>> --with-blas-lapack-lib="[/opt/apps/EPD/epd-7.3-1-rh5-x86_64/lib/libmkl_rt.so,/opt/apps/EPD/epd-7.3-1-rh5-x86_64/lib/libmkl_intel_thread.so,/opt/apps/EPD/epd-7.3-1-rh5-x86_64/lib/libmkl_core.so,/opt/apps/EPD/epd-7.3-1-rh5-x86_64/lib/libiomp5.so]"
>>>>>> # Here is the problem, see below
>>>>>>   --download-metis
>>>>>>   --download-fiat=yes --download-generator
>>>>>> --download-scientificpython # Get rid of these, they are obsolete
>>>>>> Your MKL needs another library for the OpenMP symbols. I would
>>>>>> recommend switching to --download-f2cblaslapack,
>>>>>> or you can try and find that library.
>>>>>>   Thanks,
>>>>>>       Matt
>>>>>>>    Thanks,
>>>>>>>       Matt
>>>>>>>> *Sent:* Thursday, January 16, 2014 6:35 PM
>>>>>>>>    On Thu, Jan 16, 2014 at 5:43 PM, Jones,Martin Alexander <
>>>>>>>>>  Hi, This is the next error message after configuring and
>>>>>>>>> building with the triangle package when trying to run ex12
>>>>>>>>  This is my fault for bad defaults. I will fix. Try running
>>>>>>>>  for a representative run. Then you could try 3D
>>>>>>>>  or a full run
>>>>>>>>    ex12 -refinement_limit 0.01 -bc_type dirichlet -interpolate
>>>>>>>> -petscspace_order 1
>>>>>>>> -petscspace_order 2
>>>>>>>>  Let me know if those work.
>>>>>>>>    Thanks,
>>>>>>>>       Matt
>>>>>>>>>   ./ex12
>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>> [0]PETSC ERROR: Caught signal number 8 FPE: Floating Point
>>>>>>>>> Exception,probably divide by zero
>>>>>>>>> memory corruption errors
>>>>>>>>> available,
>>>>>>>>> function
>>>>>>>>> [0]PETSC ERROR: [0] DMPlexComputeResidualFEM line 531
>>>>>>>>> /home/mjonesa/PETSc/petsc/src/dm/impls/plex/plexfem.c
>>>>>>>>> [0]PETSC ERROR: [0] SNESComputeFunction_DMLocal line 63
>>>>>>>>> /home/mjonesa/PETSc/petsc/src/snes/utils/dmlocalsnes.c
>>>>>>>>> [0]PETSC ERROR: [0] SNES user function line 2088
>>>>>>>>> /home/mjonesa/PETSc/petsc/src/snes/interface/snes.c
>>>>>>>>> [0]PETSC ERROR: [0] SNESComputeFunction line 2076
>>>>>>>>> [0]PETSC ERROR: [0] SNESSolve_NEWTONLS line 144
>>>>>>>>> /home/mjonesa/PETSc/petsc/src/snes/impls/ls/ls.c
>>>>>>>>> [0]PETSC ERROR: [0] SNESSolve line 3765
>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>> v3.4.3-2317-gcd0e7f7  GIT Date: 2014-01-15 20:33:42 -0600
>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>> [0]PETSC ERROR: ./ex12 on a arch-linux2-cxx-debug named maeda by
>>>>>>>>> mjonesa Thu Jan 16 17:41:23 2014
>>>>>>>>> [0]PETSC ERROR: Libraries linked from /home/mjonesa/local/lib
>>>>>>>>> [0]PETSC ERROR: Configure run at Thu Jan 16 17:38:33 2014
>>>>>>>>> [0]PETSC ERROR: Configure options --prefix=/home/mjonesa/local
>>>>>>>>> --with-c2html=0 --with-clanguage=c++ PETSC_ARCH=arch-linux2-cxx-debug
>>>>>>>>> --download-triangle
>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>> *Sent:* Thursday, January 16, 2014 4:37 PM
>>>>>>>>>    On Thu, Jan 16, 2014 at 4:33 PM, Jones,Martin Alexander <
>>>>>>>>>>  Hi, I have downloaded and built the dev version you suggested.
>>>>>>>>>> I think I need the triangle package to run this particular case. Is there
>>>>>>>>>> any thing else that appears wrong in what I have done from the error
>>>>>>>>>> messages below:
>>>>>>>>>  Great! Its running. You can reconfigure like this:
>>>>>>>>>    $PETSC_DIR/$PETSC_ARCH/conf/reconfigure-$PETSC_ARCH.py
>>>>>>>>> --download-triangle
>>>>>>>>>  and then rebuild
>>>>>>>>>     make
>>>>>>>>>  and then rerun. You can load meshes, but its much easier to have
>>>>>>>>> triangle create them.
>>>>>>>>>    Thanks for being patient,
>>>>>>>>>       Matt
>>>>>>>>>> [0]PETSC ERROR: No support for this operation for this object
>>>>>>>>>> type!
>>>>>>>>>> [0]PETSC ERROR: Mesh generation needs external package support.
>>>>>>>>>> Please reconfigure with --download-triangle.!
>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>> shooting.
>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>> mjonesa Thu Jan 16 16:28:20 2014
>>>>>>>>>> [0]PETSC ERROR: Configure run at Thu Jan 16 16:25:53 2014
>>>>>>>>>> --with-clanguage=c++ --with-c2html=0
>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>> [0]PETSC ERROR: DMPlexGenerate() line 4332 in
>>>>>>>>>> /home/mjonesa/PETSc/petsc/src/dm/impls/plex/plex.c
>>>>>>>>>> [0]PETSC ERROR: DMPlexCreateBoxMesh() line 600 in
>>>>>>>>>> /home/mjonesa/PETSc/petsc/src/dm/impls/plex/plexcreate.c
>>>>>>>>>> [0]PETSC ERROR: CreateMesh() line 295 in
>>>>>>>>>> /home/mjonesa/PETSc/petsc/src/snes/examples/tutorials/ex12.c
>>>>>>>>>> [0]PETSC ERROR: main() line 659 in
>>>>>>>>>> application called MPI_Abort(MPI_COMM_WORLD, 56) - process 0
>>>>>>>>>> *Sent:* Thursday, January 16, 2014 4:06 PM
>>>>>>>>>>    On Thu, Jan 16, 2014 at 4:05 PM, Jones,Martin Alexander <
>>>>>>>>>>>  Hi. I changed the ENV variable to the correct entry. when I
>>>>>>>>>>> type make ex12 I get this:
>>>>>>>>>>> mjonesa at maeda:~/PETSc/petsc-3.4.3/src/snes/examples/tutorials$
>>>>>>>>>>> make ex12
>>>>>>>>>>> g++ -o ex12.o -c -Wall -Wwrite-strings -Wno-strict-aliasing
>>>>>>>>>>> -Wno-unknown-pragmas -g   -fPIC
>>>>>>>>>>> -I/home/mjonesa/PETSc/petsc-3.4.3/include
>>>>>>>>>>> -I/home/mjonesa/PETSc/petsc-3.4.3/arch-linux2-cxx-debug/include
>>>>>>>>>>> -I/home/mjonesa/PETSc/petsc-3.4.3/include/mpiuni
>>>>>>>>>>> -D__INSDIR__=src/snes/examples/tutorials/ ex12.c
>>>>>>>>>>> ex12.c:14:18: fatal error: ex12.h: No such file or directory
>>>>>>>>>>> compilation terminated.
>>>>>>>>>>> make: *** [ex12.o] Error 1
>>>>>>>>>>> Any help of yours is very much appreciated.
>>>>>>>>>>  Yes, this relates to my 3). This is not going to work for you
>>>>>>>>>> with the release. Please see the link I sent.
>>>>>>>>>>     Matt
>>>>>>>>>>> *Sent:* Thursday, January 16, 2014 3:58 PM
>>>>>>>>>>>    On Thu, Jan 16, 2014 at 3:55 PM, Jones,Martin Alexander <
>>>>>>>>>>>>  Thanks!
>>>>>>>>>>>  You built with PETSC_ARCH=arch-linux2-cxx-debug
>>>>>>>>>>>     Matt
>>>>>>>>>>>> *Sent:* Thursday, January 16, 2014 3:31 PM
>>>>>>>>>>>>    On Thu, Jan 16, 2014 at 3:11 PM, Jones,Martin Alexander <
>>>>>>>>>>>>>  Now I went to the directory where ex12.c sits and just did a
>>>>>>>>>>>>> 'make ex12.c' with the following error if this helps?  :
>>>>>>>>>>>>> make ex12.c
>>>>>>>>>>>>> /home/mjonesa/PETSc/petsc-3.4.3/conf/variables:108:
>>>>>>>>>>>>> /home/mjonesa/PETSc/petsc-3.4.3/linux-gnu-cxx-debug/conf/petscvariables: No
>>>>>>>>>>>>> /home/mjonesa/PETSc/petsc-3.4.3/conf/rules:962:
>>>>>>>>>>>>> /home/mjonesa/PETSc/petsc-3.4.3/linux-gnu-cxx-debug/conf/petscrules: No
>>>>>>>>>>>>> make: *** No rule to make target
>>>>>>>>>>>>> `/home/mjonesa/PETSc/petsc-3.4.3/linux-gnu-cxx-debug/conf/petscrules'.
>>>>>>>>>>>>> Stop.
>>>>>>>>>>>>  1) You would type 'make ex12'
>>>>>>>>>>>>  2) Either you PETSC_DIR (/home/mjonesa/PETSc/petsc-3.4.3) or
>>>>>>>>>>>> PETSC_ARCH (linux-gnu-cxx-debug) environment variables
>>>>>>>>>>>>     do not match what you built. Please send configure.log and
>>>>>>>>>>>> make.log
>>>>>>>>>>>>  3) Since it was only recently added, if you want to use the
>>>>>>>>>>>> FEM functionality, you must use the development version:
>>>>>>>>>>>>     http://www.mcs.anl.gov/petsc/developers/index.html
>>>>>>>>>>>>    Thanks,
>>>>>>>>>>>>        Matt
>>>>>>>>>>>>> *From:* Matthew Knepley [mailto:knepley at gmail.com]
>>>>>>>>>>>>> *Sent:* Thursday, January 16, 2014 2:48 PM
>>>>>>>>>>>>> On Thu, Jan 16, 2014 at 2:35 PM, Jones,Martin Alexander <
>>>>>>>>>>>>> Hello To Whom it Concerns,
>>>>>>>>>>>>> I am trying to run the tutorial ex12.c by running 'bin/pythonscripts/PetscGenerateFEMQuadrature.py
>>>>>>>>>>>>> dim order dim 1 laplacian dim order dim 1 boundary
>>>>>>>>>>>>> src/snes/examples/tutorials/ex12.h'
>>>>>>>>>>>>> but getting the following error:
>>>>>>>>>>>>> $ bin/pythonscripts/PetscGenerateFEMQuadrature.py dim order
>>>>>>>>>>>>> dim 1 laplacian dim order dim 1 boundary src/snes/examples/tutorials/ex12.h
>>>>>>>>>>>>> Traceback (most recent call last):
>>>>>>>>>>>>>   File "bin/pythonscripts/PetscGenerateFEMQuadrature.py", line
>>>>>>>>>>>>> 15, in <module>
>>>>>>>>>>>>>     from FIAT.reference_element import default_simplex
>>>>>>>>>>>>> ImportError: No module named FIAT.reference_element
>>>>>>>>>>>>> I have removed the requirement of generating the header file
>>>>>>>>>>>>> (its now all handled in C). I thought
>>>>>>>>>>>>> I changed the documentation everywhere (including the latest
>>>>>>>>>>>>> tutorial slides). Can you try running
>>>>>>>>>>>>> with 'master' (or 'next'), and point me toward the old docs?
>>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>>     Matt
>>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>>> their experiments lead.
>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>>> experiments lead.
>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>> experiments lead.
>>>>>>>>>> -- Norbert Wiener
>>>>>>>>> experiments lead.
>>>>>>>>> -- Norbert Wiener
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>>> *Miguel Angel Salazar de Troya*
>>> Graduate Research Assistant
>>> Department of Mechanical Science and Engineering
>>> University of Illinois at Urbana-Champaign
>>> (217) 550-2360
>>> salaza11 at illinois.edu
>> experiments lead.
>> -- Norbert Wiener
> (217) 550-2360
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140303/701f0449/attachment-0001.html>
