[petsc-users] Combining preconditioners
Qin Lu
lu_qin_2000 at yahoo.com
Fri Jun 27 23:22:37 CDT 2014
Hello,
I would like to combine two preconditioners in PETSc linear solver. The first preconditioner is user defined, the second one is just PETSc ILU, and the residual is updated after application of each preconditioner (the multiplicative form). There are two questions:
1. Shall I use PCShellSetApply to set the user defined preconditioner, and then use PCCompositeAddPC to combine the 2 preconditioners?
2. The user defined preconditioner only applies to part of the components of the unknowns, in other words, the rank of the first preconditioner matrix is less than the rank of the full matrix. How can I let PETSc know how to update the residual after the application of the first preconditioner? Can I define a routine of residual updating for PETSc?
Many thanks for your help.
Best Regards,
Qin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140627/b4ddabab/attachment.html>
