[petsc-users] MatMult() returning different values depending on # of processors?
Arthur Kurlej
akurlej at gmail.com
Thu Jun 26 21:10:01 CDT 2014
Hmm, so I made that change, but my program still exhibits the same problem
with it's output.
On Thu, Jun 26, 2014 at 9:05 PM, Peter Brune <prbrune at gmail.com> wrote:
> Yep! Looks good. One other thing is that you can pre/postface all PETSc
> calls with ierr = ... CHKERRQ(ierr); and it will properly trace other
> problems if they arise.
> - Peter
> On Thu, Jun 26, 2014 at 8:56 PM, Arthur Kurlej <akurlej at gmail.com> wrote:
>> Hello,
>> I'm sorry, but this is a bit new for me, and I'm still not quite sure I
>> follow.
>> Are you recommending that opposed to doing this:
>> if(procs!=1){
>> for(i=0;i<procs;i++){
>> if(rank==i){
>> VecGetLocalSize(*x,&length);
>> VecGetOwnershipRange(*x,&div,NULL);
>> ISCreateStride(PETSC_COMM_WORLD,length,div+begin,1,&iscol);
>> ISCreateStride(PETSC_COMM_WORLD,length,div+begin,1,&isrow);
>> ierr = MatGetSubMatrix(*A,isrow,iscol,MAT_INITIAL_MATRIX,AA);
>> CHKERRQ(ierr);
>> else{
>> ISCreateStride(PETSC_COMM_SELF,final_size,begin,1,&iscol);
>> ISCreateStride(PETSC_COMM_SELF,final_size,begin,1,&isrow);
>> CHKERRQ(ierr);
>> The proper implementation would instead just be the following:
>> CHKERRQ(ierr);
>> On Thu, Jun 26, 2014 at 5:32 PM, Peter Brune <prbrune at gmail.com> wrote:
>>> MatGetSubMatrix() is collective on Mat and ISCreateXXX is collective on
>>> the provided comm, so the logic you have built to call it on one proc at a
>>> time is unnecessary at best and most likely incorrect and likely to produce
>>> strange results. You can forgo the if statement and loop over processors,
>>> create the ISes on the same comm as x, and then call MatGetSubMatrix() once.
>>> - Peter
>>> On Thu, Jun 26, 2014 at 4:26 PM, Arthur Kurlej <akurlej at gmail.com>
>>> wrote:
>>>> I cannot send the original code, but I reproduced the problem in
>>>> another code. I have attached a makefile the code, and the data for the x
>>>> vector and A matrix.
>>>> I think the problem may be with my ShortenMatrix function, but it's not
>>>> clear to me what exactly is going wrong and how to fix it. So I would
>>>> appreciate some assistance there.
>>>> Thanks,
>>>> Arthur
>>>> On Wed, Jun 25, 2014 at 6:24 PM, Barry Smith <bsmith at mcs.anl.gov>
>>>> wrote:
>>>>> Can you send the code that reproduces this behavior?
>>>>> Barry
>>>>> On Jun 25, 2014, at 4:37 PM, Arthur Kurlej <akurlej at gmail.com> wrote:
>>>>> > Hi Barry,
>>>>> > So for the matrix C that I am currently testing (size 162x162), the
>>>>> condition number is roughly 10^4.
>>>>> > For reference, I'm porting MATLAB code into PETSc, and for one
>>>>> processor, the PETSc b vector is roughly equivalent to the MATLAB b vector.
>>>>> So I know that for one processor, my program is performing as expected.
>>>>> > I've included examples below of values for b (also of size 162),
>>>>> ranging from indices 131 to 141.
>>>>> > #processors=1:
>>>>> > 0
>>>>> > 1.315217173959314e-20
>>>>> > 4.843201487740107e-17
>>>>> > 8.166104700666665e-14
>>>>> > 6.303834267553249e-11
>>>>> > 2.227932688485483e-08
>>>>> > # processors=2:
>>>>> > 5.480410831461926e-22
>>>>> > 2.892553944350444e-22
>>>>> > 7.524038923310717e-24
>>>>> > 7.524038923214420e-24
>>>>> > -3.340766769043093e-26
>>>>> > -7.558372155761972e-27
>>>>> > 5.551561288838557e-25
>>>>> > 5.550551546879874e-25
>>>>> > -1.579397982093437e-22
>>>>> > 2.655766754178065e-22
>>>>> > # processors = 4:
>>>>> > 2.892553944351728e-22
>>>>> > 7.524092205125593e-24
>>>>> > -2.584939414228212e-26
>>>>> > 0
>>>>> > 0
>>>>> > -1.245940797657998e-23
>>>>> > # processors = 8:
>>>>> > 2.892553944023035e-22
>>>>> > 7.524065744581494e-24
>>>>> > -2.250265175188197e-26
>>>>> > -6.543127892265160e-26
>>>>> > 1.544288143499193e-317
>>>>> > 8.788794008375919e-25
>>>>> > Thanks,
>>>>> > Arthur
>>>>> > On Wed, Jun 25, 2014 at 4:06 PM, Barry Smith <bsmith at mcs.anl.gov>
>>>>> wrote:
>>>>> > How different are the values in b? Can you send back a few
>>>>> examples of the different b’s? Any idea of the condition number of C?
>>>>> > Barry
>>>>> > On Jun 25, 2014, at 3:10 PM, Arthur Kurlej <akurlej at gmail.com>
>>>>> wrote:
>>>>> > > Hi all,
>>>>> > > While running my code, I have found that MatMult() returns
>>>>> different values depending on the number of processors I use (and there is
>>>>> quite the variance in the values).
>>>>> > > The setup of my code is as follows (I can go into more
>>>>> depth/background if needed):
>>>>> > > -Generate parallel AIJ matrix of size NxN, denoted as A
>>>>> > > -Retrieve parallel AIJ submatrix from the last N-1 rows&columns
>>>>> from A, denoted as C
>>>>> > > -Generate vector of length N-1, denoted as x
>>>>> > > -Find C*x=b
>>>>> > > I have already checked that A, C, and x are all equivalent when
>>>>> ran for any number of processors, it is only the values of vector b that
>>>>> varies.
>>>>> > > Does anyone have an idea about what's going on?
>>>>> > > Thanks,
>>>>> > > Arthur
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140626/a453450c/attachment.html>
