[petsc-users] Any examples to output a dmplex mesh as a hdf5 file?
Matthew Knepley
knepley at gmail.com
Wed Jun 25 10:46:36 CDT 2014
On Tue, Jun 24, 2014 at 7:50 AM, Fande Kong <fd.kong at siat.ac.cn> wrote:
> Hi all,
> There are some functions called DMPlex_load_hdf5 and DMPlex_view_hdf5 in
> petsc-dev. They are really good functions for outputting the solution as a
> hdf5 file in parallel. Are there any examples to show how to use these
> functions? Or are there some printed hdf5 and xdmf files that can be
> visualized by paraview?
This is very new code. I plan to write a manual section as soon as the
functionality solidifies. However, here is how I am currently using it.
Anywhere that you think about viewing something add
ierr = PetscObjectViewFromOptions((PetscObject) obj, prefix,
"-my_obj_view");CHKERRQ(ierr);
Then you can use the standard option style
-my_obj_view hdf5:my.h5
This extends nicely to many objects. Here is what I use for my magma
dynamics output
-dm_view hdf5:sol_solver_debug.h5 -magma_view_solution
hdf5:sol_solver_debug.h5::append -compaction_vec_view
hdf5:sol_solver_debug.h5:HDF5_VIZ:append
There is still a problem in that you cannot choose multiple formats using
this method. I am going to extend
the view options format
type:file:format:mode
to allow
type:file:format,format,format:mode
to handle this.
Matt
> Thanks,
> Fande,
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140625/a10b592e/attachment.html>
