[petsc-users] Unexpected "Out of memory error" with SLEPC
Mathis Friesdorf
mathisfriesdorf at gmail.com
Wed Jun 25 05:31:43 CDT 2014
Dear all,
after a very useful email exchange with Jed Brown quite a while ago, I was
able to find the lowest eigenvalue of a large matrix which is constructed
as a tensor product. Admittedly the solution is a bit hacked, but is based
on a Matrix shell and Armadillo and therefore reasonably fast. The problem
seems to work well for smaller systems, but once the vectors reach a
certain size, I get "out of memory" errors. I have tested the
initialization of a vector of that size and multiplication by the matrix.
This works fine and takes roughly 20GB of memory. There are 256 GB
available, so I see no reason why the esp solvers should complain. Does
anyone have an idea what goes wrong here? The error message is not very
helpful and claims that a memory is requested that is way beyond any
reasonable number: *Memory requested 18446744056529684480.*
Thanks and all the best, Mathis Friesdorf
*Output of the Program:*
*mathis at n180:~/localisation$ ./local_plus 27*
*System Size:
27--------------------------------------------------------------------------[[30558,1],0]:
A high-performance Open MPI point-to-point messaging modulewas unable to
find any relevant network interfaces:Module: OpenFabrics (openib) Host:
n180Another transport will be used instead, although this may result
inlower
performance.--------------------------------------------------------------------------[0]PETSC
ERROR: --------------------- Error Message
------------------------------------[0]PETSC ERROR: Out of memory. This
could be due to allocating[0]PETSC ERROR: too large an object or bleeding
by not properly[0]PETSC ERROR: destroying unneeded objects.[0]PETSC ERROR:
Memory allocated 3221286704 Memory used by process 3229827072[0]PETSC
ERROR: Try running with -malloc_dump or -malloc_log for info.[0]PETSC
ERROR: Memory requested 18446744056529684480![0]PETSC ERROR:
ERROR: Petsc Release Version 3.4.4, Mar, 13, 2014 [0]PETSC ERROR: See
docs/changes/index.html for recent updates.[0]PETSC ERROR: See
docs/faq.html for hints about trouble shooting.[0]PETSC ERROR: See
docs/index.html for manual pages.[0]PETSC ERROR:
ERROR: ./local_plus on a arch-linux2-cxx-debug named n180 by mathis Wed Jun
25 12:23:01 2014[0]PETSC ERROR: Libraries linked from
/home/mathis/bin_nodebug/lib[0]PETSC ERROR: Configure run at Wed Jun 25
00:03:34 2014[0]PETSC ERROR: Configure options
PETSC_DIR=/home/mathis/petsc-3.4.4 --with-debugging=1 COPTFLAGS="-O3
-march=p4 -mtune=p4" --with-fortran=0 -with-mpi=1
--with-mpi-dir=/usr/lib/openmpi --with-clanguage=cxx
--prefix=/home/mathis/bin_nodebug[0]PETSC ERROR:
ERROR: PetscMallocAlign() line 46 in
/home/mathis/petsc-3.4.4/src/sys/memory/mal.c[0]PETSC ERROR:
PetscTrMallocDefault() line 189 in
/home/mathis/petsc-3.4.4/src/sys/memory/mtr.c[0]PETSC ERROR:
VecDuplicateVecs_Contiguous() line 62 in src/vec/contiguous.c[0]PETSC
ERROR: VecDuplicateVecs() line 589 in
/home/mathis/petsc-3.4.4/src/vec/vec/interface/vector.c[0]PETSC ERROR:
EPSAllocateSolution() line 51 in src/eps/interface/mem.c[0]PETSC ERROR:
EPSSetUp_KrylovSchur() line 141 in
src/eps/impls/krylov/krylovschur/krylovschur.c[0]PETSC ERROR: EPSSetUp()
line 147 in src/eps/interface/setup.c[0]PETSC ERROR: EPSSolve() line 90 in
src/eps/interface/solve.c[0]PETSC ERROR: main() line 48 in
local_plus.cpp--------------------------------------------------------------------------MPI_ABORT
was invoked on rank 0 in communicator MPI_COMM_WORLD with errorcode
55.NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.You
may or may not see output from other processes, depending onexactly when
Open MPI kills
them.--------------------------------------------------------------------------*
*Output of make:*
*mathis at n180:~/localisation$ make local_plusmpicxx -o local_plus.o -c -Wall
-Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g -fPIC
-I/home/mathis/armadillo-4.300.8/include -lblas -llapack
-L/home/mathis/armadillo-4.300.8 -O3 -larmadillo -fomit-frame-pointer
-I/home/mathis/bin_nodebug/include -I/home/mathis/bin_nodebug/include
-I/usr/lib/openmpi/include -I/usr/lib/openmpi/include/openmpi
-D__INSDIR__= -I/home/mathis/bin_nodebug
-I/home/mathis/bin_nodebug//include -I/home/mathis/bin_nodebug/include
local_plus.cpplocal_plus.cpp:22:0: warning: "__FUNCT__" redefined [enabled
by default]In file included from
/home/mathis/bin_nodebug/include/petscvec.h:10:0, from
local_plus.cpp:10:/home/mathis/bin_nodebug/include/petscviewer.h:386:0:
note: this is the location of the previous definitiong++ -o local_plus
local_plus.o -Wl,-rpath,/home/mathis/bin_nodebug//lib
-L/home/mathis/bin_nodebug//lib -lslepc
-Wl,-rpath,/home/mathis/bin_nodebug/lib -L/home/mathis/bin_nodebug/lib
-lpetsc -llapack -lblas -lpthread -Wl,-rpath,/usr/lib/openmpi/lib
-L/usr/lib/openmpi/lib -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.7
-L/usr/lib/gcc/x86_64-linux-gnu/4.7 -Wl,-rpath,/usr/lib/x86_64-linux-gnu
-L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/lib/x86_64-linux-gnu
-L/lib/x86_64-linux-gnu -lmpi_cxx -lstdc++ -ldl -lmpi -lopen-rte -lopen-pal
-lnsl -lutil -lgcc_s -lpthread -ldl/bin/rm -f local_plus.o*
*Code:*
*//Author: Mathis Friesdorf//MathisFriesdorf at gmail.com
<MathisFriesdorf at gmail.com>static char help[] = "1D chain\n";#include
<iostream>#include <typeinfo>#include <armadillo>#include
<petscsys.h>#include <petscvec.h>#include <petscmat.h>#include
<slepcsys.h>#include <slepceps.h>#include <math.h>#include
<assert.h>PetscErrorCode BathMult(Mat H, Vec x,Vec y);PetscInt
L=30,d=2,dsys;PetscErrorCode ierr;arma::mat hint = "1.0 0 0 0.0; 0 -1.0 2.0
0; 0 2.0 -1.0 0; 0 0 0 1.0;";#define __FUNCT__ "main"int main(int argc,
char **argv){ Mat H; EPS eps; Vec xr,xi; PetscScalar kr,ki; PetscInt
j, nconv; L = strtol(argv[1],NULL,10); dsys = pow(d,L);
printf("%s","System Size: "); printf("%i",L); printf("%s","\n");
SlepcInitialize(&argc,&argv,(char*)0,help);
MatCreateShell(PETSC_COMM_WORLD,dsys,dsys,dsys,dsys,NULL,&H);
MatShellSetOperation(H,MATOP_MULT,(void(*)())BathMult); ierr =
MatGetVecs(H,NULL,&xr); CHKERRQ(ierr); ierr = MatGetVecs(H,NULL,&xi);
CHKERRQ(ierr); ierr = EPSCreate(PETSC_COMM_WORLD, &eps); CHKERRQ(ierr);
ierr = EPSSetOperators(eps, H, NULL); CHKERRQ(ierr); ierr =
EPSSetProblemType(eps, EPS_HEP); CHKERRQ(ierr); ierr =
EPSSetWhichEigenpairs(eps,EPS_SMALLEST_REAL); CHKERRQ(ierr); ierr =
EPSSetFromOptions( eps ); CHKERRQ(ierr); ierr = EPSSolve(eps);
CHKERRQ(ierr); ierr = EPSGetConverged(eps, &nconv); CHKERRQ(ierr); for
(j=0; j<1; j++) { EPSGetEigenpair(eps, j, &kr, &ki, xr, xi);
printf("%s","Lowest Eigenvalue: ");
PetscPrintf(PETSC_COMM_WORLD,"%9F",kr);
PetscPrintf(PETSC_COMM_WORLD,"\n"); } EPSDestroy(&eps); ierr =
SlepcFinalize(); return 0;}#undef __FUNCT__#define __FUNCT__
"BathMult"PetscErrorCode BathMult(Mat H, Vec x, Vec y){ PetscInt l; uint
slice; PetscScalar *arrayin,*arrayout; VecGetArray(x,&arrayin);
VecGetArray(y,&arrayout); arma::cube A = arma::cube(arrayin,1,1,pow(d,L),
/*copy_aux_mem*/false,/*strict*/true); arma::mat result =
arma::mat(arrayout,pow(d,L),1, /*copy_aux_mem*/false,/*strict*/true);
for (l=0;l<L-1;l++){ A.reshape(pow(d,L-2-l),pow(d,2),pow(d,l));
result.reshape(pow(d,L-l),pow(d,l)); for
(slice=0;slice<A.n_slices;slice++){ result.col(slice) +=
vectorise(A.slice(slice)*hint); } } arrayin = A.memptr(); ierr =
VecRestoreArray(x,&arrayin); CHKERRQ(ierr); arrayout = result.memptr();
ierr = VecRestoreArray(y,&arrayout); CHKERRQ(ierr);
PetscFunctionReturn(0);}#undef __FUNCT__*
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140625/c1720751/attachment-0001.html>
