[petsc-users] PETSC ERROR: PetscInitialize()
Oo
wumeng07maths at qq.com
Mon Jun 23 11:01:06 CDT 2014
Dear all,
Recently, I try to write a simple PETSC code for solving linear system problem.
At the beginning of main function, I use PetscInitialize().
However, when I run this program with "-start_in_debugger",
there is a PETSC ERROR caused by this line.
The PETSC ERROR is:
PETSC: Attaching gdb to /Users/meng/MyWork/BuildTools/bin/Parameterization of pid 7342 on display /tmp/launch-0lpYbb/org.macosforge.xquartz:0 on machine vis163d
Warning: locale not supported by Xlib, locale set to C
Do you have some suggestions to deal with this problem?
Thanks a lot!
Meng
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140624/61f61b94/attachment.html>
