[petsc-users] SNES divergence
Sang pham van
pvsang002 at gmail.com
Tue Jun 17 15:03:40 CDT 2014
Hi Barry,
I want to try the original version of Newton method, no line search nor
trust region...
Using grid sequencing confuses me at the point that I don't know explicitly
the final mesh size, or even if I can estimate the mesh size from the
input -snes_grid_sequence
n it's not so convenient for me when some of my routines need such info
from very first moment. I wish PETSc could allow us to pass in the finest
mesh for grid sequencing.
S,
On Tue, Jun 17, 2014 at 3:46 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Jun 17, 2014, at 2:30 PM, Sang pham van <pvsang002 at gmail.com> wrote:
> > Thanks Barry,
> > To refine the grid, I just put more points in the direction. For both
> fine and coarse meshes, I used simple initial guess (say constant values in
> whole domain for all variables).
> > By using grid sequencing, is the finest mesh is the one I first input
> the solver?
> No, you pass in the coarse one.
> > Can you let me know what options should I use to have pure Newton method?
> Not sure what you mean by pure Newton method, maybe without grid
> sequencing? It simply may not be possible to get convergence from a “poor”
> initial guess. One should always use grid sequencing if possible.
> Barry
> > S.
> > On Tue, Jun 17, 2014 at 3:20 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On Jun 17, 2014, at 2:12 PM, Sang pham van <pvsang002 at gmail.com> wrote:
> > > Hi,
> > > I am using DM structure and SNES to solve a 3D problem. In the problem
> I have 3 variables.
> > > I got SNES converged with a grid. Obtain result are physically right.
> However when I refine the grid, SNES does not always converge,
> > With the refined grid how are you starting the solution? Do you use
> the interpolated solution from the coarser grid (called grid sequencing) or
> just some “not good” initial guess?
> > > the reason of divergence is line search fail or linear solver failed.
> (I also tried other type of SNES, line search seems to be the one best fits
> my problem)
> > > Can you please give me a suggestion to figure out the problem with my
> solver? What options should I use to have pure Newton method in SNES? Is
> there any advance option I can use with line search to improve SNES
> convergence.
> > You should use grid sequencing, not only does it get convergence when
> you may not otherwise get it but it will also solve the problem faster.
> With PETSc DM you can use -snes_grid_sequence n or SNESSetGridSequence()
> in the code to do n levels of grid sequencing.
> > Barry
> > > Thank you very much.
> > > Minh.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140617/fa8a6ef0/attachment.html>
