[petsc-users] Irregular Matrix Partitioning problem
Brian Yang
brianyang1106 at gmail.com
Wed Jun 11 13:21:30 CDT 2014
Yes, thanks. So I am guessing that I need to take care of the first and
last rank and the middle part separately.
On Wed, Jun 11, 2014 at 11:51 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Jun 11, 2014 at 11:44 AM, Brian Yang <jyang29 at uh.edu> wrote:
>> Hi all,
>> To solve a linear system, Ax=b, I am trying to solve a irregular matrix
>> partitioning problem.
>> For example, I want to create a parallel sparse matrix A, which is a
>> square and 1000*1000.
>> Due to the requirements of the problem, for the first and last 100 rows,
>> I just want to put 1.0 in the main diagonal.
>> For the middle 800 rows, I will set other values around the main
>> diagonal. So what I want to do is that first and last computing node take
>> care of the first and last 100 rows and other nodes distribute the work in
>> between.
>> Is there any specific way to achieve this considering it's a parallel
>> matrix? If yes, should I also be care of the method to create the related
>> parallel vector?
> You are completely in charge of matrix partitioning when you call
> MatSetSizes()
> which sets the local and global sizes. Does this make sense?
> Thanks,
> Matt
>> Thanks.
>> Brian
> experiments lead.
> -- Norbert Wiener
Brian Yang
U of Houston
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140611/3d1598c8/attachment.html>
