[petsc-users] Problem with assembling 2 matrices
Jonas Mairhofer
mairhofer at itt.uni-stuttgart.de
Wed Jun 11 08:08:01 CDT 2014
Thank you!
And of course you are right, the more i work with PETSc the more I think
about changing from Fortran to C...
Am 11.06.2014 14:43, schrieb Matthew Knepley:
> On Wed, Jun 11, 2014 at 6:47 AM, Jonas Mairhofer
> <mairhofer at itt.uni-stuttgart.de
> <mailto:mairhofer at itt.uni-stuttgart.de>> wrote:
> Dear PETSc-Team,
> I am trying to set a global array X as column 0 of a dense matrix
> A and another global array Y as the first column of a second dense
> matrix B.
> Everything works perfectly fine in serial and parallel as long as
> I do this only for one of the matrices. However, when I try to do
> it for both matrices, the entries of matrix A seem to be
> overwritten by the values of matrix B.
> This is the output I get (first vectors X and Y, then matrices A
> and B):
> Vector Object:Vec_0x84000000_0 1 MPI processes
> type: mpi
> Process [0]
> 1
> 1
> 1
> Vector Object:Vec_0x84000000_1 1 MPI processes
> type: mpi
> Process [0]
> 2
> 2
> 2
> Matrix Object: 1 MPI processes
> type: seqdense
> 2.0000000000000000e+00 0.0000000000000000e+00 0.0000000000000000e+00
> type: seqdense
> I also attached the Fortran code:
> program main
> implicit none
> #include <finclude/petscsys.h>
> #include <finclude/petscvec.h>
> #include <finclude/petscdmda.h>
> #include <finclude/petscis.h>
> #include <finclude/petscmat.h>
> #include <finclude/petscksp.h>
> #include <finclude/petscpc.h>
> #include <finclude/petscsnes.h>
> #include <finclude/petscvec.h90>
> #include <finclude/petscdmda.h90>
> PetscInt i,j,m,n
> PetscErrorCode ierr
> PetscScalar one
> Mat A
> Mat B
> PetscInt row(3)
> DM da
> Vec X
> Vec Y
> PetscScalar,pointer :: X_pointer(:)
> PetscScalar,pointer :: Y_pointer(:)
> PetscInt xs,xm
> !Initialize
> call PetscInitialize(PETSC_NULL_CHARACTER,ierr)
> m = 3 !col
> n = 3 !row
> call DMDACreate1d(PETSC_COMM_WORLD, & !MPI communicator
> & DMDA_BOUNDARY_NONE, & !Boundary type at
> boundary of physical domain
> & n, & !global dimension of array (if negative
> number, then value can be changed by user via command line!)
> & 1, & !number of degrees of freedom per grid
> point (number of unknowns at each grid point)
> & 0, & !number of ghost points accessible to
> local vectors
> & PETSC_NULL_INTEGER, & !could be an array to
> specify the number of grid points per processor
> & da, & !the resulting distributed array object
> & ierr)
> call DMDAGetCorners(da, & !the distributed array
> & xs, & !corner index in x direction
> & PETSC_NULL_INTEGER, & !corner index in y direction
> & PETSC_NULL_INTEGER, & !corner index in z direction
> & xm, & !width of locally owned part in x
> direction
> & PETSC_NULL_INTEGER, & !width of locally owned part
> in y direction
> in z direction
> & ierr) !error check
> one = 1.0
> !set indices of matrix rows to be set
> Do i = xs,xs+xm-1
> row(i) = i
> END DO
> !Set up vector X and Matrix A
> call DMCreateGlobalVector(da,X,ierr)
> call VecSet(X,one,ierr) !set all entries of global
> array to 1
> call VecGetArrayF90(X,X_pointer,ierr)
> call
> MatCreateDense(PETSC_COMM_WORLD,PETSC_DECIDE,PETSC_DECIDE,n,m,PETSC_NULL_CHARACTER,A,ierr)
> The bug is here (and in the other create call). You should not be
> using PETSC_NULL_CHARACTER, but PETSC_NULL_SCALAR.
> This is a good reason for reconsidering the use of Fortran. It just
> cannot warn you about damaging errors like this.
> Thanks,
> Matt
> call
> MatSetValues(A,xm,row(xs:xs+xm-1),1,0,X_pointer(1:xm),INSERT_VALUES,ierr)
> call MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY,ierr)
> call MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY,ierr)
> !Set up vector Y and matrix B
> call DMCreateGlobalVector(da,Y,ierr)
> call VecSet(Y,2.d0*one,ierr) !set all entries of global
> array to 2
> call VecGetArrayF90(Y,Y_pointer,ierr)
> call
> MatCreateDense(PETSC_COMM_WORLD,PETSC_DECIDE,PETSC_DECIDE,n,m,PETSC_NULL_CHARACTER,B,ierr)
> call
> MatSetValues(B,xm,row(xs:xs+xm-1),1,0,Y_pointer(1:xm),INSERT_VALUES,ierr)
> call MatAssemblyBegin(B,MAT_FINAL_ASSEMBLY,ierr)
> call MatAssemblyEnd(B,MAT_FINAL_ASSEMBLY,ierr)
> !print out matrices and vectors to check entries
> call VecView(X,PETSC_VIEWER_STDOUT_WORLD,ierr)
> call VecView(Y,PETSC_VIEWER_STDOUT_WORLD,ierr)
> call MatView(A,PETSC_VIEWER_STDOUT_WORLD,ierr)
> call MatView(B,PETSC_VIEWER_STDOUT_WORLD,ierr)
> !free objects
> call VecRestoreArrayF90(X,X_pointer,ierr)
> call VecDestroy(X,ierr)
> call MatDestroy(A,ierr)
> call VecRestoreArrayF90(Y,Y_pointer,ierr)
> call VecDestroy(Y,ierr)
> call MatDestroy(B,ierr)
> call PetscFinalize(ierr)
> end
> Am I doing something wrong in my code?
> Thank you for your help!
> Jonas
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140611/9cc05df3/attachment-0001.html>
