[petsc-users] Problem in MPI communicator
Barry Smith
bsmith at mcs.anl.gov
Tue Jun 10 13:13:28 CDT 2014
You have a bug in you code unrelated the the reordering. Note the variable x is declared in your module and then again inside the subroutine init. Thus when init does call VecDuplicate(b,x,ierr) it sets the value of the inner x, not the outer x.
It would be nice if the Fortran compilers warned you about variables like this.
Barry
module poisson_solver
implicit none
#include <finclude/petsc.h90>
private
Vec :: b, x
Mat :: A
KSP :: ksp
DM :: da
PetscScalar :: dxdyqdz, dxdzqdy, dydzqdx
integer, parameter :: dp = kind(0.0D0)
logical :: reset = .false.
integer, parameter :: max_number_iter = 15
public init, finalize, solve
save b, x, da, A, ksp, dxdyqdz, dxdzqdy, dydzqdx, reset
contains
subroutine init(px,py,pz,nx,ny,nz,nxl,nyl,nzl)
integer, intent(in) :: px,py,pz,nx,ny,nz,nxl,nyl,nzl
PetscInt :: nnx(px), nny(py), nnz(pz)
PetscErrorCode :: ierr
MatNullSpace :: nullspace
integer :: newcomm,rank, newrank, x, y, z
PetscInt :: xs,xm,ys,zs,ym,zm
call mpi_comm_rank(MPI_COMM_WORLD, rank, ierr)
! if(PETSC_COMM_WORLD/=MPI_COMM_WORLD) write(*,*) 'Communicator problem'
x = rank / (pz*py);
y = mod(rank,(pz*py))/pz
z = mod(mod(rank,pz*py),pz)
newrank = z*py*px + y*px + x;
call mpi_comm_split(MPI_COMM_WORLD, 1, newrank, newcomm, ierr)
PETSC_COMM_WORLD = newcomm
call PetscInitialize(PETSC_NULL_CHARACTER,ierr)
! Create DM context
nnx = nxl
nny = nyl
nnz = nzl
call DMDACreate3d( PETSC_COMM_WORLD , &
& DMDA_BOUNDARY_PERIODIC , DMDA_BOUNDARY_PERIODIC, &
& DMDA_BOUNDARY_PERIODIC , DMDA_STENCIL_STAR, &
& nx, ny, nz, px, py, pz, 1, 1, nnx, nny, nnz, da , ierr)
call DMDASetInterpolationType(da, DMDA_Q0, ierr);
call DMCreateGlobalVector(da,b,ierr) ! Create Global Vectors
On Jun 10, 2014, at 2:19 AM, Michele Rosso <mrosso at uci.edu> wrote:
> Barry,
> thanks for your reply. I tried to do as you suggested but it did not solve anything as you expected.
> I attached a minimal version on my code. The file "test.f90" contains both a main program and a module. The main program is set to run on 8 processors, but you can easily change the parameters in it. It seems like the issue affects the
> DMGlobalToLocalBegin() subroutine in my subroutine restore_rhs().
> Hope this helps.
> Thanks,
> Michele
> On 06/09/2014 09:06 PM, Barry Smith wrote:
>> This may not be the only problem but you can never ever ever change PETSC_COMM_WORLD after PetscInitialize(). You need to
>> 1) call MPI_Init() your self first then
>> 2) do your renumbering using MPI_COMM_WORLD, not PETSC_COMM_WORLD
>> 3) set PETSC_COMM_WORLD to your new comm
>> 4) call PetscInitialize().
>> Let us know how it goes, if you still get failure send the entire .F file so we can run it to track down the issue.
>> Barry
>> On Jun 9, 2014, at 10:56 PM, Michele Rosso <michele.rosso84 at gmail.com> wrote:
>>> Hi,
>>> I am trying to re-number the mpi ranks in order to have the domain decomposition obtained from DMDACreate3D() match the default decomposition provided by MPI_Cart_create(). I followed the method described in the FAQ:
>>> x = rank / (pz*py);
>>> call mpi_comm_split(PETSC_COMM_WORLD, 1, newrank, newcomm, ierr)
>>> I tried to run my code (it works fine with the standard PETSc decomposition) with the new decomposition but I received the error message; I attached the full output. I run with only one processor to test the setup and I commented all the lines where I actually insert/get data into/from the PETSc arrays.
>>> Could you please help fixing this?
>>> Thanks,
>>> Michele
>>> <outfile.txt>
> <test.f90>
