[petsc-users] DIVERGED_INDEFINITE_PC in algebraic multigrid
Mark Adams
mfadams at lbl.gov
Mon Jun 2 01:34:50 CDT 2014
On Sun, Jun 1, 2014 at 10:46 PM, Michele Rosso <mrosso at uci.edu> wrote:
> Mark,
> I tried to reset every-time: the number of iterations is now constant
> during the whole simulation!
> I tried GMG instead of AMG as well: it works in this case too, so the
> trick was to reset the ksp object each time.
> As you predicted, each solve takes longer since the ksp has to be setup
> again. I noticed that the time increase is larger than 2x, particularly for
> large grids.
> I need to optimize the solve now, maybe by resetting only when needed.
> Could you help me with that please?
This logic that you put in your code. You can setup a variable for a
frequency of resetting,
if (mod(++count,reset_factor)==0) solver. KSPReset(ksp); // or whatever.
You could check the iteration count after a solve and if it is too high.
> Thanks,
> Michele
> On 05/28/2014 07:54 PM, Mark Adams wrote:
> On Mon, May 26, 2014 at 12:20 PM, Michele Rosso <mrosso at uci.edu> wrote:
>> Mark,
>> thank you for your input and sorry my late reply: I saw your email only
>> now.
>> By setting up the solver each time step you mean re-defining the KSP
>> context every time?
> THe simplest thing is to just delete the object and create it again.
> THere are "reset" methods that do the same thing semantically but it is
> probably just easier to destroy the KSP object and recreate it and redo
> your setup code.
>> Why should this help?
> AMG methods optimized for a particular operator but "stale" setup data
> often work well on problems that evolve, at least for a while, and it saves
> a lot of time to not redo the "setup" every time. How often you should
> "refresh" the setup data is problem dependant and the application needs to
> control that. There are some hooks to fine tune how much setup data is
> recomputed each solve, but we are just trying to see if redoing the setup
> every time helps. If this fixes the problem then we can think about cost.
> If it does not fix the problem then it is more serious.
>> I will definitely try that as well as the hypre solution and report back.
>> Again, thank you.
>> Michele
>> On 05/22/2014 09:34 AM, Mark Adams wrote:
>> If the solver is degrading as the coefficients change, and I would assume
>> get more nasty, you can try deleting the solver at each time step. This
>> will be about 2x more expensive, because it does the setup each solve, but
>> it might fix your problem.
>> You also might try:
>> -pc_type hypre
>> -pc_hypre_type boomeramg
>> On Mon, May 19, 2014 at 6:49 PM, Jed Brown <jed at jedbrown.org> wrote:
>>> Michele Rosso <mrosso at uci.edu> writes:
>>> > Jed,
>>> > thank you very much!
>>> > I will try with ///-mg_levels_ksp_type chebyshev -mg_levels_pc_type
>>> > sor/ and report back.
>>> > Yes, I removed the nullspace from both the system matrix and the rhs.
>>> > Is there a way to have something similar to Dendy's multigrid or the
>>> > deflated conjugate gradient method with PETSc?
>>> Dendy's MG needs geometry. The algorithm to produce the interpolation
>>> operators is not terribly complicated so it could be done, though DMDA
>>> support for cell-centered is a somewhat awkward. "Deflated CG" can mean
>>> lots of things so you'll have to be more precise. (Most everything in
>>> the "deflation" world has a clear analogue in the MG world, but the
>>> deflation community doesn't have a precise language to talk about their
>>> methods so you always have to read the paper carefully to find out if
>>> it's completely standard or if there is something new.)
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140601/1c82ada9/attachment-0001.html>
