[petsc-users] Configure with IBM XL toolchain quietly ignores request to build shared libraries
Satish Balay
balay at mcs.anl.gov
Wed Jul 30 20:27:33 CDT 2014
On Wed, 30 Jul 2014, Alp Dener wrote:
> Hi,
> I’m trying to build PETSc 3.4.5 on an IBM BlueGene/Q at the moment using the XL toolchain. I need to build the PETSc shared library and to accomplish that, I use the following configure options:
> ./configure \
> --with-shared-libraries=1 \
> --with-debugging=1 \
> --with-fortran-interfaces=1 \
> --with-mpi=/bgsys/drivers/ppcfloor/comm \
> --with-blas-lib="-L/gpfs/u/software/bgq/lapack/xl/3.5.0/lib -lblas" \
> --with-lapack-lib="-L/gpfs/u/software/bgq/lapack/xl/3.5.0/lib -llapack" \
> --with-metis-include=/gpfs/u/software/bgq/parmetis/xl/4.0.2/include \
> --with-metis-lib="-L/gpfs/u/software/bgq/parmetis/xl/4.0.2/lib -lmetis" \
> --with-parmetis-include=/gpfs/u/software/bgq/parmetis/xl/4.0.2/include \
> --with-parmetis-lib="-L/gpfs/u/software/bgq/parmetis/xl/4.0.2/lib -lparmetis" \
> --download-superlu=/gpfs/u/barn/ODLC/shared/src/PETSc/superlu_4.3.tar.gz \
> --download-superlu_dist=/gpfs/u/barn/ODLC/shared/src/PETSc/superlu_dist_3.3.tar.gz \
> --prefix=/gpfs/u/barn/ODLC/shared/xl/petsc/3.4.5 \
> --PETSC_ARCH=xl-dbg \
> FFLAGS="-qextname”
> Despite specifying the “—with-shared-libraries” option, the configuration report shows “shared libraries : disabled”. The configure log doesn’t appear to contain any warnings or errors about this (or maybe I couldn’t find it).
> Normally, compiling shared objects with XL compilers require a -qmkshrobj flag. I’ve attempted passing this to PETSc using LDFLAGS but this causes the configuration to fail with an error, stating that it cannot run executables created with the C compiler.
> This problem seems to be persistent across a number of PETSc versions. I need to use 3.4.5 for compatibility reasons, but I’ve attempted the same build with 3.5, 3.3 and 3.0 with the exact same results.
> Would really appreciate it if anyone can offer guidance on how to force PETSc to build its shared library. The configure log from the above options is provided in the attachment.
Shared libraries with IBM compilers is something I've not tired. If its just a matter
of using '-qmkshrobj' - you could try to build it manually - and see if it works.
[when I try it I get errors.]
Satish
[balay at vestalac1 ~]$ cd petsc/arch-xl-opt-nopkg/lib/
[balay at vestalac1 lib]$ ar x libpetsc.a
[balay at vestalac1 lib]$ mpixlc -qmkshrobj -o libpetsc.so *.o
[balay at vestalac1 lib]$ file libpetsc.so
libpetsc.so: ELF 64-bit MSB shared object, 64-bit PowerPC or cisco 7500, version 1 (SYSV), dynamically linked, not stripped
[balay at vestalac1 lib]$ mv libpetsc.a libpetsc-bkp.a
[balay at vestalac1 lib]$ cd $PETSC_DIR
[balay at vestalac1 petsc]$ cd src/ksp/ksp/examples/tutorials/
[balay at vestalac1 tutorials]$ make ex2
mpixlc_r -o ex2.o -c -qpic -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -I/home/balay/petsc/include -I/home/balay/petsc/arch-xl-opt-nopkg/include -I/bgsys/drivers/V1R2M1/ppc64/comm/include -I/bgsys/drivers/V1R2M1/ppc64/comm/lib/gnu -I/bgsys/drivers/V1R2M1/ppc64 -I/bgsys/drivers/V1R2M1/ppc64/comm/sys/include -I/bgsys/drivers/V1R2M1/ppc64/spi/include -I/bgsys/drivers/V1R2M1/ppc64/spi/include/kernel/cnk `pwd`/ex2.c
mpixlc_r -qpic -O3 -qhot=level=0 -qsimd=auto -qmaxmem=-1 -qstrict -qstrict_induction -o ex2 ex2.o -L/home/balay/petsc/arch-xl-opt-nopkg/lib -lpetsc -L/soft/libraries/alcf/current/xl/LAPACK/lib -llapack -L/soft/libraries/alcf/current/xl/BLAS/lib -lblas -lpthread -L/bgsys/drivers/V1R2M1/ppc64/comm/lib -L/bgsys/drivers/V1R2M1/ppc64/comm/lib64 -L/bgsys/drivers/V1R2M1/ppc64/spi/lib -L/bgsys/drivers/V1R2M1/ppc64/comm/sys/lib -L/soft/compilers/ibmcmp-may2014/xlsmp/bg/3.1/bglib64 -L/soft/compilers/ibmcmp-may2014/xlmass/bg/7.3/bglib64 -L/soft/compilers/ibmcmp-may2014/vac/bg/12.1/bglib64 -L/soft/compilers/ibmcmp-may2014/vacpp/bg/12.1/bglib64 -L/bgsys/drivers/toolchain/V1R2M1_base-efix033/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.6 -L/bgsys/drivers/toolchain/V1R2M1_base-efix033/gnu-linux/lib/gcc -L/bgsys/drivers/toolchain/V1R2M1_base-efix033/gnu-linux/powerpc64-bgq-linux/lib -L/soft/compilers/ibmcmp-may2014/xlf/bg/14.1/bglib64 -Wl,-rpath,/soft/compilers/ibmcmp-may2014/lib64/bg/bglib64 -lmpichf90-gcc -lxlf90_r -lxlomp_ser -lxlfmath -lm -lmpichcxx-gcc -libmc++ -ldl -lmpich-gcc -lopa-gcc -lmpl-gcc -lpami-gcc -lSPI -lSPI_cnk -lrt -lpthread -lstdc++ -lxlopt -lxl -lnss_files -lnss_dns -lresolv -lgcc_eh -ldl
/bgsys/drivers/ppcfloor/gnu-linux/powerpc64-bgq-linux/bin/ld: cannot find -lpetsc
make: [ex2] Error 1 (ignored)
/bin/rm -f ex2.o
