[petsc-users] Shell matrix in petsc4py?
Gaetan Kenway
gaetank at gmail.com
Wed Jul 30 18:48:00 CDT 2014
Hi Jonathan
I've successfully used petsc shell matrices from Python. There is an
example of how to do it in demo/poisson2d/poisson2d.py. The example is a
little sparse, but it has all the important information. The most important
is to define the
def mult(self, mat, x, y):
routine inside of a Python class that is given in mat.setPythonContext()
command.
Hope that helps.
Gaetan
On Wed, Jul 30, 2014 at 7:29 PM, Jonathan Tu <jonathantu at gmail.com> wrote:
> Hi,
> I would like to solve a large linear system. I have a linear operator
> that operates on a "state" vector. The linear operator does things like
> take the sum of the state elements, take the cross product of the state
> with a known vector, and then multiply the state by a large (distributed)
> matrix. You could imagine it like this:
> [sum of elements, cross product with other vector, multiplication with
> large matrix] = A * x
> Now, I realize it is possible to implement all of this using a large
> matrix. After all, these are all linear operations. However, I thought it
> might be faster and less error-prone to use some of numpy's built-in
> operations, for the sums and cross products, and only use a distributed
> matrix for the last part of the output.
> From the PETSc documentation, it seems like a matrix shell would be
> perfect for this. I could define my own mult operator that does all of
> these things in steps, using built-in numpy functions when appropriate and
> direct matrix multiplication when appropriate. However, I cannot figure
> out how to do this in petsc4py. I found somewhere online that perhaps
> createPython is the way I need to go about this, but I couldn't figure out
> the details.
> Any ideas?
> Jonathan Tu
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140730/db128f5e/attachment.html>
