[petsc-users] Error with SNESVISetVariableBounds
Tue Jul 29 13:21:45 CDT 2014
On Tue, Jul 29, 2014 at 1:19 PM, Que Cat <quecat001 at gmail.com> wrote:
> I also used the ghosted vector (VecCreateGhost). Does it have any relation
> to the DMGetGlobalVector() ?
We clearly have the problem that a full stack in not being printed. I am
open to the idea that it is a problem
in our SNESVI, but we need a way to track it down. Could you produce a test
example small enough to send
us?
     Matt
> Que
> On Tue, Jul 29, 2014 at 12:42 PM, Que Cat <quecat001 at gmail.com> wrote:
>> Yes, I don't use DM at all and no information about who is calling
>> DMGetGlobalVector(). When I use snesnewtonls (without constraint on the
>> solution), the code worked fine. I only changed one of code :
>> ierr = SNESSetType(snes,SNESNEWTONTR );CHKERRQ(ierr);
>> --- > ierr = SNESSetType(snes,SNESVINEWTONSSLS );CHKERRQ(ierr);
>> and added :
>> ierr = SNESVISetVariableBounds(snes, low_b, up_b);CHKERRQ(ierr);
>> and the errors appeared.
>> Que
>> On Tue, Jul 29, 2014 at 12:29 PM, Jed Brown <jed at jedbrown.org> wrote:
>>> Que Cat <quecat001 at gmail.com> writes:
>>> > Hi Jed,
>>> > I removed only one line from the error message that indicated the
>>> > unnecessary information like directory path, program name, processor
>>> type.
>>> > In this problem, I created the vector using VecCreateMPI, not with DM.
>>> Does
>>> > it cause such problem? I have the unstructured grid and can not use DM
>>> There should be more lines, like who is calling DMGetGlobalVector().
>>> Maybe that is your code and you don't check errors, but why are you
>>> calling that function if you don't use DM (so the DMShell is created
>>> automatically)?
>>> > Que
>>> > On Tue, Jul 29, 2014 at 12:09 PM, Jed Brown <jed at jedbrown.org> wrote:
>>> >> > Dear Petsc-Users,
>>> >> > I called the SNESVISetVariableBounds
>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/SNES/SNESVISetVariableBounds.html#SNESVISetVariableBounds
>>> >> > and
>>> >> > received the following error:
>>> >> > [0]PETSC ERROR: Must call DMShellSetGlobalVector() or
>>> >> > DMShellSetCreateGlobalVector()
>>> >> > [0]PETSC ERROR: See
>>> http://www.mcs.anl.gov/petsc/documentation/faq.html
>>> >> for
>>> >> > trouble shooting.
>>> >> > [0]PETSC ERROR: Petsc Release Version 3.5.0, Jun, 30, 2014
>>> >> It looks like you are truncating the error message.  Please don't ever
>>> >> do that.
>>> >> > [0]PETSC ERROR: Configure options --with-x=0 -with-pic
>>> --with-external-packages-dir=/opt/apps/intel13/mvapich2_1_9/petsc/3.5/externalpackages
>>> >> > --with-mpi-compilers=1 --with-mpi-dir=/opt/apps/intel13/mvapich2/1.9
>>> >> > --with-scalar-type=real --with-shared-libraries=1 --with-matlab
>>> >> > --with-matlab-dir=/work/apps/matlab/2013a --with-spai=1
>>> --download-spai
>>> >> > --with-hypre=1 --download-hypre --with-mumps=1 --download-mumps
>>> >> > --with-scalapack=1 --download-scalapack --with-blacs=1
>>> --download-blacs
>>> >> > --with-spooles=1 --download-spooles --with-superlu=1
>>> --download-superlu
>>> >> > --with-superlu_dist=1 --download-superlu_dist --with-parmetis=1
>>> >> > --download-parmetis --with-metis=1 --download-metis --with-hdf5=1
>>> >> > --with-hdf5-dir=/opt/apps/intel13/mvapich2_1_9/phdf5/1.8.9
>>> >> > --with-debugging=no
>>> --with-blas-lapack-dir=/opt/apps/intel/13/composer_xe_2013.3.163/mkl/lib/intel64
>>> >> > --with-mpiexec=mpirun_rsh --COPTFLAGS= --CXXOPTFLAGS= --FOPTFLAGS=
>>> >> > 0]PETSC ERROR: #1 DMCreateGlobalVector_Shell() line 245 in
>>> /opt/apps/intel13/mvapich2_1_9/petsc/3.5/src/dm/impls/shell/dmshell.c
>>> >> > [0]PETSC ERROR: #2 DMCreateGlobalVector() line 681 in
>>> >> > /opt/apps/intel13/mvapich2_1_9/petsc/3.5/src/dm/interface/dm.c
>>> >> > [0]PETSC ERROR: #3 DMGetGlobalVector() line 154 in
>>> >> > /opt/apps/intel13/mvapich2_1_9/petsc/3.5/src/dm/interface/dmget.c
>>> >> > Could anyone give me a hint to the source of the error? Thank you.
>>> >> > Que
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140729/df2c3b97/attachment.html>
