[petsc-users] Poor multigrid convergence in parallel
Jed Brown
jed at jedbrown.org
Tue Jul 29 10:58:37 CDT 2014
Lawrence Mitchell <lawrence.mitchell at imperial.ac.uk> writes:
> No, I'm L2-projecting (with mass-lumping) for the restriction. So if I
> weren't lumping, I think this is the dual of the prolongation.
A true L2 projection is a dense operation (involves the inverse mass
matrix). But here, we're trying to map residuals, not states, so
_integration_ rather than "projection" is the desired operation.
Integration is the transpose of your prolongation. We can do a precise
analysis, but I expect that you'll see slightly better convergence if
you modify this operator.
I would also recommend trying FMG soon. You should be able to converge
in one F-cycle, and that will be faster than V-cycles with Krylov.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140729/bd29fb46/attachment.pgp>
