[petsc-users] force KSP to perform at least a single iteration
Jed Brown
jed at jedbrown.org
Mon Jul 28 10:37:50 CDT 2014
Rolf Kuiper <kuiper at mpia.de> writes:
> I need this to e.g. solve a linear system of equations several times
> (as the physical system proceeds in time); during a single call /
> timestep, the system, might not change stronger than the RTOL in use,
> but in the long-run (several hundreds to thousands of calls), the
> system will actually change by several RTOL; nonetheless, the default
> KSP solver stops without doing any iteration (= 0), i.e. the system
> does not change at all.
When you use -ksp_converged_reason, is it completing due to RTOL or
ATOL? For transient problems, it's often good to set an absolute
tolerance.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140728/fddf9522/attachment.pgp>
