[petsc-users] why a certain option cannot be used
Sun, Hui hus003 at ucsd.edu
Wed Jul 23 12:36:02 CDT 2014
Dear Jed, Dave, Matt and others,
I just want to let you know that I have successfully applied fieldsplit and Schur complement into the project I'm working on. The code I start up with is ex70.c under SNES/examples/tutorial. Thank you all for your kindly help.
Best,
Hui
Sent: Friday, July 18, 2014 10:23 AM
To: Sun, Hui; Dave May
Cc: petsc-users at mcs.anl.gov
Subject: RE: [petsc-users] why a certain option cannot be used
"Sun, Hui" <hus003 at ucsd.edu> writes:
> Thank you Jed. After reading ex15, I got some idea of how to define the PCShell with KSP solver. However, I want to verify with you if the following procedure is normally what one should do.
> 1. Define a ShellPC struct, which includes a MAT object, say Pmat, and a KSP object, say innerKsp.
The context should indeed contain innerKSP.  The ShellPC may not need a
Mat (you can just pass it down to innerKSP).
> 2. PCSetType(pc, PCSHELL)
> 3. Create a context for the user defined PC. It is here that we call KSPSetOperators(innerKsp, Pmat, Pmat)
You can do it eagerly or via PCShellSetSetUp(), if you want the shell PC
to be more reusable/independent.
> 4. Set the user defined routine for applying the preconditioner. It is in this user-define routine that we call KSPSolver(innerKsp, r, y)
> I'm wondering the way I set up the inner KSP for the PC is standard? Thank you!
Pretty much.
