[petsc-users] MPI-IO
Jed Brown
jed at jedbrown.org
Mon Jul 21 10:55:52 CDT 2014
Barry Smith <bsmith at mcs.anl.gov> writes:
> We should change this to use a PetscViewerFormat instead of special casing it.
It's not really a "format", but it would be nice to have a common way to
address other viewer implementations.
>> PETSc devs, do you suppose MPI-IO support is stable enough that we could
>> make this a default?
> It is not so much a question of stability, it is more a question
> of (I believe) MPI IO is just loads slower for what might normal
> PETSc users use, it only pays off for large numbers of nodes.
Do we have current data demonstrating that this is still the case? It's
really a failure of the implementations if they can't fall back to the
dumbest mechanism when it's faster.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140721/3b0dd050/attachment.pgp>
