[petsc-users] __FUNCT__ does not agree with __FUNCTION__
Dominik Szczerba
dominik at itis.ethz.ch
Sun Jul 20 09:00:57 CDT 2014
__FUNCT__="ScalarSolver::SetupStiffnessMatrix"
does not compile. I assume you meant:
#undef __FUNCT__
#define __FUNCT__ "ScalarSolver::SetupCoefficientMatrix"
but now I do not get exact lines leading to a crash. Also skipping
__FUNCT__ completely does not help. It used to work before, I can not
figure out what has changed. Using MSVC 2010.
Please advise...
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
probably memory access out of range
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[0]PETSC ERROR:
or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory
corruption error
[0]PETSC ERROR: likely location of problem given in stack below
[0]PETSC ERROR: --------------------- Stack Frames
[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[0]PETSC ERROR: INSTEAD the line number of the start of the function
[0]PETSC ERROR: is given.
[0]PETSC ERROR: [0] ScalarSolver::SetupCoefficientMatrix line 1216
"unknowndirectory/"..\..\..\Source\ScalarSolver\ScalarSolver.x\ScalarSolver.cpp
[0]PETSC ERROR: [0] ScalarSolver::Initialize line 181
[0]PETSC ERROR: [0] ScalarSolverXMLDriver::Initialize line 74
"unknowndirectory/"..\..\..\Source\ScalarSolver\ScalarSolver.x\ScalarSolverXMLDriver.cpp
[0]PETSC ERROR: [0] ScalarSolverXMLDriver::ScalarSolverXMLDriver line 53
[0]PETSC ERROR: --------------------- Error Message
2014-07-09 5:21 GMT+02:00 Jed Brown <jed at jedbrown.org>:
> Satish Balay <balay at mcs.anl.gov> writes:
> > One can skip __FUNCT__ alltogether in user sourcefiles [assuming you
> > have a c99 compiler] - as __func__ would automatically be used
> > by the petsc macros [in includes]
> You can literally skip it everywhere, C99 or not, and PETSc will not
> issue these warnings. If __func__ is not available, traces will say
> "User defined function".
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140720/84f823bf/attachment.html>
