[petsc-users] Symmetric non-positive definite system
Matthew Knepley
knepley at gmail.com
Fri Jul 18 13:22:30 CDT 2014
On Fri, Jul 18, 2014 at 1:19 PM, Chetan Jhurani <chetan.jhurani at gmail.com>
wrote:
> > From: Jed Brown <jed at jedbrown.org>
> > Jozsef Bakosi <jbakosi at lanl.gov> writes:
> > > Hi folks,
> > > I have a matrix as a result of a finite element discretization of the
> Poisson
> > > operator and associated right hand side. As it turns out, the matrix is
> > > symmetric but not positive definite since it has at least two negative
> small
> > > eigenvalues. I have been solving this system without problem using the
> conjugate
> > > gradients (CG) algorithm with ML as a preconditioner, but I'm
> wondering why it
> > > works.
> > Is the preconditioned matrix
> > P^{-1/2} A P^{-T/2}
> > positive definite?
> This does not answer the original question regarding CG/ML, but
It is possible for CG to convergence with an indefinite matrix, but it is
also
possible for it to fail.
Matt
> will reduce some debugging work. P^{-1/2} A P^{-T/2} cannot be
> positive definite since A is not positive definite. This is due
> to Sylvester's inertia theorem.
> http://books.google.com/books?id=P3bPAgAAQBAJ&pg=PA202
> Applied Numerical Linear Algebra By James W. Demmel, p 202
> Chetan
> > > Shouldn't CG fail for a non-positive-definite matrix? Does PETSc do
> some
> > > additional magic if it detects that the dot-product in the CG
> algorithm is
> > > negative? Does it solve the system using the normal equations, A'A,
> instead?
> > CG will report divergence in case a direction of negative curvature is
> > found.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140718/64b4e9d4/attachment.html>
