[petsc-users] MatSetNearNullSpace and BoomerAMG ?
Natacha BEREUX natacha.bereux at gmail.com
Fri Jul 18 08:25:23 CDT 2014
OK, thanks a lot Jed for your quick answer.
I have a second question on multigrid :
I define a matrix block size (equal to 3). Is this mandatory for any type
of multigrid preconditioner (BoomerAMG, ML and GAMG) ?
Or is it only  required with  ML and GAMG ?
Best regards
Natacha
On Fri, Jul 18, 2014 at 3:07 PM, Jed Brown <jed at jedbrown.org> wrote:
> Natacha BEREUX <natacha.bereux at gmail.com> writes:
> > Dear all,
> > I am testing three multigrid preconditionners: BoomerAMG, ML and GAMG on
> a
> > 3D elasticity problem (a cube with prescribed displacement on upper and
> > lower faces).
> > I set the null space by calling  MatNullSpaceCreateRigidBody and then
> > MatSetNearNullSpace).
> > I see a difference (about half iterations) for ML and GAMG but nothing
> > happens with BoomerAMG (same number of iterations with and without
> setting
> > the NearNullspace).
> That's expected because BoomerAMG does not use any such information
> (though the algorithm might be extended in the future so that those
> vectors become seed vectors for Bootstrap AMG, for example; I don't know
> if the BoomerAMG developers have any interest in implementing this).
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140718/6da7c72d/attachment.html>
