[petsc-users] MatViewAndMatlabLoad
Jed Brown jed at jedbrown.org
Fri Jul 18 08:04:45 CDT 2014
Oo       <wumeng07maths at qq.com> writes:
> Dear All,
> I met a problem about using "load()" function in Matlab to read a m file which describes a PETSc Mat object by :
>  //Save coeff_matrix as a matlab file PetscViewer viewer; PetscViewerASCIIOpen(PETSC_COMM_WORLD,"CoeffMatrixFileName.m",&viewer); PetscViewerSetFormat(viewer, PETSC_VIEWER_ASCII_MATLAB); MatView(coeff_matrix, viewer); PetscViewerDestroy(&viewer);
> In Matlab, I used:M=load("CoeffMatrixFileName.m") and I got an error.The error is:???Error using ===> loadNumber of columns on line 2 of ASCII file CoeffMatrixFileName.m must be the same as previous lines.
What does the file look like?
Note that we recommend using a binary viewer and
  A = PetscBinaryRead('binaryoutput')
to read in MATLAB.  It is more accurate and much faster.
> Do you know how to deal with that error?Or Do you think there is some a mistake in my output of PETSc Mat Obj with the PetscViewer?
> Thank you~:)
> Meng
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140718/628279fc/attachment.pgp>
