[petsc-users] Symmetric non-positive definite system solved with CG+ML - why does it not fail?
Jed Brown jed at jedbrown.org
Thu Jul 17 18:06:18 CDT 2014
Jozsef Bakosi <jbakosi at lanl.gov> writes:
>> > Hi folks,
>> > I have a matrix as a result of a finite element discretization of the Poisson
>> > operator and associated right hand side. As it turns out, the matrix is
>> > symmetric but not positive definite since it has at least two negative small
>> > eigenvalues. I have been solving this system without problem using the conjugate
>> > gradients (CG) algorithm with ML as a preconditioner, but I'm wondering why it
>> > works.
>> Is the preconditioned matrix
>>   P^{-1/2} A P^{-T/2}
>> positive definite?
> How would you extract P?
You don't, you apply P^{-1}.  Have you checked whether your solution is
accurate?  If you want to study the operator further, you can consider
the generalized eigenvalue problem
  A x = \lambda P x
Note that eigensolvers can work on this system while only being able to
apply A and P^{-1}.  You can find any negative eigenvalues of that
problem, get the eigenvectors, and see how it compares to the
unpreconditioned case.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140717/cfbdae16/attachment.pgp>
