[petsc-users] Symmetric non-positive definite system solved with CG+ML - why does it not fail?
Jed Brown
jed at jedbrown.org
Thu Jul 17 17:41:33 CDT 2014
Jozsef Bakosi <jbakosi at lanl.gov> writes:
> Hi folks,
> I have a matrix as a result of a finite element discretization of the Poisson
> operator and associated right hand side. As it turns out, the matrix is
> symmetric but not positive definite since it has at least two negative small
> eigenvalues. I have been solving this system without problem using the conjugate
> gradients (CG) algorithm with ML as a preconditioner, but I'm wondering why it
> works.
Is the preconditioned matrix
P^{-1/2} A P^{-T/2}
positive definite?
> Shouldn't CG fail for a non-positive-definite matrix? Does PETSc do some
> additional magic if it detects that the dot-product in the CG algorithm is
> negative? Does it solve the system using the normal equations, A'A, instead?
CG will report divergence in case a direction of negative curvature is
found.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140717/8b2203f0/attachment.pgp>
