[petsc-users] why a certain option cannot be used
Klaij, Christiaan
C.Klaij at marin.nl
Thu Jul 17 01:41:12 CDT 2014
Just for future reference, below are the correct comments that
should be at the top of ex70.
(Jed, Matt, I sent these to the maintainer list a long time
ago ([petsc-maint #155997]), but you never put them in, it would
avoid a lot of confusion)
/* Poiseuille flow problem. */
/* Viscous, laminar flow in a 2D channel with parabolic velocity */
/* profile and linear pressure drop, exact solution of the 2D Stokes */
/* equations. */
/* Discretized with the cell-centered finite-volume method on a */
/* Cartesian grid with co-located variables. Variables ordered as */
/* [u1...uN v1...vN p1...pN]^T. Matrix [A00 A01; A10, A11] solved with */
/* PCFIELDSPLIT. Lower factorization is used to mimick the Semi-Implicit */
/* Method for Pressure Linked Equations (SIMPLE) used as preconditioner */
/* instead of solver. */
/* Disclaimer: does not contain the pressure-weighed interpolation */
/* method needed to suppress spurious pressure modes in real-life */
/* problems. */
/* usage: */
/* mpiexec -n 2 ./ex70 -nx 32 -ny 48 -ksp_type fgmres -pc_type fieldsplit -pc_fieldsplit_type schur -pc_fieldsplit_schur_fact_type lower -fieldsplit_1_pc_type none
/* Runs with PCFIELDSPLIT on 32x48 grid, no PC for the Schur */
/* complement because A11 is zero. FGMRES is needed because */
/* PCFIELDSPLIT is a variable preconditioner. */
/* mpiexec -n 2 ./ex70 -nx 32 -ny 48 -ksp_type fgmres -pc_type fieldsplit -pc_fieldsplit_type schur -pc_fieldsplit_schur_fact_type lower -user_pc
/* Same as above but with user defined PC for the true Schur */
/* complement. PC based on the SIMPLE-type approximation (inverse of */
/* A00 approximated by inverse of its diagonal). */
/* mpiexec -n 2 ./ex70 -nx 32 -ny 48 -ksp_type fgmres -pc_type fieldsplit -pc_fieldsplit_type schur -pc_fieldsplit_schur_fact_type lower -user_ksp
/* Replace the true Schur complement with a user defined Schur */
/* complement based on the SIMPLE-type approximation. Same matrix is */
/* used as PC. */
/* mpiexec -n 2 ./ex70 -nx 32 -ny 48 -ksp_type fgmres -pc_type fieldsplit -pc_fieldsplit_type schur -pc_fieldsplit_schur_fact_type lower -fieldsplit_0_ksp_type gmres -fieldsplit_0_pc_type bjacobi -fieldsplit_1_pc_type jacobi -fieldsplit_1_inner_ksp_type preonly -fieldsplit_1_inner_pc_type jacobi -fieldsplit_1_upper_ksp_type preonly -fieldsplit_1_upper_pc_type jacobi
/* Out-of-the-box SIMPLE-type preconditioning. The major advantage */
/* is that the user neither needs to provide the approximation of */
/* the Schur complement, nor the corresponding preconditioner.
dr. ir. Christiaan Klaij
CFD Researcher
Research & Development
E mailto:C.Klaij at marin.nl
T +31 317 49 33 44
MARIN
2, Haagsteeg, P.O. Box 28, 6700 AA Wageningen, The Netherlands
T +31 317 49 39 11, F +31 317 49 32 45, I www.marin.nl
