[petsc-users] why a certain option cannot be used
Dave May dave.mayhem23 at gmail.com
Wed Jul 16 17:40:20 CDT 2014
You need to specify the fieldsplit preconditioning type. The choices are
-pc_fieldsplit_type <MULTIPLICATIVE> (choose one of) ADDITIVE
MULTIPLICATIVE SYMMETRIC_MULTIPLICATIVE SPECIAL SCHUR
Maybe what you want to run is the following
./ex70 -ksp_view  -pc_type fieldsplit -fieldsplit_0_pc_type jacobi
-fieldsplit_1_pc_type jacobi  -pc_fieldsplit_type SCHUR
-pc_fieldsplit_schur_precondition user
The option " -fieldsplit_1_user_pc" seems meaningless to me.
I don't see anything in ex70.c which would cause this option to have any
effect. The lines
 ierr     = PetscOptionsHasName(NULL, "-user_pc", &s.userPC);CHKERRQ(ierr);
  ierr     = PetscOptionsHasName(NULL, "-user_ksp",
&s.userKSP);CHKERRQ(ierr);
imply that the option -user_pc and -user_ksp are meaningful and modify how
the schur complement preconditioner will be configured. The first option
triggers this setup to occur;
  if (s->userPC) {
    ierr = PCFieldSplitSchurPrecondition(pc, PC_FIELDSPLIT_SCHUR_PRE_USER,
s->myS);CHKERRQ(ierr);
the second option will force this setup to occur
  if (s->userKSP) {
    ierr = PCSetUp(pc);CHKERRQ(ierr);
    ierr = PCFieldSplitGetSubKSP(pc, &n, &subksp);CHKERRQ(ierr);
    ierr = KSPSetOperators(subksp[1], s->myS, s->myS,
SAME_PRECONDITIONER);CHKERRQ(ierr);
    ierr = PetscFree(subksp);CHKERRQ(ierr);
On 17 July 2014 00:24, Sun, Hui <hus003 at ucsd.edu> wrote:
>  Thank you Dave. It does give me the other options. However I want to be
> able to use the user defined fieldsplit_1_pc_type. In example ex70.c, there
> is a user defined Schur complement preconditioner. I want to use that. Then
> how should I set the values for the options?
>  I tried to see which values could be set by typing
>  ./ex70 -pc_type fieldsplit -help 2>/dev/null | grep -A5 fieldsplit_1_pc
>   And I get the following output:
>    -fieldsplit_1_pc_type <bjacobi>: Preconditioner (one of) none jacobi
> pbjacobi bjacobi sor lu shell mg
>       eisenstat ilu icc cholesky asm gasm ksp composite redundant nn mat
> fieldsplit galerkin exotic hmpi asa cp lsc redistribute svd gamg tfs
> (PCSetType)
>   -fieldsplit_1_pc_use_amat: <FALSE> use Amat (instead of Pmat) to define
> preconditioner in nested inner solves (PCSetUseAmat)
>   Block Jacobi options
>   -fieldsplit_1_pc_bjacobi_blocks <-1>: Total number of blocks
> (PCBJacobiSetTotalBlocks)
> Krylov Method (KSP) options
>   -fieldsplit_1_ksp_type <preonly>: Krylov method (one of) cg groppcg
> pipecg cgne nash stcg gltr richardson
>       chebyshev gmres tcqmr bcgs ibcgs fbcgs fbcgsr bcgsl cgs tfqmr cr
> pipecr lsqr preonly qcg bicg fgmres minres symmlq lgmres lcd gcr pgmres
> specest dgmres (KSPSetType)
>   -fieldsplit_1_ksp_max_it <10000>: Maximum number of iterations
> (KSPSetTolerances)
>   -fieldsplit_1_ksp_rtol <1e-05>: Relative decrease in residual norm
> (KSPSetTolerances)
>  I cannot find anything here about the user defined pc. Do you have any
> idea what might be the choice?
> *From:* Dave May [dave.mayhem23 at gmail.com]
> *Sent:* Wednesday, July 16, 2014 3:11 PM
> *To:* Sun, Hui
> *Cc:* Matthew Knepley; petsc-users at mcs.anl.gov
> *Subject:* Re: [petsc-users] why a certain option cannot be used
>    To see all the fieldsplit options, run with
>  -help will only display the options relevant to the current configuration
> of your KSP and PC.
> On 17 July 2014 00:10, Dave May <dave.mayhem23 at gmail.com> wrote:
>>  Run with
>>  -help
>> On 17 July 2014 00:07, Sun, Hui <hus003 at ucsd.edu> wrote:
>>>  Thank you Dave, it does solve the problem. Another question is: since
>>> some options like
>>>  does not show up if I type
>>>  ./ex70 -help
>>>  how then can I have a complete list of all the options?
>>>  Best,
>>> Hui
>>> *Sent:* Wednesday, July 16, 2014 2:57 PM
>>> *To:* Sun, Hui
>>>   You need to specify on the command line
>>> -pc_type fieldsplit -fieldsplit_0_pc_type xxx -fieldsplit_1_pc_type yyy
>>>  Where xxx and yyy are the desired preconditioners for the (1,1) block
>>> and (2,2) block. Note that the default PC (ilu(0)) applied to both splits
>>> will fail for this example.
>>>  The comments in the code are misleading and incorrect. Without the
>>> option -pc_type fieldsplit, all fieldsplit options have no effect.
>>>  When debugging solvers, always run with - ksp_view (as Matt
>>> recommends)
>>> On Wednesday, 16 July 2014, Sun, Hui <hus003 at ucsd.edu> wrote:
>>>>  No I don't think I'm using fieldsplitting although I want to use it.
>>>> The output of
>>>>  ./ex70 -nx 32 -ny 48 -fieldsplit_1_pc_type jacobi -ksp_view
>>>>  is the following:
>>>>  KSP Object: 1 MPI processes
>>>>   type: gmres
>>>>     GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
>>>> Orthogonalization with no iterative refinement
>>>>     GMRES: happy breakdown tolerance 1e-30
>>>>   maximum iterations=10000, initial guess is zero
>>>>   tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
>>>>   left preconditioning
>>>>   using PRECONDITIONED norm type for convergence test
>>>> PC Object: 1 MPI processes
>>>>   type: none
>>>>   linear system matrix = precond matrix:
>>>>   Matrix Object:   1 MPI processes
>>>>     type: nest
>>>>     rows=4608, cols=4608
>>>>       Matrix object:
>>>>         type=nest, rows=2, cols=2
>>>>         MatNest structure:
>>>>         (0,0) : prefix="a00_", type=mpiaij, rows=3072, cols=3072
>>>>         (0,1) : prefix="a01_", type=mpiaij, rows=3072, cols=1536
>>>>         (1,0) : prefix="a10_", type=mpiaij, rows=1536, cols=3072
>>>>         (1,1) : prefix="a11_", type=mpiaij, rows=1536, cols=1536
>>>>  residual u = 2.6315e-05
>>>>  residual p = 0.000229872
>>>>  residual [u,p] = 0.000231373
>>>>  discretization error u = 0.00633503
>>>>  discretization error p = 0.121534
>>>>  discretization error [u,p] = 0.121699
>>>> WARNING! There are options you set that were not used!
>>>> WARNING! could be spelling mistake, etc!
>>>> Option left: name:-fieldsplit_1_pc_type value: jacobi
>>>> *From:* Sun, Hui
>>>> *Sent:* Wednesday, July 16, 2014 2:40 PM
>>>> *To:* Matthew Knepley
>>>> *Cc:* petsc-users at mcs.anl.gov <http://UrlBlockedError.aspx>
>>>> *Subject:* RE: [petsc-users] why a certain option cannot be used
>>>>   Thank you Matt. I've corrected it to
>>>>  However the output is still:
>>>>  If I type
>>>>  ./ex70 -help | grep fieldsplit_1_
>>>>  the output is that nothing coming out.
>>>> *From:* Matthew Knepley [knepley at gmail.com
>>>> <http://UrlBlockedError.aspx>]
>>>> *Sent:* Wednesday, July 16, 2014 2:32 PM
>>>> *To:* Sun, Hui
>>>>    On Wed, Jul 16, 2014 at 4:25 PM, Matthew Knepley <knepley at gmail.com
>>>> <http://UrlBlockedError.aspx>> wrote:
>>>>>   On Wed, Jul 16, 2014 at 4:22 PM, Sun, Hui <hus003 at ucsd.edu
>>>>>>  Thank you Matt for answering, however even with that I don't think
>>>>>> it works. For example, the command
>>>>>>  ./ex70 -nx 32 -ny 48 -fieldsplit_1_type jacobi
>>>>>  You have mistyped. Look carefully at my last message:
>>>>  I also want to note that you can see all the available options with
>>>> -help. It does produce
>>>> a lot of output, but you can segregate it by prefix ("fieldsplit_1_").
>>>> You can also see the
>>>> prefix of each solver component using -ksp_view.
>>>>    Matt
>>>>>        Matt
>>>>>>   gives me the following output
>>>>>> Option left: name:-fieldsplit_1_type value: jacobi
>>>>>>  Furthermore, if I look into the possible options with keyword
>>>>>> fieldsplit involved by the command:
>>>>>>  ./ex70 -help | grep -A5 fieldsplit
>>>>>>  I get this output:
>>>>>> (PCSetType)
>>>>>>   -pc_use_amat: <FALSE> use Amat (instead of Pmat) to define
>>>>>>   -ksp_type <gmres>: Krylov method (one of) cg groppcg pipecg cgne
>>>>>> cr pipecr lsqr preonly qcg bicg fgmres minres symmlq lgmres lcd gcr pgmres
>>>>>>   -ksp_max_it <10000>: Maximum number of iterations (KSPSetTolerances)
>>>>>>  So I don't see any option that's similar to -fieldsplit_1_type.
>>>>>>  Hui
>>>>>> *Sent:* Wednesday, July 16, 2014 2:16 PM
>>>>>> *To:* Sun, Hui
>>>>>>    On Wed, Jul 16, 2014 at 4:09 PM, Sun, Hui <hus003 at ucsd.edu
>>>>>>>  I want to solve Stokes equation using user defined schur
>>>>>>> complement preconditioner. So I'm reading and testing
>>>>>>> snes/examples/tutorial/ex55.c, and ex70.c. In these examples, there are
>>>>>>> comments about the usage, for example:
>>>>>>>  mpiexec -n 2 ./stokes -nx 32 -ny 48 -fieldsplit_1_user_pc.
>>>>>>>  However the option -fieldsplit_1_user_pc is not recognized by the
>>>>>>> executable. The output of the above command is:
>>>>>>  This ("user_pc") is just a mnemonic. What it means is that you can
>>>>>> use any PC in this slot. What he should have written is
>>>>>>    -fieldsplit_1_pc_type <user pc>
>>>>>>    Thanks,
>>>>>>       Matt
>>>>>>> Option left: name:-fieldsplit_1_user_pc (no value)
>>>>>>>  I'm wondering what's going on. Is that because I need some
>>>>>>> specific options during my configuring of the package? By the way, the
>>>>>>> version of PETSc I'm using is 3.4.4.
>>>>>>>  Best,
>>>>>>> Hui
>>>>>> What most experimenters take for granted before they begin their
>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140717/1cb642ba/attachment-0001.html>
