[petsc-users] why a certain option cannot be used
Dave May dave.mayhem23 at gmail.com
Wed Jul 16 17:10:30 CDT 2014
Run with
-help
On 17 July 2014 00:07, Sun, Hui <hus003 at ucsd.edu> wrote:
>  Thank you Dave, it does solve the problem. Another question is: since
> some options like
>  -fieldsplit_0_pc_type
>  does not show up if I type
>  ./ex70 -help
>  how then can I have a complete list of all the options?
>  Best,
> Hui
> *From:* Dave May [dave.mayhem23 at gmail.com]
> *Sent:* Wednesday, July 16, 2014 2:57 PM
> *To:* Sun, Hui
> *Cc:* Matthew Knepley; petsc-users at mcs.anl.gov
> *Subject:* Re: [petsc-users] why a certain option cannot be used
>  You need to specify on the command line
> -pc_type fieldsplit -fieldsplit_0_pc_type xxx -fieldsplit_1_pc_type yyy
>  Where xxx and yyy are the desired preconditioners for the (1,1) block
> and (2,2) block. Note that the default PC (ilu(0)) applied to both splits
> will fail for this example.
>  The comments in the code are misleading and incorrect. Without the
> option -pc_type fieldsplit, all fieldsplit options have no effect.
>  When debugging solvers, always run with - ksp_view (as Matt recommends)
> On Wednesday, 16 July 2014, Sun, Hui <hus003 at ucsd.edu> wrote:
>>  No I don't think I'm using fieldsplitting although I want to use it.
>> The output of
>>  ./ex70 -nx 32 -ny 48 -fieldsplit_1_pc_type jacobi -ksp_view
>>  is the following:
>>  KSP Object: 1 MPI processes
>>   type: gmres
>>     GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
>> Orthogonalization with no iterative refinement
>>     GMRES: happy breakdown tolerance 1e-30
>>   maximum iterations=10000, initial guess is zero
>>   tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
>>   left preconditioning
>>   using PRECONDITIONED norm type for convergence test
>> PC Object: 1 MPI processes
>>   type: none
>>   linear system matrix = precond matrix:
>>   Matrix Object:   1 MPI processes
>>     type: nest
>>     rows=4608, cols=4608
>>       Matrix object:
>>         type=nest, rows=2, cols=2
>>         MatNest structure:
>>         (0,0) : prefix="a00_", type=mpiaij, rows=3072, cols=3072
>>         (0,1) : prefix="a01_", type=mpiaij, rows=3072, cols=1536
>>         (1,0) : prefix="a10_", type=mpiaij, rows=1536, cols=3072
>>         (1,1) : prefix="a11_", type=mpiaij, rows=1536, cols=1536
>>  residual u = 2.6315e-05
>>  residual p = 0.000229872
>>  residual [u,p] = 0.000231373
>>  discretization error u = 0.00633503
>>  discretization error p = 0.121534
>>  discretization error [u,p] = 0.121699
>> WARNING! There are options you set that were not used!
>> WARNING! could be spelling mistake, etc!
>> Option left: name:-fieldsplit_1_pc_type value: jacobi
>> *From:* Sun, Hui
>> *Sent:* Wednesday, July 16, 2014 2:40 PM
>> *To:* Matthew Knepley
>> *Cc:* petsc-users at mcs.anl.gov <http://UrlBlockedError.aspx>
>> *Subject:* RE: [petsc-users] why a certain option cannot be used
>>   Thank you Matt. I've corrected it to
>>  However the output is still:
>>  If I type
>>  ./ex70 -help | grep fieldsplit_1_
>>  the output is that nothing coming out.
>> *From:* Matthew Knepley [knepley at gmail.com <http://UrlBlockedError.aspx>]
>> *Sent:* Wednesday, July 16, 2014 2:32 PM
>> *To:* Sun, Hui
>>    On Wed, Jul 16, 2014 at 4:25 PM, Matthew Knepley <knepley at gmail.com
>> <http://UrlBlockedError.aspx>> wrote:
>>>   On Wed, Jul 16, 2014 at 4:22 PM, Sun, Hui <hus003 at ucsd.edu
>>>>  Thank you Matt for answering, however even with that I don't think it
>>>> works. For example, the command
>>>>  ./ex70 -nx 32 -ny 48 -fieldsplit_1_type jacobi
>>>  You have mistyped. Look carefully at my last message:
>>  I also want to note that you can see all the available options with
>> -help. It does produce
>> a lot of output, but you can segregate it by prefix ("fieldsplit_1_").
>> You can also see the
>> prefix of each solver component using -ksp_view.
>>    Matt
>>>        Matt
>>>>   gives me the following output
>>>> Option left: name:-fieldsplit_1_type value: jacobi
>>>>  Furthermore, if I look into the possible options with keyword
>>>> fieldsplit involved by the command:
>>>>  ./ex70 -help | grep -A5 fieldsplit
>>>>  I get this output:
>>>>  eisenstat ilu icc cholesky asm gasm ksp composite redundant nn mat
>>>> fieldsplit galerkin exotic hmpi asa cp lsc redistribute svd gamg tfs
>>>> (PCSetType)
>>>>   -pc_use_amat: <FALSE> use Amat (instead of Pmat) to define
>>>> preconditioner in nested inner solves (PCSetUseAmat)
>>>> Krylov Method (KSP) options
>>>>   -ksp_type <gmres>: Krylov method (one of) cg groppcg pipecg cgne nash
>>>> stcg gltr richardson
>>>>       chebyshev gmres tcqmr bcgs ibcgs fbcgs fbcgsr bcgsl cgs tfqmr cr
>>>> pipecr lsqr preonly qcg bicg fgmres minres symmlq lgmres lcd gcr pgmres
>>>> specest dgmres (KSPSetType)
>>>>   -ksp_max_it <10000>: Maximum number of iterations (KSPSetTolerances)
>>>>  So I don't see any option that's similar to -fieldsplit_1_type.
>>>>  Hui
>>>> *Sent:* Wednesday, July 16, 2014 2:16 PM
>>>> *To:* Sun, Hui
>>>>    On Wed, Jul 16, 2014 at 4:09 PM, Sun, Hui <hus003 at ucsd.edu
>>>>>  I want to solve Stokes equation using user defined schur complement
>>>>> preconditioner. So I'm reading and testing snes/examples/tutorial/ex55.c,
>>>>> and ex70.c. In these examples, there are comments about the usage, for
>>>>> example:
>>>>>  mpiexec -n 2 ./stokes -nx 32 -ny 48 -fieldsplit_1_user_pc.
>>>>>  However the option -fieldsplit_1_user_pc is not recognized by the
>>>>> executable. The output of the above command is:
>>>>  This ("user_pc") is just a mnemonic. What it means is that you can
>>>> use any PC in this slot. What he should have written is
>>>>    -fieldsplit_1_pc_type <user pc>
>>>>    Thanks,
>>>>       Matt
>>>>> Option left: name:-fieldsplit_1_user_pc (no value)
>>>>>  I'm wondering what's going on. Is that because I need some specific
>>>>> options during my configuring of the package? By the way, the version of
>>>>> PETSc I'm using is 3.4.4.
>>>>>  Best,
>>>>> Hui
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140717/df5d68d7/attachment.html>
