[petsc-users] why a certain option cannot be used
Dave May
dave.mayhem23 at gmail.com
Wed Jul 16 16:57:56 CDT 2014
You need to specify on the command line
-pc_type fieldsplit -fieldsplit_0_pc_type xxx -fieldsplit_1_pc_type yyy
Where xxx and yyy are the desired preconditioners for the (1,1) block and
(2,2) block. Note that the default PC (ilu(0)) applied to both splits
will fail for this example.
The comments in the code are misleading and incorrect. Without the
option -pc_type
fieldsplit, all fieldsplit options have no effect.
When debugging solvers, always run with - ksp_view (as Matt recommends)
On Wednesday, 16 July 2014, Sun, Hui <hus003 at ucsd.edu> wrote:
> No I don't think I'm using fieldsplitting although I want to use it. The
> output of
> ./ex70 -nx 32 -ny 48 -fieldsplit_1_pc_type jacobi -ksp_view
> is the following:
> KSP Object: 1 MPI processes
> type: gmres
> GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
> GMRES: happy breakdown tolerance 1e-30
> maximum iterations=10000, initial guess is zero
> tolerances: relative=1e-05, absolute=1e-50, divergence=10000
> left preconditioning
> using PRECONDITIONED norm type for convergence test
> PC Object: 1 MPI processes
> type: none
> linear system matrix = precond matrix:
> Matrix Object: 1 MPI processes
> type: nest
> rows=4608, cols=4608
> Matrix object:
> type=nest, rows=2, cols=2
> MatNest structure:
> (0,0) : prefix="a00_", type=mpiaij, rows=3072, cols=3072
> (0,1) : prefix="a01_", type=mpiaij, rows=3072, cols=1536
> (1,0) : prefix="a10_", type=mpiaij, rows=1536, cols=3072
> (1,1) : prefix="a11_", type=mpiaij, rows=1536, cols=1536
> residual u = 2.6315e-05
> residual p = 0.000229872
> residual [u,p] = 0.000231373
> discretization error u = 0.00633503
> discretization error p = 0.121534
> discretization error [u,p] = 0.121699
> WARNING! There are options you set that were not used!
> WARNING! could be spelling mistake, etc!
> Option left: name:-fieldsplit_1_pc_type value: jacobi
> *From:* Sun, Hui
> *Sent:* Wednesday, July 16, 2014 2:40 PM
> *To:* Matthew Knepley
> *Cc:* petsc-users at mcs.anl.gov
> <javascript:_e(%7B%7D,'cvml','petsc-users at mcs.anl.gov');>
> *Subject:* RE: [petsc-users] why a certain option cannot be used
> Thank you Matt. I've corrected it to
> However the output is still:
> If I type
> ./ex70 -help | grep fieldsplit_1_
> the output is that nothing coming out.
> *From:* Matthew Knepley [knepley at gmail.com
> <javascript:_e(%7B%7D,'cvml','knepley at gmail.com');>]
> *Sent:* Wednesday, July 16, 2014 2:32 PM
> *To:* Sun, Hui
> *Subject:* Re: [petsc-users] why a certain option cannot be used
> On Wed, Jul 16, 2014 at 4:25 PM, Matthew Knepley <knepley at gmail.com
> <javascript:_e(%7B%7D,'cvml','knepley at gmail.com');>> wrote:
>> On Wed, Jul 16, 2014 at 4:22 PM, Sun, Hui <hus003 at ucsd.edu
>> <javascript:_e(%7B%7D,'cvml','hus003 at ucsd.edu');>> wrote:
>>> Thank you Matt for answering, however even with that I don't think it
>>> works. For example, the command
>>> ./ex70 -nx 32 -ny 48 -fieldsplit_1_type jacobi
>> You have mistyped. Look carefully at my last message:
> I also want to note that you can see all the available options with
> -help. It does produce
> a lot of output, but you can segregate it by prefix ("fieldsplit_1_"). You
> can also see the
> prefix of each solver component using -ksp_view.
> Matt
>> Matt
>>> gives me the following output
>>> Option left: name:-fieldsplit_1_type value: jacobi
>>> Furthermore, if I look into the possible options with keyword
>>> fieldsplit involved by the command:
>>> ./ex70 -help | grep -A5 fieldsplit
>>> I get this output:
>>> eisenstat ilu icc cholesky asm gasm ksp composite redundant nn mat
>>> fieldsplit galerkin exotic hmpi asa cp lsc redistribute svd gamg tfs
>>> (PCSetType)
>>> -pc_use_amat: <FALSE> use Amat (instead of Pmat) to define
>>> preconditioner in nested inner solves (PCSetUseAmat)
>>> Krylov Method (KSP) options
>>> -ksp_type <gmres>: Krylov method (one of) cg groppcg pipecg cgne nash
>>> stcg gltr richardson
>>> chebyshev gmres tcqmr bcgs ibcgs fbcgs fbcgsr bcgsl cgs tfqmr cr
>>> pipecr lsqr preonly qcg bicg fgmres minres symmlq lgmres lcd gcr pgmres
>>> specest dgmres (KSPSetType)
>>> -ksp_max_it <10000>: Maximum number of iterations (KSPSetTolerances)
>>> So I don't see any option that's similar to -fieldsplit_1_type.
>>> Hui
>>> *Sent:* Wednesday, July 16, 2014 2:16 PM
>>> *To:* Sun, Hui
>>> On Wed, Jul 16, 2014 at 4:09 PM, Sun, Hui <hus003 at ucsd.edu
>>>> I want to solve Stokes equation using user defined schur complement
>>>> preconditioner. So I'm reading and testing snes/examples/tutorial/ex55.c,
>>>> and ex70.c. In these examples, there are comments about the usage, for
>>>> example:
>>>> mpiexec -n 2 ./stokes -nx 32 -ny 48 -fieldsplit_1_user_pc.
>>>> However the option -fieldsplit_1_user_pc is not recognized by the
>>>> executable. The output of the above command is:
>>> This ("user_pc") is just a mnemonic. What it means is that you can use
>>> any PC in this slot. What he should have written is
>>> -fieldsplit_1_pc_type <user pc>
>>> Thanks,
>>> Matt
>>>> Option left: name:-fieldsplit_1_user_pc (no value)
>>>> I'm wondering what's going on. Is that because I need some specific
>>>> options during my configuring of the package? By the way, the version of
>>>> PETSc I'm using is 3.4.4.
>>>> Best,
>>>> Hui
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140716/619439fc/attachment.html>
