[petsc-users] why a certain option cannot be used
Matthew Knepley
knepley at gmail.com
Wed Jul 16 16:43:10 CDT 2014
On Wed, Jul 16, 2014 at 4:40 PM, Sun, Hui <hus003 at ucsd.edu> wrote:
> Thank you Matt. I've corrected it to
> ./ex70 -nx 32 -ny 48 -fieldsplit_1_pc_type jacobi
> However the output is still:
> residual u = 2.6315e-05
> residual p = 0.000229872
> residual [u,p] = 0.000231373
> discretization error u = 0.00633503
> discretization error p = 0.121534
> discretization error [u,p] = 0.121699
> WARNING! There are options you set that were not used!
> WARNING! could be spelling mistake, etc!
> Option left: name:-fieldsplit_1_pc_type value: jacobi
> If I type
> ./ex70 -help | grep fieldsplit_1_
> the output is that nothing coming out.
That seems to show that you are not using PCFIELDSPLIT at all. Are you? You
can
check using -ksp_view
Matt
> *From:* Matthew Knepley [knepley at gmail.com]
> *Sent:* Wednesday, July 16, 2014 2:32 PM
> *To:* Sun, Hui
> *Cc:* petsc-users at mcs.anl.gov
> *Subject:* Re: [petsc-users] why a certain option cannot be used
> On Wed, Jul 16, 2014 at 4:25 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Wed, Jul 16, 2014 at 4:22 PM, Sun, Hui <hus003 at ucsd.edu> wrote:
>>> Thank you Matt for answering, however even with that I don't think it
>>> works. For example, the command
>>> ./ex70 -nx 32 -ny 48 -fieldsplit_1_type jacobi
>> You have mistyped. Look carefully at my last message:
> I also want to note that you can see all the available options with
> -help. It does produce
> a lot of output, but you can segregate it by prefix ("fieldsplit_1_"). You
> can also see the
> prefix of each solver component using -ksp_view.
> Matt
>> Matt
>>> gives me the following output
>>> Option left: name:-fieldsplit_1_type value: jacobi
>>> Furthermore, if I look into the possible options with keyword
>>> fieldsplit involved by the command:
>>> ./ex70 -help | grep -A5 fieldsplit
>>> I get this output:
>>> eisenstat ilu icc cholesky asm gasm ksp composite redundant nn mat
>>> fieldsplit galerkin exotic hmpi asa cp lsc redistribute svd gamg tfs
>>> (PCSetType)
>>> -pc_use_amat: <FALSE> use Amat (instead of Pmat) to define
>>> preconditioner in nested inner solves (PCSetUseAmat)
>>> Krylov Method (KSP) options
>>> -ksp_type <gmres>: Krylov method (one of) cg groppcg pipecg cgne nash
>>> stcg gltr richardson
>>> chebyshev gmres tcqmr bcgs ibcgs fbcgs fbcgsr bcgsl cgs tfqmr cr
>>> pipecr lsqr preonly qcg bicg fgmres minres symmlq lgmres lcd gcr pgmres
>>> specest dgmres (KSPSetType)
>>> -ksp_max_it <10000>: Maximum number of iterations (KSPSetTolerances)
>>> So I don't see any option that's similar to -fieldsplit_1_type.
>>> Hui
>>> *Sent:* Wednesday, July 16, 2014 2:16 PM
>>> *To:* Sun, Hui
>>> On Wed, Jul 16, 2014 at 4:09 PM, Sun, Hui <hus003 at ucsd.edu> wrote:
>>>> I want to solve Stokes equation using user defined schur complement
>>>> preconditioner. So I'm reading and testing snes/examples/tutorial/ex55.c,
>>>> and ex70.c. In these examples, there are comments about the usage, for
>>>> example:
>>>> mpiexec -n 2 ./stokes -nx 32 -ny 48 -fieldsplit_1_user_pc.
>>>> However the option -fieldsplit_1_user_pc is not recognized by the
>>>> executable. The output of the above command is:
>>> This ("user_pc") is just a mnemonic. What it means is that you can use
>>> any PC in this slot. What he should have written is
>>> -fieldsplit_1_pc_type <user pc>
>>> Thanks,
>>> Matt
>>>> Option left: name:-fieldsplit_1_user_pc (no value)
>>>> I'm wondering what's going on. Is that because I need some specific
>>>> options during my configuring of the package? By the way, the version of
>>>> PETSc I'm using is 3.4.4.
>>>> Best,
>>>> Hui
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140716/56f3d731/attachment.html>
