[petsc-users] Computing time derivatives in the residual for TS
Jed Brown
jed at jedbrown.org
Fri Jul 11 12:12:20 CDT 2014
Mani, I apologize for my slow reply.
Mani Chandra <mc0710 at gmail.com> writes:
> Hi,
> Suppose the following is the residual function that TS needs:
> void residualFunction(TS ts, PetscScalar t, Vec X, Vec dX_dt, Vec F, void
> *ptr)
> and this returns the following finite volume residual at each grid point
> dU_dt + gradF + sourceTerms = 0
> where dU_dt are the time derivatives of the conserved variables.
> The value of dU_dt needs to be computed from the values of the time
> derivatives of the primitive variables given in dX_dt, i.e. dU_dt is an
> analytic function of dX_dt.
I recommend using this analytic relationship, i.e.,
dU_dt = dU/dX dX_dt
This can be done by algorithmic differentiation or differencing, if you
prefer.
> But is it possible to compute dU_dt numerically using the vector X and
> it's value at a previous time step like the following?
> dU_dt = (U(X) - U(X_old) )/dt -- (1)
> (instead of analytically computing dU_dt which is a function of the vectors
> X and dX_dt which is hard to do if the function is very complicated)
> So, is computing dU_dt using (1) permissible using TS? The jacobian will be
> correctly assembled for implicit methods?
No, your equation is a very inaccurate time derivative and will spoil
the accuracy and stability properties of the high-order time
integrators. You could add U as an algebraic constraint:
U - eq_state(X) = 0
if you want. This equation is trivial to solve, but it requires that
you use methods capable of solving DAEs.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140711/194ac1f5/attachment.pgp>
